S 55 AMG 2002 , car raised up to high , rides rough.
Old Apr 11, 2014 | 11:16 AM
jiffypop's Avatar
s 55 amg
Just finished getting clobbered by stealership , had the dreaded Active body control pump replaced $$$ WHICH WAS DEAD , However, they did mention to me car is raised up slightly higher and you can feel every bump you go over . This was what dealer wrote up additionally " GOT ACTIVE BODY CONTROL UP AND RUNNING , TIGHTEND LINES,SOME LINES ARE SEEPING , VEHICLE RAISES UP NOW AND IS DRIVABLE BUT RIDES ROUGH , VERY STIFF , WOULD NEED TO DIAGNOSE STIFF RIDE ISSUE , VIBRATION DAMPNER ISSUE , NEED TO LOOK INTO FURSTER, TRIED TO GET CAR TO LOWER DOWN AND GET OUT OF STIFF MODE BUT WOULD NOT LOWER, NEED MORE LABOR TIME TO INSPECT AND DIAGNOSE IF CLIENT WANTS " . NATURALLY I SAY NO AT $175 AN HOUR . ANY IDEA WHAT THIS COULD BE .
Old Apr 11, 2014 | 11:30 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
if the car raises up and rides stiff, there is a fault in the ABC system (this is a fail safe mode). The dealer has not done their due diligence.
A faulty speed sensor can also trigger this fail safe mode.
Old Apr 11, 2014 | 11:40 AM
jiffypop's Avatar
s 55 amg
are you 100% certain , what should i do .
Old Apr 11, 2014 | 12:14 PM
shardul's Avatar
yes. if there is an error in the ABC, speed sensor system and other realted systems the ABC will go into a fail safe mode and raise all they way up and ride will be super stiff
Old Apr 11, 2014 | 01:10 PM
jiffypop's Avatar
s 55 amg
well than is this an expensive fix.
Old Apr 11, 2014 | 02:30 PM
shardul's Avatar
all they have to do is a run a quick test via DAS and it will show whats causing the issue.
Old Apr 14, 2014 | 01:33 PM
jiffypop's Avatar
s 55 amg
Thanks , you have been great help , but is their usually a set problem with this , or could it be many things .
Old Apr 14, 2014 | 06:09 PM
richvegas's Avatar
2016 S65 AMG coupe, 2010 E63, 2015 Z06/z07 m7 vert 735rwhp, 2000 f-350 crewcab w/ 16" kelderman kit
could be many things. worth the diag fee
Old Apr 17, 2014 | 09:19 PM
luckytomyu's Avatar
E 320 -2005, C 320 '04
Where are you located ? if you near East of Los angeles , i offer you to scan with my star diagnostic Das xentry for free,
but i only have time in weekend only. pls PM me
Tommy
