S 55 ABC pump?
Yesterday the white ABC warning came on shortly followed by the RED ABC warning. The car dropped on the rear and the tires began to rub. I pulled over and shut off the car. I cleared the warnings with the "r" (reset) dash button. The car was sitting down on the rear tires. I restarted the car and after approximately 30 seconds the car rose on its own and assumed a normal stance.
About 6 hours later I drove the car again and received both ABC warnings but the rear did not drop down. This AM the car was sitting normally when I stated it and drove it for about 10 miles with no warnings or dropping. After finsihing this appointment (approx. 1 hr.) I drove for another 7 miles and the lights came on and the suspension dropped on the rear to settle on the rear tires. I was in the store for 5 minutes and came out and started the car. The car remained on the rear tires until I pushed the raise button on the dash. The ABC red warning now showed car rising and then the warning disappeared and up came "no malfunctions.
Now for my question. Does this indicate a pump going bad as my Indie tells me or is it a sensor or electrical problem as it seems to me?
https://mbworld.org/forums/cl55-amg-...ock-today.html
https://mbworld.org/forums/s-class-w...2003-s600.html
First thing to do, though, is check the fluid level in the reservoir. Its the large one next to the power steering reservoir.
Nick
There might possibly be some air in the system, but its probably contamination. As long as the reservoir is full and the pump isn't making any audible noises, it should help by repeatedly raising and lowering as you drive along, which is a sort of DIY rodeo. That may help to clear the rubbish out.
Otherwise I think you need to remove the rear valve block and clean out the valves, and I would replace the O-rings while you're at it. Its not that difficult.
Whatever you do, don't go to a dealer or believe anyone who says you need a new pump or valve block.
Nick
Out of curiosity, did the Indie replace the ABC filter when he did the fluid change? There is an uber-fine mesh filter in the ABC reservoir that should be replaced with fluid changes. Perhaps some contamination on the filter was disturbed during the fluid change process, especially if the filter was pulled out and the reservoir was not drained prior to the fluid change. Nick is right, the ABC circuit is wickedly susceptible to valve block contamination.
Cheers,
Jeff
Bob, +1 on this thread. I've just finished going through this on my car, but not in MI, as the car was in FL at the time. It's the valve. Not a cheap part, but a very well known problem and procedure. I think Mercedes rec is actually to address the fluid as a first step, and if the problem re-occurs, to address the valve. It's not the pump.
Good luck, and let me know how it turns out.
Cheers,
maw
Cheers,
Jeff
