S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
19 S560 - DIY oil change what to use?
Old May 6, 2025 | 12:14 AM
apollo18's Avatar
C63
hey all i got a 19 s560, i heard on mercedes people usually mityvac it but maybe not the case on our vehicle or am i mistaken?
regardless what oil change parts people are running for there vehicles, fully oem from mb dealer or any aftermarket oil or filters ?
thanks!
Old May 6, 2025 | 08:45 AM
W205C43PFL's Avatar
thanks!
Use oem filter. Oil you could get mobil1, motul, amsoil, Pennzoil, liqui moly, etc. That meets mb approval 229.5
Old May 6, 2025 | 08:46 AM
W205C43PFL's Avatar
https://operatingfluids.mercedes-benz.com/sheet/229.5
Old May 6, 2025 | 08:48 AM
W205C43PFL's Avatar
Oil filter part number 1761800800
Old May 6, 2025 | 08:49 AM
W205C43PFL's Avatar
Buy it here https://mbparts.mbusa.com/oem-parts/...ent-1761800800
Old May 6, 2025 | 08:51 AM
chassis's Avatar
2017 GLE350 4MATIC
Use MB compliant oil as noted above.
I bottom drain, it’s easy and gets all the oil out.
I use the cheapest store brand oil filter I can find in a Porsche and get excellent Blackstone results on 5k-6k mile oil change intervals.
Change the oil every 5k-6k miles.
Old May 6, 2025 | 07:57 PM
apollo18's Avatar
C63
awesome thanks, r u reusing drain plug / crush washer? ty
Old May 6, 2025 | 07:58 PM
W205C43PFL's Avatar
If it is copper, you could probably reuse it once, if plastic, just replace it. If you are worried, replace it regardless of copper or plastic.
Old May 6, 2025 | 07:59 PM
apollo18's Avatar
C63
awesome thanks, r u reusing drain plug / crush washer? thanks
Old May 7, 2025 | 06:30 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
https://alphaeuropean.myamsoil.com/
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old May 7, 2025 | 11:18 AM
justchangeoil63's Avatar
2019 Mercedes S560
When I’m doing work to the car myself I get all the parts from FCP Euro. Go online and make an account with your car info and it should pop up everything you need. If you need help you can call and they will help you choose the parts.
I just did a oil change at 55k miles with OE parts and liqui Molly Oil (some ppl are very pressed about what oil you use, as long as it’s from a reputable brand and you change your oil frequently and on time you should be ok). Remember to get a new metal gasket for the oil drain plug!!
Also just used them to get OEM brakes (rotors and pads) all around. Parts came super fast and everything they sell somehow has a lifetime warranty (that they will honor!).
Old May 7, 2025 | 03:07 PM
W205C43PFL's Avatar
Could also get one of their oil change kits.
Old May 7, 2025 | 03:08 PM
W205C43PFL's Avatar
You're welcome : ) I change it every time. We have a different car and engine though.
