S63 AMG 4MATIC Coupe, S65 AMG Coupe (C217), Convert. (A217) 2014 -2021
Lowered S63
Old May 23, 2017 | 02:45 PM
dappersclass's Avatar
2016 S63 AMG, 2007 S65 AMG
Lowered S63
Curious about suspension set ups for my 16 S63. I recently picked it up and got stage 1 tuned. Now that performance has been taken care of, I am considering addressing the cosmetics and ride height. Any suggestions? Thanks in advance gents
Old May 23, 2017 | 03:28 PM
3WD's Avatar
3WD
SPONSOR
Car
Hello,
We can offer you a BRABUS lowering module for your S63. Please PM us for pricing and details. Thank you!
Old May 24, 2017 | 11:02 AM
Heisenberg's Avatar
2020 S63 Coupe, 2006 Hummer H1 Alpha, 2018 McLaren 720S, 2022 Porsche 911 TurboS, 2022 Tesla Model X
I had the LoMo installed and have been very pleased with it. The front and rear ride height settings are independently adjustable. Driver and passenger wheels are always at identical and stable height, which was never the case with the old Renntech module I had in a CLS55. Settings are fully integrated into COMAND and adjusted using the steering wheel buttons; no extra hardware i.e. tablet is needed. It can also be bypassed which is useful for longer trips to reduce inner tire wear, on rough roads to maximize ride comfort, and of course dealership service visits to have the suspension at factory settings.
I typically drive with the module set at -3 front and -5 rear which gives the car a nice aggressive stance with most of the wheel gap eliminated, yet does not adversely affect ride quality or result in the bottomed-out ghetto look. It is probably about a 20-25mm drop.
Old May 24, 2017 | 02:12 PM
RENNtechHQ's Avatar
Former Vendor of MBWorld
Mercedes-AMG
We recently launched our all new lowering module which utilizes the OBD2 port and takes just seconds to lower/modify the vehicles ride height. Simple plug-n-play solution with full adjust-ability using either Windows or Android OS devices.
Check out our website for more info:
http://www.renntechmercedes.com/inde...-sclass-detail
Additional S-Coupe products:
http://www.renntechmercedes.com/inde...iturbo-4-matic
Old May 25, 2017 | 11:01 AM
Thanks for the input guys! I will check into those options. Anyone go full air ride?
Old May 25, 2017 | 11:58 AM
getmercd's Avatar
Mercedes Benz C43 AMG
I have considered going air ride on my C43 but I was told that no one makes a kit for the W205 4matic. Not sure if that applies to the S-Class as well, but worth taking note of. Good luck with the car!
Old May 28, 2017 | 08:19 PM
Manofsteelpt's Avatar
Veteran: Army
S63
I've been looking into an ELM Afro my S63. LoMo seems the best option, as Heisenberg stated, fully adjustable through the steering wheel.
I inquired about Renntechs version too. Need the tablet or connect to PC to adjust height. The worst part is, the unit is married to YOUR car. So, if u wanna remove it and sell it, or put it on a different car you can't. UNLESS, you send it back to them to reprogram for $750. Technically, I was quoted 50% of the cost of the unit.
Old Sep 21, 2017 | 11:18 PM
COOPERDB's Avatar
NB8 PARACHUTE
When you have time could you post a couple
a couple of pictures with the coupe at the
above settings - with one side shot taken
standing up - at my height I don't get down
to the ground level shots that often
Also - I may have missed it if you posted
regarding the updated rear brake pad wear
Are you still getting dust on the rear wheels
Thank-You
D.B.
Old Sep 25, 2017 | 05:51 AM
Heisenberg's Avatar
Thank-You
D.B.
Here are a few pics with the LoMo set at -3 front, -5 rear. This gives the same wheel-fender gap front and back. Visually I cannot see any obvious difference in camber.
The OEM Conti 5P tires lasted 8k miles before the outer tread was completely worn. The inner tread was worn too, but less so. The center tread was hardly worn. This wear pattern is typically the result of underinflation, rather than excessive camber. In fact, any further negative camber from the LoMo might have helped! The rear tires, interestingly, showed considerably less and more uniform wear, they had plenty of miles left. I had used the cold psi recommended in the owner manual, i.e. listed on the fuel door placard.
I just had the Conti 5P replaced with Michelin PS4. Despite the guidance in the owner manual and on the fuel door placard, I was advised to keep the cold tire pressure near 50 psi, as listed for max load on the driver door placard, for best tire life. Unfortunately this really detracts from ride comfort, not to mention lots of new vibrations and rattle noises in the cabin. So I will have to try to find a good compromise between ride quality and tire life.
I still have significantly more brake dust on the rear than the front, and rear brakes still get hotter too. Dealer found nothing amiss during recent service, so I assume it is related to the EBFD system as you had suggested before. It is just weird because it was the exactly opposite on my previous 2014 CLS63-S.
Attached Thumbnails Lowered S63-img_0026.jpg   Lowered S63-img_8513.jpg   Lowered S63-img_0027.jpg   Lowered S63-img_0785.jpg   Lowered S63-img_0024.jpg
Old Sep 25, 2017 | 02:36 PM
COOPERDB's Avatar
NB8 PARACHUTE
This looks incredible
As for the tyre wear I have a friend
who has a C217 - almost a year now
He drives in S mode all the time and
has no irregular tyre wear
I have also asked several C217 owners
about this when I see them at the store
All but one owner are experiencing the
same tyre wear as you
AMG might need to take a long look at
the design as something is not right
As for the brake pads - when they need
replacing you might try Akebono pads
On the BMW 7 series they leave no dust
Thank-You
D.B.
Old Sep 25, 2017 | 06:11 PM
Heisenberg's Avatar
At the psi recommended on the fuel door placard, my front tires ~ 40 psi cold lost all tread at the margins (inner < outer) by 8,000 miles. The rear tire obviously held up much better. See photos below.
WSI in Tempe suggested cold pressure near 50 psi to get better tire life. That sure detracts from the ride quality so will have to find a compromise between comfort and tread life. The rear tires were run in the low-mid 30 psi range with acceptable wear, so it seems to be an issue with how AMG configures front suspension. I will get an alignment done but I believe there is only factory adjustability for toe.
I've had premature wear problems with the Conti 5P in the past, so it may have something to do with the tires themselves. Michelin Pilot Sport 2 and Vredestein Ultrac Vorti both held up far better on my previous AMG CLS cars compared with the OEM Continentals.
I used Porterfield RS-4 low dust brake pads, might try the Akebono next time. I get little dust up front, but a decent amount on the rears. If I end up trading this in for a new S63 (not certain that makes much sense given the changes) I will definitely opt for the ceramic brakes.
Old Sep 26, 2017 | 12:30 AM
COOPERDB's Avatar
NB8 PARACHUTE
When you get an alignment done I would
look into going where they put weights in
to match the drivers / passengers weight
Food for thought
Thank-You
D.B.
Old Sep 26, 2017 | 01:10 AM
COOPERDB's Avatar
NB8 PARACHUTE
This shows the amount of weight
BMW recommends for their big body
cars with placement when getting
an alignment
Thank-You
D.B.
Old Oct 13, 2017 | 11:37 AM
TurboBmaNN's Avatar
2018 S63 AMG
Can't say enough good things about - https://www.ghostmotorsports.com/ghost-links/bmw.html
I haven't created an album yet of my new S63 coupe.. but you can see some random pics here - https://www.instagram.com/bmaczuga/
PM me if you have any questions about them. Glad to help. (I am not affiliated with Ghost Links, just love their product)
Old Dec 5, 2017 | 11:26 AM
TurboBmaNN's Avatar
2018 S63 AMG
Old Feb 6, 2018 | 06:16 PM
sattman's Avatar
2016 S550 coupe and 2018 AMG GTR
car looks great, i too have ghost links and love them.
Old Apr 8, 2018 | 06:38 PM
SkforzaGroup's Avatar
S63
Anyone having any issues with the rear suspension rattling? The rear passenger side has a weird small rattle when going over multiple bumps.
Old May 19, 2018 | 03:50 PM
barryrobinson19's Avatar
2016 Mercedes S63 4matic sedan
I bought the lowering module that plugs into the OBD2 port. Has stock program, low program pre loaded, and custom program, where you can lower or raise the car to what you want. All this is done through the dash screen (the one on the right). Very easy to use and you need no tools. Just plug it in and go. Here are some photos.
Old Apr 8, 2019 | 05:34 AM
Adi Toma's Avatar
s63 amg coupe
where from?
thanks!
Old Apr 10, 2019 | 01:09 PM
S63
Amazon !
Old Apr 18, 2019 | 07:12 AM
Adi Toma's Avatar
s63 amg coupe
would you be so kind to give me the name of the manufacturer? or a link? anything to start the search with?
thanks!
Old Apr 18, 2019 | 01:09 PM
sattman's Avatar
he didn't give much to go on, but i found this.
https://www.ebay.com/itm/MERCEDES-BE...frcectupt=true
Old Apr 19, 2019 | 09:02 AM
Adi Toma's Avatar
s63 amg coupe
yes , thank you, i got them also, already talked to them but i was interested in the one that SkforzaGroup because he is the confirmation that it works and he is happy about it
cheers!
