S55 Spark Plug Change
Thanks in Advance.
Thanks in Advance.
If your coil setup is similar to my wife's E500, it's pretty straight forward. One coil per cylinder with 2 plugs per (16 spark plugs total). Keep track which line is A and B. Don't use too much dielectric grease when re-installing or the wire will slide off slowly (fit so tight there was a slight vacuum...putting it on slowly seemed to help a bit). If you're done and it's idling roughly when you re-start check to see if one didn't pop off.
Id rather not chance something else going on the electrical side.
Mike
I got a friend mechanic of mine to do mine, his advice to you is . . . . . . the front 8 are pretty straight forward, but get a "swear-jar" for the rear 8.
(I have one at work, when it hits 50 bucks I buy drinks!)
, but there is a special tool
to get the spark plug boots off if I remember correctly for the plugs near the firewall which are hard to get to. I'm thinking of getting the Iridiium type plugs by Bosch or has anyone used DENSo?
Unless your doing serious engine mods then dont worry about cold plugs, just stick with the normal ones. I thought i would put Bosch Platinum in mine, funnily enough the last guy must have done the same thought as thats what came out of the car aswell. Never had any problems with them.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
BTW I would use exactly the plugs mentioned in the Owners Manual. However, if you have a modified engine as EM says one must go down a heat range as a rule.
I use a long skinny 14mm open end wrench to help me pop the base of each plug wire off the plugs. They are friction fitted by the ground shields. Just sitting in the holes. A little leverage from the open-end wrench helps pop them off the plugs.
Your tool drawer should include a good socket set with various extension lengths and various wobble versions. It helps to have a wobble-extension on the socket to get at the back plugs. I removed the air boxes to get full access.
Don’t worry about the battery.
Be careful if you decide to disconnect each ignition pack from the electrical source harness, as the plastic connectors would be brittle by now. Go slow and don’t force them.
good luck.
Fun w my plugs
