W221 S65 turbo leaking
Old Dec 20, 2012 | 01:10 PM
vee12's Avatar
W221 S65, W140 S600, W210 E430, W126 300SD
Recently noticed coolant on the garage floor. Took it in to my trusted indy for evaluation....they diagnosed leaks in both turbos...the driver side more so. $4500 for each turbo (part only) plus labor, etc, etc, to remove the engine to get to everything. Total damage somewhere in the $13-15K range. What a lovely Christmas present! Anyone else had issues with these watercooled turbos leaking coolant?
Might be time to give Speeddriven a call.
Old Dec 20, 2012 | 05:52 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
yes i have seen V12TT leak / loose coolant from the turbo
Old Dec 20, 2012 | 08:12 PM
dtohio's Avatar
05,cl65;33ford3wc.
This is a newer model, any warranty? In any event isn't this hopefully a plumbing fix? New turbos seem like worst case scenario, i'd get a second opinion.
Old Dec 20, 2012 | 09:12 PM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
Since you need new turbos are there any vendors that sell upgraded turbos?
I feel for you man. Uncle had the exact same issue on his Porsche Turbo, total damage was slightly more than what you're looking at.
Old Dec 20, 2012 | 10:00 PM
babyman1737's Avatar
2005 CLK500 cab, 2004 S600 designo mocha
Why/how would turbos leak coolant? You would think it's just the banjo connections or crush washers? That must mean the turbo bodies are cracked? I've never heard of that.....
Old Dec 21, 2012 | 07:25 PM
UNderdog's Avatar
S65 GL320CDI GLS63 80 Series Landcruiser
I agree. My Indy lets me check out the car when it's on the lift. I would want to see the leak. Can't just start throwing parts at it...that's what going to the dealer is for! Make sure he's seen this engine before; experience is everything.
Old Dec 22, 2012 | 09:14 PM
vee12's Avatar
I got a look at the leaking turbos. The turbos have what looks like a freeze plug on the housing. The leak is coming out of these "freeze plugs". Apparently Mercedes Benz does not offer the freeze plug as a replacement part....not that you could not fabricate one. Still would have to pull the motor to replace them. What a tool job.
Old Jan 6, 2013 | 08:24 AM
Stephen04E55's Avatar
'09 CLK550, '18 AMG GTR, '06 C55 AMG, '25 GLS450, 09 E63
my buddy has a '07 W221 S600 had the same thing happen...under warranty.
Old Jan 13, 2013 | 12:28 PM
Busa196's Avatar
2018 S63, lowered
Yep, happened to me but was just an O-ring where the coolant flows int the turbo. But, required some massive labor......all under warranty of course. Your turbos aren't bad......thats ridiculous.
It's stories like this that people who even consider owning one of these cars without a warranty need to read.
Old Jul 15, 2014 | 03:40 PM
Welwynnick's Avatar
2006 S600
This is what my turbo water seals looked like after 10 years. The top ones (coolant outlets) were heavily perished, but still weren't leaking. I replaced them with the new red ones. Like divertor valve diaphragms, this isn't something you would do out of choice.
157,000 miles on my wagon, and no warranty...
Nick
Old Jul 16, 2014 | 11:21 AM
Speedriven1's Avatar
Speedriven
We offer a complete rebuild/upgraded turbo's. Custom billet wheels and machined housings. Turbo's are completely overhauled with brand new seals and gaskets. The package is $3900 plus shipping along with core is required. Takes about 3 weeks after we receive turbo's.
