Gear swap
Old Apr 23, 2018 | 01:50 PM
cmpcpro's Avatar
2004 CLK 500
Gear swap
Hey goes does anyone know which ring and pinions work for an 06 S55? I want to go 3.07 or 3.27. Thanks!
Old Apr 23, 2018 | 07:31 PM
cmpcpro's Avatar
2004 CLK 500
I didn’t think that would help seeing as these cars didn’t come with any other ratio but stock but here it is. Thanks!
WDBNG74J86A482876
Old Apr 23, 2018 | 11:37 PM
cmpcpro's Avatar
2004 CLK 500
It’s not a dream, I own Star and have already talked with Jerry who has done a few hundred of these gear swaps, it’s just a matter of finding the right gears for me rear end as he is just the tuner... it’s not hard to set the TCU and ECU for the swap at all, they will take upto 3.27’s
Old Apr 24, 2018 | 04:37 AM
cm60k's Avatar
Yeah, my friend done that 3 years ago,
he installed "3.27", but not sure from which M/Y diff. he went with, and adapt the TCU as well,
most tuners can do it,
soooo fun.., much wheel spin from dig, but really gain some ET's then..,,
i tried to contact him, but his Cell switched-off, seems his out of country..
-;ZAYED;-
Old Apr 24, 2018 | 07:32 AM
cmpcpro's Avatar
2004 CLK 500
If you can get ahold of him i would be FOREVER grateful to you!
Old Apr 24, 2018 | 05:24 PM
maw1124's Avatar
'06 MB S55 AMG; '04 Audi Allroad 4.2; '05 BMW M3 Conv.; '92 MB 500E
Chris, the guys at Quaife or Sun Valley may know. I'd start with Marc at Sun Valley since they did your transmission (IIRC).
GL
maw
Old Apr 24, 2018 | 06:20 PM
cmpcpro's Avatar
2004 CLK 500
Thanks,
Quaife didn’t seem to know or want to tell me which was a surprise, and Marc hasn’t written back yet, and that was about a week or two ago so I guess I’ll try to reach out to him again but didn’t figure he would be a big help on the differential end.
Chris
Old Apr 24, 2018 | 06:32 PM
maw1124's Avatar
Interesting re: Quaife. I've found over the years that Marc works better by phone. I'd also try Wavetrac, again by phone. Finally, Jonothan Hodgman, down at Blue Ridge MB (outside Atlanta) might know. 404.805.1357; www.blueridgemb.com; @blueridgemb. Jono is the one who first told me about Wavetrac LSD for these cars. Depending upon where you are geographically, Hodgman might be a good one to know in person.
GL
maw
Old Apr 25, 2018 | 12:25 PM
cm60k's Avatar
Chris,
My friend called me hour ago,
he said; he used diff. & axles from "2000 S280",
he also used propeller shaft rear one only (that attach to diff.),
cause S55 uses (4) fingers, while "S280" uses (3) fingers,
so many guys tell him to not use "S280" diff., cause i think it uses small carrier (210HAG), it will not handle the "S55K" tq/power,,
but he used the car around "3" years without any issues..
-;ZAYED;-
Old Apr 25, 2018 | 01:03 PM
cmpcpro's Avatar
2004 CLK 500
Thanks for the info! Unfortunately I have a Quaife installed in my rear diff so I want to keep my diff and find a ring and pinion to match.
Thanks again though!
