S63 AMG 4MATIC Coupe, S65 AMG Coupe (C217), Convert. (A217) 2014 -2021
MB OEM Trickle Charger
Old Jun 2, 2018 | 11:49 AM
chrislambros's Avatar
'22 e450 Cabriolet
I have a '17 S63 Cabriolet .. there is a charging cable included with the vehicle. It appears to be MB specific. Can anyone recommend a compatible trickle charger (OEM or otherwise) ??
Old Jun 3, 2018 | 09:30 AM
jbattan's Avatar
2023 Mercedes EQS 580 SUV, 2023 Bentley Bentayga, 2023 Genesis GV60
Mine came with the charger and cable. MB branded, but the CTEK brand looks similar.
Old Jun 4, 2018 | 04:48 AM
BillyD's Avatar
'12 R197, '17 S63A4, '13 CLS4M, '99 A208 320CLK'99 CLK320A
OEM Charger
As stated above, the MB OEM charger is made by CTEK, but with a non-standard connector to your charging cable. If you purchased the car new, the MB charger is standard and you should have received one. If not, I'm afraid that you may have to purchase the charger from the MB parts department due to the unique connector to mate with your charging cable.
Hope this helps.
Bill
Old Jan 1, 2019 | 09:22 AM
badbenzz's Avatar
AMG GTS, Ford Raptor and Tesla Model 3 dual motor
Where is the charging cable located?
Old Jan 1, 2019 | 10:55 AM
BillyD's Avatar
When the car is purchased new a charger and charger cable are included in the delivery in a cardboard box.
The charging socket is located in the trunk on the driver's side near the trunk lid opening.
Hope this helps.
Old Jan 2, 2019 | 12:56 AM
badbenzz's Avatar
Hope this helps.
Thank you, now I just have to find the charger that fits the connection
Old Jan 2, 2019 | 11:07 AM
BillyD's Avatar
The charger part # is A 000 982 29 21
The "connecting" cable is NOT included. It's part # is A 217 583 00 00.
Good hunting.
Hope this helps.
Old Jan 6, 2019 | 04:22 AM
DrumdudeAMG's Avatar
2012 E63 AMG Wagon
Hope this helps.
Do you know if there was such a 'socket' for the E63 Wagon?
Also - I've had one of these (CTEK (56-158) MULTI US 3300 12 Volt Fully Automatic 4 Step Battery Charger) on my ZO6 Vette for 9 years or so, using the extension cable that mounts above the rear license plate, up where the plate lights and trunk release are for a quick plug in solution - and it works flawlessly. I'm trying to understand what the difference is between this unit and the MB one, besides a more than THREE TIMES the cost difference? Is there something with the voltage, or??
I can't imagine a cable would equate to that much of a
price difference... Thoughts? Thanks in advance for any knowledge to share!
Old Jan 6, 2019 | 10:01 PM
BillyD's Avatar
Sorry, I have no idea if the E63 wagon has such a charging socket (port).
It's clear that the MB version of the CTEK charger deliberately has a different connector (to the MB final cable into the socket) than a standard CTEK charger.
I believe that it is simply for revenue purposes. To be fair, the cable and charger are included with the sale of the (new) car. They also did this on my '16 AMG GTS.
Hope this helps.
Old Jan 6, 2019 | 10:49 PM
badbenzz's Avatar
Good hunting.
Hope this helps.
Thanks all good now
Old Jan 24, 2020 | 04:19 PM
Heisenberg's Avatar
2020 S63 Coupe, 2006 Hummer H1 Alpha, 2018 McLaren 720S, 2022 Porsche 911 TurboS, 2022 Tesla Model X
Reviving an old thread here... anyone know if the 2018-2020 S63 are supposed to come with a battery charger ? My 2020 did not. I have the outlet in the trunk just like my 2015, but at least on that car it could not be used for charging as it was switched to the ignition. At least the 2019 manual says to for cars with lithium batteries (i.e. S63) to jump or charge using posts in the engine bay.
I have CTEK 4.3 amp and (McLaren-branded) 7 amp lithium battery chargers on hand, with the clip attachment for the engine compartment posts. At least the negative post is out in the open now, on my 2015 it was hidden under a plastic cover.
Old Jan 26, 2020 | 03:01 PM
Heisenberg's Avatar
Can someone post a photo of that 217 583 00 00 charging cable ?
Tried to plug by CTEK Lithium US into the S63 socket with the cigarette plug adapter I use on the 720S (which looks same as in the photo below). As expected it doesn't charge unless the car is running - the trunk 12v socket is switched to the ignition. Doubt the M-B cable is any different - other than costing 10x as much as the CTEK - but if it somehow enables charging via that trunk socket would be nice as it's a pain to pop the hood and attach the alligator clips on the jump start terminals.
Old Jan 26, 2020 | 03:17 PM
COOPERDB's Avatar
NB8 PARACHUTE
I am going to the dealership tomorrow
to pick-up some parts and I will inquire
about the charger coming with the MY20 Coupe -
Thank-You
D.B.
Old Jan 26, 2020 | 06:11 PM
Heisenberg's Avatar
Thank-You
D.B.
Thank you @COOPERDB
Not aware of anyone getting a charger with their S63. The part# A 000 982 29 21 referenced above is for a 5A lead-acid charger, almost certainly manufactured for M-B by CTEK, and is not suitable for the LiFePo4 battery in the S63 (at least in the coupe). CTEK Lithium US is the correct model for these batteries and runs $95 on Amazon, and includes the alligator clips needed to connect with the exposed terminals in the engine compartment. It does not include the 12v plug adapter, but that can be purchased separately for $10... though as I mentioned the trunk 12v plug is switched to the ignition so not usable for charging.
My 720S charges via that 12v plug which is in the frunk right in front of the LiFePO4 battery. Car came with a McLaren-branded 7A Lithium charger clearly manufactured by CTEK.
Old Jan 26, 2020 | 07:01 PM
Igor Sakhnov's Avatar
2025 GLE63s
Didn't get a charger with my 2020
Old Jan 27, 2020 | 08:04 AM
HAWKiS63's Avatar
S63 AMG Cabrio
I ordered it together with the car from factory (code 675, Euro 110, ex VAT) . Has a strange connector, but it works.
It does NOT look like on the picture in the pricelist however:
Old Jan 27, 2020 | 10:37 AM
BERNIE's Avatar
S63 AMG Coupe 2020
same as the one for AMG GTS modèle 2016
Very efficient
I plug it during winter permanently. In spring the car start from first key turn !
Old Jan 27, 2020 | 12:12 PM
coolcamden's Avatar
2021 E63S Wagon 2019 S63 AMG Coupé 2015 S Coupé Edition 1 1970 Chevelle LS5
Didn’t get a charger with 2019 either.
Old Jan 28, 2020 | 12:19 AM
COOPERDB's Avatar
NB8 PARACHUTE
HEISENBERG -
At the dealership today I was told by a salesman - the service manager
and the parts manager that the chargers no longer come standard
with the S classes -
However they are available for order / purchase from parts -
Just another issue that shows how Mercedes is re-defining
THE BEST or NOTHING to suit their bottom line -
Thank-You
D.B.
Old Mar 20, 2021 | 03:35 PM
Vladimir_S63's Avatar
S63 AMG cabriolet 2017
Seems I am having the same problem with my '17 S63 cabriolet. The plug on the left in the trunk is different from the original Mercedes CTEK charger I bought. Even without the end (there's a connection in the middle) it does not fit.
It just has these plugs but not the one on the left and the cigarette plug on the right does not work.
Anyone please figured out the type of cable that fits the socket and can be purchased? All help highly appreciated.
Old Mar 20, 2021 | 03:46 PM
BillyD's Avatar
The Cable you need is Mercedes part # A217 583 00 00. You can sometimes find it on EBay for around $60.00.
Hope this helps.
Bill
Old Mar 20, 2021 | 03:57 PM
Thank you, Bill! I just can't find the picture of the cable anywhere, so I am little worried about getting the same thing (cigarette lighter connection) that I already have. Don't you please have a picture of that?
Old Mar 20, 2021 | 04:26 PM
BillyD's Avatar
Sorry, No. If you just use the part number I sent you - you can't make a mistake. All the best.
Old Mar 20, 2021 | 04:30 PM
I will try that. Thank you!
Old Feb 27, 2022 | 03:37 PM
2025 GLE63s
Reviving this old thread - what is the guidance on a trickle charger to get that would work for 20 S63?
