S65 mercedes turbo problem 2008
Old Sep 27, 2017 | 08:55 AM
Hussein Jammal's Avatar
Mercedes s class
I have a mercedes s65 amg 2008 ihave a problem in the tubro if you are driving the car normally i does nothing but if i floored the gas perel the turbo stopes and the car startes shaking and im wondering whats the problem and if i turned the car of then start it as if nothing happened this problem happenes only if i floored it the car stops recieving gas as im pushing and the turbo stopes and it startes shaking im wondering if its the intercooler or the turbo or a sensor?? And pls if it happen to some one before i wana know what did he do
Old Sep 27, 2017 | 08:58 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Sounds like your car is going to limp mode due to bad coil packs. Very common after an ECU tune.
Old Sep 27, 2017 | 09:09 AM
Mercedes s class
I have no check engine light and by the way the car is stock and if i turn it of then start it comes normal but if i floored it again same problem will come so what do u think i should do
Old Sep 27, 2017 | 03:47 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
don't worry...the problem is unfixable and you should give the car to me.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Sep 27, 2017 | 04:44 PM
BlownV8's Avatar
Could be the intercooler pump is bad. Usually the coil packs will throw a CEL but a bad intercooler pump may not.
Old Sep 27, 2017 | 07:33 PM
Dublinoh's Avatar
E63 AMG 2007
Ok I can't really help you, but you need to have it hooked up to a Star reader and find out what codes are there. Come back with the codes and people can help you more.
Old Sep 28, 2017 | 12:06 AM
l pagan's Avatar
1999 E55, 2005 E55 AMG
Lmfao
Old Sep 28, 2017 | 08:35 AM
tscales's Avatar
2005 E55 Wagon, 2017 C63S Cab, 1986 560SL
I agree -- get it connected to Star.
My SL65 was a bottomless cost pit.
I'd guess coil packs ($3000-4000) or intercooler pump ($500).
Old Sep 29, 2017 | 08:25 AM
Mercedes s class
The codes were misfiring for clylinder i dont really remember which clylinders they are
Old Sep 29, 2017 | 08:40 AM
Hotsauce55's Avatar
2005 E55
Rockauto about $2K
Deep pockets are typically required for this car
Old Sep 30, 2017 | 01:29 PM
amstel78's Avatar
Veteran: Army
2006 W220 S65 AMG
You can buy new coil packs with lifetime warranties from FCP Euro for under $1500.00. You can also get rebuilt coil packs from Clark for around $700.
To the OP, flooring it and then the engine starts shaking is usually an indicator of a misfire event in one or multiple cylinders. I would not associate that with a failed IC pump.
Old Sep 30, 2017 | 04:36 PM
ItalianJoe1's Avatar
2003 CL 600
Take the car to a shop. Nothing simple or cheap to do to fix a misfire on the V12 cars, it's most likely a failed coil or igniter, it's 10 years old but i'm sure it's never had the plugs done. Budget for the spark plugs, coils and igniter (3500 in parts if you shop around, labor cost depends on where you are, 6-7 hours). That should make the car run like new for at least another 10 years.
Where are you located?
