s 55 amg 2002 active body control issues
Old Feb 26, 2014 | 01:19 PM
jiffypop's Avatar
s 55 amg
well in a nutshell here it goes , purchased car about three years ago . Every day whenever I left the car upon return , the car had sunk . Upon starting would raise up , thought this was normal . fast forward to few months ago , red light has been coming on for a while and noticed that's its handling ability diminished , along with the jolt from going over bumps. few weeks ago the car would stay jacked up , but higher than normal ( a lot higher) now the car is resting on one side , kind of like a one legged duck . I did check fluid level , that was ok and no leaks that I noticed . Any ideas ?? is it a bad strut , ABC pump , valve block or sensor or all of the above ...
Old Feb 26, 2014 | 03:00 PM
holycowe's Avatar
Ussually if it sunk like that. It's the valve blocks and also the tandem pump is on it way out too as well (doesn't hold pressure after engine turned off).
Sorry but either way, it's gonna be expensive fix
Old Feb 26, 2014 | 05:26 PM
Welwynnick's Avatar
2006 S600
Its easy to be negative about ABC when it goes wrong, but its not necessarily a disaster. This case may be as simple as a valve block service - clean out and re-seal. There are several threads and videos about this. Just google "abc valve block repair"
Nick
Old Feb 26, 2014 | 05:46 PM
jiffypop's Avatar
s 55 amg
Nick
going to take vehicle to the stealership just to run it through the computers and get the codes , than off to a local MB guy . question would the system let me no of such a problem ie re- seal or valve block repair.. I do maintain their are no leaks but im sure that's not the whole picture
Old Feb 26, 2014 | 06:00 PM
Welwynnick's Avatar
2006 S600
Would the system tell you if the valve block was leaking?
No, I can't see how it can.
Its not exactly a rare fault, and in every instance reported around here, nobody said DAS told them where to look.
Not have they said there were any external leaks. They have always been internal.
Old Feb 26, 2014 | 06:13 PM
jiffypop's Avatar
s 55 amg
did google valve block repair watched you tube version , was most impressive especially some of the comments from the peanut gallery.
Old Feb 26, 2014 | 06:25 PM
jiffypop's Avatar
s 55 amg
Nick
lets say your right , after looking at the you tube on abc block repair seems to me that most of the fixes stem from here , and that most of all the other work done is a waist . especially the comments coming from this one knowledgeable person in the comments section . not sure how to proceed , do I go to the stealership and get a bunch of rotten codes or do I delve into this 90 minute procedure.
Old Feb 26, 2014 | 06:47 PM
jnash's Avatar
2017 S63
Depends how good you are at DIY. You will need new O-rings to rebuild the valve blocks.
I have an O-ring kit, they are listed on one of these forums.
A dealer will replace the valve block and not rebuild it.
There are extensive tests on SDS that your dealer could do, if they know how.
The only code you are likely to see form a quick test is low pressure.
Old Feb 26, 2014 | 08:14 PM
jiffypop's Avatar
s 55 amg
i am quoting someone i looked at regarding abc valve block repair " almost every problem ive ever seen with ABC cars is caused by dirty fluid , keep that in mind I worked at the dealership for 8 years until 2009 so I no what im talking about . the fluid gets worked hard and pentosin leaves deposits when heated. Your car uses air instead of fluid but somewhat similar . If you here air leaking thats a pretty good clue that there is a problem. Just follow the noise until you find the leak. I worked on hundreds of late model benz, honestly , hundreds and thats how we diagnosed suspension issues end of story" he continues on with how to work each strut .
Old Feb 27, 2014 | 08:11 AM
Welwynnick's Avatar
2006 S600
I always recommend people to look at this thread on W220 maintenance, which should help provide some confidence in what can be done:
https://mbworld.org/forums/s-class-w...03-s600-4.html
Nick
Old Feb 27, 2014 | 11:31 AM
jiffypop's Avatar
s 55 amg
Jnash if their is no leak is that a good sign , in otherwords does it rule out a bunch of issues or not enough info to go from . BTW you have been very very very helpful cant thank you enough.
