S63 AMG 4MATIC Coupe, S65 AMG Coupe (C217), Convert. (A217) 2014 -2021
2015 S63 Coupe Porterfield Rear Brake Pads
Old Oct 13, 2024 | 11:29 PM
nys29's Avatar
2015 S63 Coupe, W221 2010 S300
Rear pads are due soon and the current stock pads are producing way too much brake dust. Looking to switch to an aftermarket option. From what I read, people are recommending the Porterfield R4S. Also trying to figure out the exact part number for the Porterfields.
Old Oct 14, 2024 | 03:30 PM
xabo's Avatar
'20 S63
https://porterfield-brakes.com/searc...ufacturer=7444
Old Oct 20, 2024 | 04:10 AM
nys29's Avatar
Some people are recommending the Powerstop Z23/26 as well. Is Porterfield or Powestop better?
Old Oct 22, 2024 | 08:13 PM
The Truth's Avatar
2015 S63 & 2014 ML350
I'll be going with the Powerstops as well in a few weeks.
Old Oct 22, 2024 | 08:50 PM
nys29's Avatar
Keep me updated! Let me know how it is
Old Nov 10, 2024 | 03:18 PM
pomchal's Avatar
2015 S63 AMG Coupe, 2003 CLK500, 1986 TVR 280i
Hi everyone,
I'm a newbie to this forum. So pardon the dumb question. Do you guys change rotors every time you change pads?
I measured the front rotor and it's 24mm thick and I see a lip at the outer edge of the rotor.
I typically change rotors with pads on my cars. This is the first time changing pads on my 2015 S63. I picked it up about a year and a half ago with 16K miles on it. It now has 26k miles. I actually drive it ;-)
Cheers,
MO
2015 S63 Coupe
2004 Infiniti FX35
2003 CLK500 Coupe
1986 TVR 280i
Old Nov 10, 2024 | 07:05 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
It seems like these cars burn the rears up faster than the front. I think they have alot of rear bias. As a rule of thumb, I would figure 2 sets of pads before the rotors. But go by your min thickness stamped on the rotor.
Old Nov 10, 2024 | 09:22 PM
nys29's Avatar
So, I just checked and my rotors are still above minimum spec, and not grooved. However, when I run my finger from the inner to the outer part of the rotor, it feels wavy. Is that normal, or should I replace my rotors as well?
Old Nov 10, 2024 | 09:55 PM
okbarnett's Avatar
its against the rules but Im going to turn my rotors to smooth them out. Before I am going to buy new ones. They may last 5 or 10k miles longer.
Old Nov 11, 2024 | 01:15 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
I put Powerstop Z23/Z26 on my 18 S63 sedan this past summer. I also changed the rear rotors to the Zimmerman rotors but kept front rotors since they were changed a year ago. Stopping power is exactly the same and brake pedal feel is also the same. I now have what I would say is ZERO brake dust. I was expecting a 90% improvement, but my results have far exceeded my expectations. Z26 pads on the front and I get less brake dust on the front than the rear. OEM machined 10 spoke forged wheels. The difference is like night and day since changin in June/July of this year.
Old Nov 17, 2024 | 09:32 AM
JohnLane's Avatar
222 S-65
Carlos are the Powerstop pads making for rotor wear as we see with OEM pads?
Old Nov 17, 2024 | 10:50 PM
nys29's Avatar
I am in the process of installing Powerstop z23 rear brake pads on my car. However, I noticed that all 4 pads do not have the hole for the brake pad sensor to go in, unlike the original mercedes pads. Am I doing something wrong? Pads are Z23-1669
Old Nov 18, 2024 | 11:15 AM
Top Answer: 1
You're totally fine. There's only 1 front sensor and 1 rear sensor. Funnty thing is I've been working on cars for 40+ years and I have to remind myself of this every time I do a brake job.
Old Nov 18, 2024 | 11:22 AM
Top Answer: 1
Yes!! There's a really good informative but boring video on Youtube that talks about how brake pads and rotors react with each other. That iterface determines so much that goes on that is never talked about. In a nutshell, under braking, the brake pads lay down a coating on the rotor, and this coating is what determines everything between the pad and rotor; sound, wear, heat dissipation, off gassing, etc. Carbon ceramic pads lay down a coating that leads to far less rotor wear than metallic or OEM type pads. Prior to learning about this, I always thought brake dust was from the pads, but in reality 90% or more of brake dust is from the rotors. Most of the material from the pads is burned away as gas. That why when you combine a Carbon Ceramic pad with a Carbon ceramic rotor you get so little rotor wear.
Old Nov 18, 2024 | 12:47 PM
nys29's Avatar
What I mean is none of the pads that I got for the rears had the hole for the sensor. Therefore, I can’t install the rear sensors.
Old Nov 19, 2024 | 06:19 PM
Top Answer: 1
If you have CCB's then just a rear sensor, if you have regular AMG brakes then there should be a sensor for front and rear. They must have packed the box incorrectly, forgot to include a pad with the notch for the sensor.
Old Nov 22, 2024 | 01:40 AM
zk2004mb's Avatar
S63 Coupe
Originally Posted by pomchal
Hi everyone,
Cheers,
MO
2015 S63 Coupe
2004 Infiniti FX35
2003 CLK500 Coupe
1986 TVR 280i
Are you talking about rear rotors? 24mm can't be the front thickness. The rear one is 26mm new and 24mm is the minimum. Yes you need to change it. Go with brembo 09B87911
As for front, the new thickness is 36mm and 33mm is minimum. Go with brembo 09931333, better than oem, 2 piece floating design, lighter, cheaper and looks way better.
Old Nov 26, 2024 | 03:34 PM
nys29's Avatar
So I reordered them and this time it came with the hole for the sensor. I guess the previous one I got was defective and they forgot to drill a hole for the sensor. The previous one has a manufacturing date of 2020, and the newer ones I got are from 2024.
Old Feb 1, 2025 | 08:55 PM
villain666's Avatar
2016 s63 coupe- renntech R1-capristo exhaust
Brembo 09931333 front rotors
how are the brembo 09931333 front rotors holding up?
Old Feb 1, 2025 | 09:50 PM
The Truth's Avatar
I've had the power stops on for about a month now and I have zero brake dust. Could not be happier.
Old Feb 2, 2025 | 03:33 PM
villain666's Avatar
Word. I got mine put on today. Hopefully I have the same results. 👍🏾
Old Feb 2, 2025 | 05:56 PM
pomchal's Avatar
Brembos all around.
I installed Bembos disc all around with Genuine MB pads on my 2015 S63 coupe.
i am very happy with results.
Dealer quoted me $13.8k !
I have done brakes on all my cars for 30 years. This estimate from the dealer was the highest I have ever seen (I’ve had a number of v8s and biturbo V8 MBs).
by the way, I have not had good experience with aftermarket pads. Many have not fit exactly right. So, I always use original equipment pads and have never had any issues.
