New purchase! 2003 s55 amg!
Old Feb 6, 2017 | 10:30 AM
AMGK1NG's Avatar
2004 clk55
This car has been my dream for the last 3 years, since 14 i started saving up for this car and 3 years later i bought it. The car has 127xxx on the clock. A couple of questions for my first post. My antifreeze is green, under my car its leaking very slowly blue fluid i dont know what it is. Car has srs on for passenger seat pad but other then that 0 issues! I need a couple cosmetic items such as front right jack hole cover and a rear bumper tow hook cover so if anyone has any in silver let me know! Wish me luck! i will post pictures.
Old Feb 6, 2017 | 11:09 AM
cmpcpro's Avatar
2004 CLK 500
Congratulations! Have you made sure the green fluid isn't ABC hydraulic fluid?
Old Feb 6, 2017 | 12:10 PM
AMGK1NG's Avatar
2004 clk55
There is no green fluid leaking only blue fluid.
Old Feb 6, 2017 | 11:00 PM
hvacdude's Avatar
2006 CLS55AMG & 2005 S55AMG
Washer fluid ?
Old Feb 7, 2017 | 02:22 AM
cmpcpro's Avatar
2004 CLK 500
Yeah probably washer fluid from the tank
Old Feb 7, 2017 | 08:08 AM
GrepAwk's Avatar
'03 S55 (79K miles)
Welcome to the club.
If blue, then probably washer fluid. Cracked tank? There are hoses that go to the windshield as well as to the headlights. Can you get under the car to look? You could try just pumping out all the blue fluid and replacing with the orange or yellow color some companies make (fogx) and give it a blast and look for ur next favorite color.
Do you mind saying how much you paid for the car?
Old Feb 7, 2017 | 01:20 PM
AMGK1NG's Avatar
2004 clk55
i paid 7150.
Old Feb 7, 2017 | 02:10 PM
Mikeki7's Avatar
CLS63, S55
The washer fluid is probably leaking from one of the headlight washers, I never use them so I temporarily unplugged the hose from the leaky one and plugged it.
Old Feb 7, 2017 | 03:48 PM
bigmyself's Avatar
2005 S55 AMG, 2005 S500
MB S55 coolant BQ1030004 agent is blue.
Old Feb 7, 2017 | 03:59 PM
Mikeki7's Avatar
CLS63, S55
If its not washer fluid but coolant thats leaking, find the source of the leak, hopefully not from the radiator itself, otherwise you would probably have to replace it vs replacing a leaky hose connection which is much cheaper. Also you said the coolant is green in the tank if there is blue coolant leaking you should do a flush after fixing the leak because mixing coolant that have different chemical properties can clog the radiator.
Old Feb 9, 2017 | 08:10 PM
AMGK1NG's Avatar
2004 clk55
Old Feb 10, 2017 | 07:14 PM
bigmyself's Avatar
It looks cool!
I replaced the star emblem to the black AMG flat emblem.
Sun
