06 s55 AMG vibration at 2900
Thanks,
Cam
Has your Dealer Service looked at this part when you had the car there?
Best of luck!
Replaced the engine and trans mounts ( very expensive) which didn't do a thing.
ABC dampener wasn't too expensive - you can do it yourself if you're inclined. I wish I had done that myself first.
Good luck !
It could be harmonic balancer but I doubt it -- a wobbly crank pulley (harmonic balancer) wobbles at all RPMs, and if it was wobbling enough to vibrate the car, any dealer could find it. You would see it looking under the hood. If the engine mounts haven't been changed, I'd look there first. Virtually everyone recommends changing those with the trans mounts, but the trans mounts are so much easier, lazy service people will do trans mounts and leave engine mounts untouched.
Good luck and please keep us posted.
Cheers,
maw
Cheers,
maw
Just wanted to share my experience as this issue of vibration drove me nuts.
I understand this is an old thread, but when you’re searching all information is valuable.
So a couple years back I bought a really nice 2004 S55 AMG with 125k miles.
From day one I felt some vibration under my seat coming from the general transmission area.
The vibration was especially noticeable between 2000-3000 RPM (moving or parked).
So I decided if I’m going underneath and I plan on keeping the car for a while I might as well replace all possible related parts.
On my list I did motor mounts, transmission mount, both flex discs and the carrier bearing.
I thought for sure I had most if not all bases covered.
*All parts were bought from FCP Euro.
I took the car for a spin and to my disappointment the vibration was still present. Maybe a bit less than it was.
So I thought the last thing left was the harmonic balancer (crank shaft pulley).
After replacing the pulley (about a year later), once again I was disappointed because it didn’t solve the vibration problem.
After doing more research, I decided to buy the transmission mount from the dealer.
After removing the transmission mount bolts I jacked up the transmission off the cross support brace just to do a test by taking the load off the mount.
Sure enough, the vibration was gone. So I decided to replace a less than one year old transmission mount (that had vibration from day one) and what do you know, the car runs smooth!
maw
P.S. my 25+ year old 500E has taught me to only use OE parts on these cars. Pay the extra money and save yourself some headache.
Didn’t think rubber pads were that hard to replicate.
Apparently those other “German manufactured”aftermarket parts are not up to snuff.
