Coilover conversion SWAY / Torsion Bars DY
Old Mar 3, 2017 | 02:14 PM
pmercury's Avatar
member
CL
Lightbulb Coilover conversion SWAY / Torsion Bars DY
So, I don't have much time
I have been driving without torsion bars for a while with Yellow coil-over suspension
it was ok, not bad at all, but I wanted to make it better
THIS IS FOR A 2003 CL600
I am saying this because on my subframe, I had the place to bolt on the torsion bar ready on my subframe
all you need is to remove the ABC crap on those two locations and you can bolt on the fantastic sway bar from a W220
The ride will be 95% as good as ABC
here pictures and part list
good luck
Control Arms left and right
A2203308907
A2203309007
many aftermarket company's make these, don't be silly and buy them from mercedes
second hand complete torsion bar
A2203232565
Bushing Brackets x2 (and you need the two bolts)
A2203230040
result:
remarks:
don't forget to buy the two bolts and nuts
it looks difficult to get behind the subframe to hold the nuts but it isn't
your fingers will go there
buy the sway bar second hand from ebay
hundreds there !
Also, the replacement lower arms have the lower end of the springs connecting more outside, that increases the firmness of the coil-overs !
update
After a 2 years experiencing, you must add this mod to make it perfect:
new control arms mod
you won't regret this !
Read my posts before you go into the wrong direction with DAS / Xentry Diagnostics
__________________________________________________ ___________________________
Want to talk live ? Please install Skype and hit the little S (skype button) under my Username or just PM me
Old Mar 3, 2017 | 03:22 PM
biker349's Avatar
cl600
good info.
thanks
Old Mar 3, 2017 | 03:42 PM
tusabes's Avatar
Mercedes
Thanks for the details !!
When buying aftermarket control arms , buy lemfoerder or genuine Mercedes oem
The eBay supplier like Hamburg technic or URO are not good
Old Mar 4, 2017 | 07:30 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
I wonder if this could done on a V12 SL?
Old Mar 5, 2017 | 02:36 AM
tusabes's Avatar
Mercedes
Yes but you need pricey sl65 black series parts
They didn't have abc and used struts
Old Mar 6, 2017 | 07:20 AM
pmercury's Avatar
member
CL
here is a picture where the torsion bar mounts
as I said, just remove all the stuff bolted there to free the area
Old Mar 6, 2017 | 11:35 AM
Ste73's Avatar
Mercedes cl500 2000
Did you have to use flat top yellowspeed front coilovers or do the slanted top ones bend out that extra bit onto w220 arms? I'm interested in this as it's pretty easy to do this unless I have to fit flat top mounts to send the lower of Strut out to match 220 lower arms...
Old Mar 6, 2017 | 11:40 AM
Ste73's Avatar
Mercedes cl500 2000
The Cl 500 also has these subframe mounts, I haven't encountered much body roll but the 600 has probably got more nose weight. Only concern I have noticed is a bit of bobbing at speed but if I add more rebound it cures it but makes it a bit harsh at lower speed. ARB won't solve that but if it's an easy mod I may as well do it.
Old Mar 6, 2017 | 12:47 PM
pmercury's Avatar
member
CL
Well, I ordered yello coilovers for slanted but what they send me had flat tops, maybe they ask that just for the size as I called them and they said it was ok
whatever, yes it bends fine, position is fine
Old Mar 6, 2017 | 12:50 PM
pmercury's Avatar
member
CL
I don't want to convince you but really, it is really much better !
Old Mar 10, 2017 | 12:24 PM
Ste73's Avatar
Mercedes cl500 2000
Yes I'm thinking about it now, it was always a big wallowing cruiser before but since the coilovers it definitely feels more like a large sports car so I'm interested in making it handle well. I'm on 26 clicks front & 22 rear now on the damping. I find it's more fun to drive fast since conversion.
Old Mar 10, 2017 | 12:33 PM
Ste73's Avatar
Mercedes cl500 2000
What I have got is a bit of low speed noise from the rear struts like you can hear them going up & down ( a light rattle) it stops above 45mph. I've had both back coilovers out & cant see anything that would cause it.
Old Mar 10, 2017 | 12:35 PM
Ste73's Avatar
Mercedes cl500 2000
It's as though I'd left the bottom mounting bolts loose but I haven't & they are packed with grease.
Old Mar 19, 2017 | 06:53 AM
g60wall's Avatar
2014 E63s
Dealing with same noise in the rear. Will be replacing all 8 rear thrust arms hoping that solves it
Old Mar 19, 2017 | 11:01 AM
pmercury's Avatar
member
CL
I replaced all these, I had no special noises but it's better to replace these after 13+ years
you need to remove the whole subframe for this
not very difficult but heavy
Old Mar 19, 2017 | 05:36 PM
Welwynnick's Avatar
2006 S600
How did you get the subframe bushes in and out?
Thanks, Nick
Old Mar 19, 2017 | 07:50 PM
pmercury's Avatar
member
CL
wood, metal pieces and a huge hammer
to get them in, same thing but you use the subframe's weight by returning it
+ some vaseline
ps, don't forget to mark position before removal
Old Apr 13, 2017 | 09:58 AM
Daveb44's Avatar
Cl600 biturbo 2005 w215
Is there any modifications that need doing on the rear ? What is best to do with the pump ? Can it be changed for just a power steering pump ? Lastly what is best way to stop the errors with abc gone.
My 2005 cl600 pump is on its way out so if it's fairly simple I'm going to do the conversion. The coilovers are nearly the same price as changing the pump. Thanks
Old Apr 13, 2017 | 10:43 AM
g60wall's Avatar
2014 E63s
The ride will not be anywhere nearly as smooth as what your expecting, Just a FYI it becomes very aggressive. Unless *** you add both sways bars then you can soften up the struts considerably and the ride is decent. Still very sporty but not embarrassing at all.
To get rid of the RED ABC error you can just disconnect the CAN bus for the ABC system out of the Driver side fuse box. Then you get ABC display defective and you can clear the warning. There is no modifications for the rear sway all the mounting points are there. You just need to drop the subframe which is pretty labor intensive.
You can swap the pump, from a regular S500.
Old Apr 13, 2017 | 11:24 AM
pmercury's Avatar
member
CL
you can keep the pump and modify the circuit
look in posts I posted how
for the ABC error you can buy the strutmaster module
or search for my other post how to code out ABC with DAS developper
it's easy
Old Apr 13, 2017 | 11:59 AM
g60wall's Avatar
2014 E63s
I haven't been successful coding out the option 160. It never allows it to complete. It will give a communication error. as far as the star goes. On my S55. Maybe S600 or S65 is different.
Old Apr 13, 2017 | 01:49 PM
pmercury's Avatar
member
CL
I did it with C4 sd connect and xentry 2016 developper mode
what you used ?
Old Apr 13, 2017 | 02:18 PM
Daveb44's Avatar
So it's better to have a rear sway bar but not critical. I get it that with a sway bar fitted the springs can be set a bit softer. I'm going to get on eBay and start looking for parts. Thanks for the information.
Old Apr 13, 2017 | 04:23 PM
g60wall's Avatar
2014 E63s
Same thing. I starting to think my ECU is locked because of my tune or something
Old Apr 13, 2017 | 04:59 PM
pmercury's Avatar
member
CL
ABC ecu is not locked because of your tune
only the engine ecu and the transmission ecu might be locked
