ABC question
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
What you need to do is rebuild the control block with new O-rings and clean the valve assembly.
This is a high pressure system so follow the instructions that are on one of these forums.
Mbenz will not clean it and will insist on a new block which is about $1700.
The system is quite conventional - there's a pump, four struts, some dampers, a reservoir, filter and cooler. There are also two valve blocks. Both front struts are controlled by the forward valve block, which is in front of the left front wheel. There's a rear valve block, in front of the right rear wheel. They're pretty much independent, as long as the pump doesn't fail - but it sounds like it's OK. Other thing you have to watch is the fluid level. The pump absolutely must not be allowed to run dry.
It sounds like your problem is with the valve blocks. The O-rings don't last forever, plus they leak when they're contaminated with dirt. Dealers will replace them at great expense, but all they need is dismantling, cleaning and new O-rings. Its not difficult or expensive, bar the cost of the Pentosin CHF-11S fluid. There are several threads about this - have a look at Howards wonderful W220 maintenance thread here:
https://mbworld.org/forums/5184137-post81.html
https://mbworld.org/forums/s-class-w...03-s600-4.html
Regards,
Nick
BTW I would replace the filter every year and check the fluid level. Don't overfill. It's better to be at the low marker or just a bit above. The new filters are 3 micron vs. the 10 micron of the original filters.
I've heard that opened/resealed Pentosin fluid goes bad after a period of time so if you top off you should be aware of that. Does anyone know definitely about this degradation interval?
Off topic: BTW since installing Racing Brake 2 piece rotors in the CL55 that save substantial weight over the stock AMG rotors seat of the pants impression is that the ABC system is not working as hard because of the lower unsprung weight. Bumps in the road are softer with increased road feel and cornering prowess. Braking distance has been reduced considerably, I still haven't got used to this. BTW the MB pads are now made by TRW and are a considerable improvement in construction and performance over the Pagid pads stamped Brembo that were installed originally.
