S63 amg engine squeaky noise 2008
I only say this because I went through it on my 01.
my serpantine belt needs to be changed so I think I'll remove this and piole around a little more while it's off to see it I can't dial in on the exact issue.
SB
SB
The event. While driving I felt a very (make that VERY) slight shudder which was quickly followed-up with an onscreen notice to check ABC system, then to check the power steering fluid level, and then to check the engine coolant temperature. As I immediately began to pull towards the hard shoulder the steering tightened up and I coasted to a stop and shut-off the motor. First comment - when the power steering assistance is lost on these cars the steering is practically impossible to turn (while moving) - and when parked, just forget about it. Upon closer inspection I could see that my belt had snapped/been shredded, coolant was running everywhere, and I was gonna need a tow truck.
The next day I removed the radiator and fan housing, flushed the coolant system, cleaned out all the belt remnants, and took stock of just what had happened. Turns out that the bearing on the upper left idler pulley on the water pump (the grooved one) had collapsed, causing the pulley to lock tight, stripping the belt and shearing-off the plastic pulley cup. Also, upon inspection I noticed the upper right idler pulley on the water pump (smooth one) was in bad shape - it was not spinning freely and had a metallic whirring sound when it would spin. Fortunately I had a belt in hand already as I'd been planning to replace the existing one, so all I needed was 6L of coolant and two new pulleys. I called the local (Houston) stealership and they wanted $85/pulley. Refusing to pay these prices I ended-up buying OE units online for $21/pulley plus $11 on 2 day shipping. As for the coolant, it turns out that when the belt snapped it also took out the plastic fitting that connects the return hose from the expansion bottle to the thermostat housing - as in, it sheared it completely off. A new thermo housing is ~$190 but since the unit itself looked fine I decided to repair it as opposed to replacing it. I drilled-out and tapped the aluminum housing and installed a 3/8 hose barb that screwed straight into the housing itself and reconnected the hose with the existing pipe clamp.
After installing the new belt (really easy with the radiator and fan removed) I filled up the coolant, ran the system, bled-out the air and listened for the same squeaking sound. Not a peep - it now sounds perfect. What I think was happening was the bearing that failed was putting a lot of strain on the crankshaft/harmonic dampener and this is what was causing the squeaking. The car runs better than before so to anyone who is exhibiting any symptoms that you think might be related to the harmonic dampener I would highly recommend removing the belt and checking-out all the pulleys before dropping the $500 on a replacement dampener plus the cost to rent/buy the specialized tool to remove it. I'm $100 into this repair (for two pulleys, new serp. belt, a brass fitting ($3 from Home Depot) and 2 gallons of Zerex G-05 50/50 mix coolant).
Here are the part numbers (W221 2009 S63AMG):
Pulleys were bought from Pelican Parts:
Drive Belt Idler Pulley (Grooved, On Water Pump)
Brand: Litens Note: (2009 Mercedes-Benz S63 AMG Base Sedan)
Part #: 156-202-06-19-M302
http://www.pelicanparts.com/cgi-bin/...202-06-19-M302
OEM Part # A1562020619
Drive Belt Idler Pulley (Smooth, On Water Pump)
Part #: 156-202-08-19-M302
http://www.pelicanparts.com/cgi-bin/...202-08-19-M302
OEM Part # A1562020819
Amazon:
Serp. belt: $26.99 from Advanced Auto Parts (I found a 25% off coupon - they have them on their website ALL the time):
https://shop.advanceautoparts.com/p/...ontent=general
Amazon 1:
Amazon 2:
