Euro spec taillights with dynamic signal x290
Old Nov 4, 2021 | 02:46 AM
AMGGT63S's Avatar
AMG GT63S
installed a pair of Euro spec tail lights with dynamic/sequential signals. Can supply taillights and install instructions.
Old Nov 8, 2021 | 10:03 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Looks good!
Old Nov 12, 2021 | 04:26 PM
AMGGT63S's Avatar
AMG GT63S
Thanks!!
Old Dec 2, 2021 | 01:34 AM
Nik640's Avatar
‘22 G63 ‘23 G63 4x4
Can you send me more info please?
Old Dec 5, 2021 | 04:24 AM
AMGGT63S's Avatar
AMG GT63S
ill have to dig out the info. You'll need euro spec tail lights, run two wires to the rear same and some coding. For the coding i didnt do it myself. I paid someone to do it and he couldnt share that with me. I got the software and i am going to find a way of how he did it. it took him 5 minutes. The bulk of the cost is removing the rear bumper and installing the tail lights.
Old Dec 7, 2021 | 02:21 AM
Nik640's Avatar
‘22 G63 ‘23 G63 4x4
You don’t have the part numbers for them do you? I need to pull my taillights anyways cause I was going to get them smoked. Did you run new wires and tap into some empty pin slots on the SAM also where is the SAM located? Apologies for all the questions.
Old Dec 10, 2021 | 10:20 PM
AMGGT63S's Avatar
AMG GT63S
Part number is
A2909060100/0200
you’ll have to run a wire from each light to the rear SAM. It’s located in the trunk right side. You’ll need to removed everything in the Trunk as well as the rear bumper.
Old Dec 11, 2021 | 02:41 PM
Nik640's Avatar
‘22 G63 ‘23 G63 4x4
Right on thanks for the part #s. You don’t to have any pics from when you did the wiring do you?
Old Dec 17, 2021 | 09:29 PM
AMGGT63S's Avatar
AMG GT63S
Ill have to dig in my files and get you the wiring diagram. Here’s a couple from my phone. HECK L/R is where the signals connect to with the yellow wire. I used the same yellow wire to connect into the plug. I have to get the electrical diagram to tell you what pin.
i did all this in the summer. I don’t want to give you the wrong info and confuse you further.
Old Dec 17, 2021 | 09:32 PM
AMGGT63S's Avatar
AMG GT63S
this the plug for the tail lights where you’ll have to run the yellow wire from the Sam to each taillight.
Old Dec 17, 2021 | 10:45 PM
AMGGT63S's Avatar
AMG GT63S
Old Dec 17, 2021 | 10:49 PM
AMGGT63S's Avatar
AMG GT63S
left tail e3 pin 3 and pin 3 in heck L
right tail e4 pin 3 and heck R pin 12
before you put everything back to together, test it to make sure the connection is correct. It will work even before coding it. Only thing is the brake light will flash. After coding the amber will flash. Hope this helps!
