S63 AMG 4MATIC Coupe, S65 AMG Coupe (C217), Convert. (A217) 2014 -2021
s65 lithium ion battery cost
Old Jan 8, 2021 | 09:52 AM
gamepoint's Avatar
S65 amg coupe
My 2015 S65 with 20,000 miles just randomly died with no power and had to be towed to the dealer. Dealer states that the lithium ion battery in the trunk is not holding a charge and replacement cost for parts and labor is $2500. Does that sound accurate? Can I get it done cheaper? Sounds excessive for a battery. Any help is appreciated.
Old Jan 8, 2021 | 11:40 AM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
Yes. There is no aftermarket option or replacement. Battery is a little over $2,000 if I recall correctly
Old Jan 9, 2021 | 08:47 AM
gamepoint's Avatar
S65 amg coupe
Thanks, I told the dealer to go ahead as I have no choice but what a steep price for a battery. I just hope that all the other electronics work appropriately as the car had gone completely dead. It’s still under CPO warranty and I was hoping that they would help a little bit but they didn’t .
Maybe the Time for trade in is approaching if the future costs for repairs is going to be this high once warranty runs out in 1 year.
thanks for your answer
Old Jan 9, 2021 | 08:51 AM
gamepoint's Avatar
S65 amg coupe
Obviously the question is what do you buy after having a car like this? Not many options .
Old Jan 9, 2021 | 09:03 AM
places's Avatar
No more MB:(
That's right, where do you go? You're at the top of the heap.
Old Jan 9, 2021 | 04:48 PM
Normg's Avatar
2016 S63 AMG
Was this the original battery?
I'm asking because I am looking for some way to predict the need for a new battery before mine expires and requires towing.
Norm
Old Jan 9, 2021 | 05:11 PM
gamepoint's Avatar
S65 amg coupe
Original battery, no warning, sudden death
Old Jan 9, 2021 | 05:28 PM
Normg's Avatar
2016 S63 AMG
Thanks....
The dealer advised my battery was replaced last year (2016 S63 with currently 16K miles)
Anybody used a battery maintainer?
I have the MB model (rebranded Ctek) but have not installed it yet. Based on the operator's manual it looks like I need a specific 12 v socket to plug in to. Apparently the factory socket in the trunk is an "accessory socket" and requires the ignition to be on. Good for operating the 12 v air pump provided but not a battery maintainer. Looks like the W263 and SLR are the only MB equipped with a suitable 12 v socket from the factory.
I will be at the dealer Tuesday to install and address a few other small issues...
Norm
Old Jan 11, 2021 | 10:38 AM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
Its a $225,000 vehicle of course maintenance and repair costs will be high, but proportionally it is no higher than an average $30,000 honda for 95% of repairs that will/may be needed.
Old Jan 12, 2021 | 07:49 PM
amir1's Avatar
2019 S65 Coupe, 2017 S650 Maybach Convertible, 2020 S560 Sedan, 2022 Porsche 911 Turbo S
I purchased the MB chargers for my 2019 S65 coupe and Maybach S650 Convertible from the dealer. I think they were $130 each. From what the instructions stated, you plug them into the accessory plug in the trunk, but then need to hold down the button on the charger for about 15 seconds until one of the lights on the charger flashes a few times. Then, its charging. If i'm wrong, i'm in for a new battery.
Old Jan 12, 2021 | 08:58 PM
Normg's Avatar
2016 S63 AMG
Thank you for posting!
Today the dealer confirmed that the socket in the trunk is an accessory outlet and not suitable for the battery maintainer. The maintainer operating manual advises that only the W263 (G Wagon) and SLR have trunk sockets that are suitable for using a battery maintainer. Take a look at your maintainer manual (I think page 4) where it advises that a socket needs to be installed to use the male lighter plug except for the two models mentioned. It clearly does not advise that you can plug the maintainer into any accessory socket.
I admit that I have read other reports of people using their trunk outlet. If it works for you, I am glad but continue to be confused by what "experts" have told me.
I was also told that the lithium battery is better at holding a charge than the lead acid type battery and that I should not expect the same poor performance that I experienced with the consumer battery in my SL 550.
When I inquired about signs of a failing battery like "gamepoint" experienced I was told that if I start to sense a "slow" start or see a battery warning light flash, I should plan on a visit to the dealership.
Norm
Old Jan 31, 2021 | 01:27 PM
amir1's Avatar
I took the S65 Coupe to the dealer and it turns out that the accessory plug in the trunk is NOT suitable for plugging in the charger. The charger only works if there is a current coming to the accessory plug when the car is turned off, which there isn't. So I had the charger hard wired to the positive and negative connecting points in the engine bay and left there a small tail with a quick connect plug for the charger. Those connecting points have a constant current regardless of whether the car is on or turned off.
Old Jan 31, 2021 | 03:23 PM
Normg's Avatar
2016 S63 AMG
Glad to hear the confirmation on the connection.
My dealer rewired the existing socket in the trunk, adding a separate in line fuse mounted on the left side of the fuse panel located in the trunk (right near the factory socket) so my trunk socket is now connected directly to the battery.
Now if I could just figure out if the "reset" button needs to be pushed every time I use the maintainer. I pushed it the first time I used it but now the lights come on when I plug it in, so I am wondering if the unit has a "memory" that recognizes the lithium battery after that first use.
Norm
