Voltage regulator replacement
Old Aug 11, 2020 | 10:29 PM
Renntech6509's Avatar
2014 ML350
Just putting out a feeler. Wondering if anyone here has replaced the alternator voltage regulator on the M275 engine without taking the alternator out? My lights have a slight flicker and my battery isn't charging fully. I've tracked the problem back to the voltage regulator but don't want to remove the alternator to get it done. Any help or advice is much appreciated.
Old Aug 13, 2020 | 02:57 PM
JohnLane's Avatar
222 S-65
OP I have yet to encounter an alternator that is not mostly used up by the time it needs a voltage regulator. I did not attempt removal of the regulator before pulling my alternator.
Old Aug 13, 2020 | 02:59 PM
whoover's Avatar
'19 E63S sedan
Second. There are lots of threads here that go, "I was sure a new voltage regulator would fix the problem, but after replacing it I discovered I needed a new alternator."
Old Aug 13, 2020 | 08:49 PM
2014 ML350
I was really trying to avoid pulling the alternator because it's water cooled and I just did a coolant flush a week ago. I figured I'd give the regulator a try and if not just pull the entire alternator. Car has 50k on it and I was hoping to get a little more out of the alternator.
Old Aug 16, 2020 | 02:36 AM
JohnLane's Avatar
222 S-65
So your car got the Maybach alternator. Interesting. My 2008 car got the air cooled alternator. It made it to 70,000 miles before deciding for me the radiator would be coming out to pull it. Pro-tip.... Engine mounts are pretty handy to do while the alternator is out... At least on the passenger side. They will be dead unless you've done them in the last year or so. My car is ready for them again. This will be the third set in 60,000 miles I've had it.
You will want a hug to go with the purchase of that liquid cooled alternator.
Best wishes.
Old Jan 31, 2024 | 06:39 PM
Patryk09's Avatar
Maybach 62
Hey did you ever figure it out?
Old Jan 31, 2024 | 09:21 PM
JohnLane's Avatar
222 S-65
He may have given up on the car after suffering heart failure at how many dollars are required to acquire that water cooled alternator.
Old Feb 1, 2024 | 12:14 PM
2014 ML350
Lol. I haven't given up on it. When I actually looked into it, I did indeed have the air cooled alternator. For some reason on the build sheet for my car it's listed as water cooled. But turns out the problem was a weak consumer battery. Replaced both batteries and haven't had any issues.
Old Feb 1, 2024 | 12:25 PM
JohnLane's Avatar
222 S-65
So you still have alternator failure to look forward to!
Glad it was an easy fix.... You are glad to have the air cooled alternator!
