Help with wheels
Looks like I made a mistake with offset, rears are +35 and they stood right even with the fender.
P.S. the touching side is the side where my vehicle drops sometimes due to hydraulic shock failure.
Any opinion appreciated!
When I bought my S55, I knew I'd have to replace the wheels. Some prior idiot put 20s on it, and an inch wider than stock, and then put stock width tires on it to get those flayed sidewalls. All four tires had fender-rub grooves in the sidewalls! I went to stock size 18s, found a set of actual AMG wheels for it.
"Stance" just isn't worth the safety issues of tire rub. That said, 19s or 20s are fine if you want the lower-profile tires, but they have to fit in the fenders.
- make sure u r using the correct bolts for the wheels .. some wheels will require another bolts to fit and if u used the stock ones then u will get a sound of metal grinding
- one more thing , 275 is the maximum u can do for the read tyres
OP has incorrectly sized rear wheels... wrong offset... period, end of story...
Let’s not muddle that story with uninformed opinion and guesses... I know this is the free internet and all, but damn!
The only real question in my mind is whether some 10mm spacers will help the wheels tuck in a bit. I often get confused on whether spacers make them tuck in or push out, because as a rule I won’t use spacers on my cars, for the reasons @wfooshee articulated... “stance” just isn’t that important... “correct” matters.
maw
Something is clearly wrong on the OP's car. Either the wheels are not a 35mm offset or the rear hubs have been replaced. Is it possible someone put S65 brakes on this car? If so the S65 rear hub requires a 60mm offset, unlike the S55.
maw
i'm using the S65 rims on my S55 for the past 2 years and the maximum i was able to go before i touch the body is 275 ... but my car is lowered 1.5 inch so the finder is almost at the tyres which could be the reason that i touch once im over an uneven road .
What I have done for sidewall protection, ride comfort, rear wheel hook up, etc., has been to go from 235/275 stock setup to 245/285. All I feel is a softer, slightly more rim protected, "bouncy" ride (play with the pressure to get rid of that bounce -- I keep mine in the middle of the recommended range, 36F, 39R, PSI when warm). Usually it's just me and some golf clubs in the car, but every now and then 2 or 4 adults + luggage for hours.
I thought about HRE, etc., but the forged factory 2-piece wheels are NLA now and look so perfect on the car I see no reason to change.
If you have 18" single piece wheels, I have no idea. Don't know if they're forged or what, or what sizes will work, nor do I have any experience with them. Sorry. Forged 2-piece pictured below. The offsets are different for the 65 cars but the tire sizes are the same.
Other than that, it appears all of your questions are answered above, post #5 especially.
GL
maw
f
Cheers,
maw
Regards Frank
maw
On the 55 that’s 245 out front... on the 65, that’s 255 out front... both are 285 out back.
A couple of thoughts:
(1) Michelin is running a mail in rebate which all but eliminates the pricing difference between their ultra High Performance All Season tire and Continental’s same category tire; and
(2) I just put 4 new Conti DWS ‘06+ on my 55 last month, and while I can’t honestly compare them to the DWS 06 that I took off (5 years old), or the last Michelin all season tire the car wore (over a decade ago), I can say they are grippy and compliant. I’ve been driving the car a little testy, getting used to a new supercharger pulley and tune combo with TCU tune, and I have to say, I’ve spent very little time thinking about tires or traction compared to prior years... seems I would be worried about the **** end driving like this in prior years (ABC Sport, ESP off, M shifting, 40* F sunny weather)... but these are holding their own. Of course, they’re likely to be 15k mile tires at this rate, but that’s the nature of these cars.
Hope this helps. Happy Easter,
maw
