Occasional rough-running condition
Bill
Bill
maw
Lack of fuel will recover as soon as he is out of the throttle and leave codes for multiple random misfire or some such.
OP pull codes from the ECU. The flashing check engine light says that the ECU is aware of the problem and will have a treasure trove of useful data for diagnosis. Expect it to say which cylinder is misfiring.
If one cylinder is misfiring.... Swap ignition coils from the hole having a problem with a cylinder not having an issue. If the problem moves you know what to replace. Good opportunity to pull spark plugs to have a look and replace with fresh.
On my S55, he failing fuel pump was even more subtle. There would be periodic extended cranks before she would turn over. Every now and again, nothing constant or repeatable. I threw a crankshaft position sensor at it — no dice, same thing, still every now and again. This went on for years, but nothing to bother about. Then, I was driving the car, I hit the gas for acceleration and it sputtered and muttered, but kept running. Light fuel pressure was fine, and the car would cruise, but as soon as I put my foot into it, sputter and mutter. Lean condition, fuel pump. Changed it and filter, no problems since. So I’m just ruling out the things that it makes sense to do on yours, to isolate the fuel pump. New plugs and fuel filter never hurt, so I’m not advising against that. But from the beginning I suspect the fuel pump, based upon my experience.
GL and pleas keep us posted.
Cheers,
maw
maw
Bill
maw
I give that to you as added data, but the choice is still yours. I generally don't like throwing parts at cars, unless I have a really good idea about it. But I've observed over time that my guesses are as good as anyone else's, and a lot less painful than the stealership's learning on my dime. If the guess is going to be wrong, it's gonna be my guess (my car, my money), not someone else's.
GL, please keep us posted.
maw
maw
Random multiple misfire can easily be an issue with just about any and all.
Certainly before condemning a fuel pump I'd have OP hook up a gauge and drive it with that gauge clearly visible such that we can see 'while making multiple awful misfires fuel pressure is low.'
In my E-55 I got to deal with many issues of driving along... Load it up and it cuts the supercharger... Is misfiring... No check engine light. That was really annoying and got fixed with ultimately replacing all plugs, coils, wires + screwing around with coil connectors.
Does the TTbent eight use air mass meters or is it speed-density? E-55 and my 275 are speed density.
maw
Intermittent issues are are the most annoying of all! Currently the S-65 shuts Command off intermittently. Grrrr
Misfires in the E-55 were especially annoying. At first it did it..... Dead hole. No codes. Cycle key and it was fine for weeks to over a month. Predictably it got more consistent over time but was still unwilling to share it's secrets. Finally narrowed it down to a coil. Replace it... Month or so later another fails. Rinse repeat. Especially fun is when a new coil decides to make for yet another new/exciting drivability issue. Been there. Done that. Half of them never make a check engine light flash. It had to run really bad for that.
The point is, these cars do NOT like to run lean. Basic air, fuel and spark. If you have air and spark, then fuel delivery is probably the issue. The 65 cars were an anomaly, with coil packs and modules going bad. On everything else, if you've taken care of plugs and don't have pressure leaks, it's more likely the pumps. I haven't heard of any ECU issues on these.
maw
P.S. Unfortunately, these pumps look like they are in the tank. Brilliant.
