FULL size intercooler upgrade DY
Old Apr 17, 2017 | 03:54 PM
pmercury's Avatar
member
CL
Lightbulb FULL size intercooler upgrade DY
HI,
Thanks to the great Idea by
Welwynnick
so here is my A0995003603 full size radiator upgrade
result is, I have be stressing my turbos for about 40 minutes, I stopped
I touched the radiatior, warm (not hot) on left side, bodywarm on the right side. Just incredible in combination with a upgraded 150 pump.
The radiator from the 2014 S600 is a little to high, like 1 cm, you'll have to grind off a bit on the top and lower corners
also, you won't need brackets as the top metal plate holds the radiator perfectly
the engine radiatior's top will move back 1 cm so youll need to add rubber between and add a bolt on both sides to hold it as replacement of the two plastic clips
remember, this is not plug and play
radiator and parts need to be grinded and adapted a little !
To gain space above the radiator, you'll have to grind off all stuff on the plate interior
also, the left hood cable's plastic brackets have to be removed and you return the rubber just up here and place that cable inside, that does the job
Old Apr 17, 2017 | 06:14 PM
Welwynnick's Avatar
2006 S600
I was wondering how you were going to get on fitting a large HE. Finding space for it is one thing. Getting it into that space is another thing. I fitted mine from below, but it looks like you fitted it from above.
Did you have to move the radiator back in order to get the top of the HE to fit behind the flange that turns down at the front of the top plate, that runs across the top of the radiator? I cut that flange instead, and bent it upwards.
I like the idea of fitting a proper heat exchanger, as the inlet & outlet are at the sides, instead of rear-facing. That makes it much easier to fit.
Did you have any problem with the bonnet latch hitting the HE core when the bonnet is closed? I had to move my latch forwards.
Hopefully you don't have any clearance problems with the small screws that secure the forward under-tray to the bottom radiator brackets. It's tight down there, and you don't want the screws to puncture the HE.
That's a nice job though. Sounds like you're happy with it.
By the way. What's a 150 pump?
Nick
Old Apr 17, 2017 | 07:17 PM
ItalianJoe1's Avatar
2003 CL 600
Very nice, subbed for reference. I guess I should upgrade mine soon, it's getting hot down here.
Old Apr 17, 2017 | 07:34 PM
pmercury's Avatar
member
CL
-fitted from above like charm
-nope, but the radiator moved back by itself as on the right side you unfortunatly have two alumium pipes on the airconditioner radiator
-no problem at all
-nope, that was checked and once the new radiator installed nothing can move
thx ! very !
sorry, its the peirsburg CWA100.2
Nick[/QUOTE]
Old Apr 17, 2017 | 07:38 PM
pmercury's Avatar
member
CL
there is something I'll need to add tomorrow
as none of the plastic plates on the side of the radiators fitted anymore, I have to close that space with some custom
also the space now between the new radiator and the airco avaporator radiator
for those who don't know, all this is present to force the air to flow true the radiators
Old Apr 19, 2017 | 12:51 PM
pmercury's Avatar
member
CL
Just want to add some info
When you do this you should really double bleed
dunno if prefilling the full size radiator helps but I didn't do that
Next day I found a new intercooler intake air too hot
but that was because air remained
so I bleeded for about 2 hours today like a maniac and now everything is fine
you should finish bleeding with only the left bleeding valve open (standing front to the engine)
then activate pump with sort on/off's
on the end you can remain pump on
untill not even finest bubbles are presend anymore
make a 10 min pause once in a while
all this is longer with a piersburg cwa100 pump because of it's power
I also noticed that the vacum with air compressor tool is far to low vacuum
I'm going to buy a electrical vacum pump
now, next, is the tank upgrade
Old Apr 19, 2017 | 04:22 PM
v8mercedes's Avatar
CL 600 '04, Porsche GT3 RS '08, CLS 500 '05, SL 500 '92
awesome replacement
thanks for sharing all your ideas and the detailed photo dokumentation
Old Apr 19, 2017 | 06:59 PM
pmercury's Avatar
member
CL
Thumbs up
Originally Posted by v8mercedes
awesome replacement
thx mate !
it was very exiting yes !
Old Apr 30, 2017 | 03:47 AM
pmercury's Avatar
member
CL
Just want to add these results:
with a outside temp of 15 Celsius, driving strong, not max
I came home and for the first time could put my hands on both intercoolers
they where body temp
I estimate the temp change from original radiator to this upgrade -65%
be careful to fill up the space on the sides between the newly installed radiator and the second airco radiator to prevent the air to escape
I am also going to add a second CWA-100.2 pierburg pump on the left side
pierburg 7.06754.05.0
also, after many engine temp tests, I confir'm
do not use the engine covers !
it cools your intercoolers better and engine is 10% cooler
I have tested this before with no good results, but with this new upgrade it really worth keeping the covers out of the engine
Old Apr 30, 2017 | 05:55 AM
Welwynnick's Avatar
2006 S600
Great work there.
Just wondering what you meant by air compressor tool ? Do you mean a vacuum pump driven by compressed air, like the one MB use?
By electric vacuum pump, do you mean a rotary vane vacuum pump?
Having done a lot of IC bleeding over the last few years, I've largely come to the same conclusion.
Nick
Old Apr 30, 2017 | 07:59 AM
pmercury's Avatar
member
CL
Originally Posted by Welwynnick
Great work there.
Nick
< yes, you can built one yourself, look in my other posts
< yes a electric pump like this:
just one FACT: THERE IS NO WAY TO BLEED PROPERLY THE INTERCOOLERS WITHOUT VACUUM CIRCUIT !!!!
NO WAY ! so don't listen to any idiots pretending that in the forum
Old Apr 30, 2017 | 10:06 AM
Welwynnick's Avatar
2006 S600
Yup, that's a generic Chinese single stage rotary vane vacuum pump, which is suitable for refrigeration evacuation and composites manufacture. It's a PROPER vacuum pump, and will achieve around 10 Pa vacuum, yet it's not expensive.
Atmospheric pressure is around 101300 Pa, so its deep vacuum - more than enough to make water boil at ambient temperature. When the water boils in the IC system, it displaces the air, so when you use your vacuum re-filler, there is no air left. None. Not even one percent.
By contrast, a compressed air vacuum pump will only achieve around 15000 to 20000 Pa, and that will only get MOST of the air out. No wonder MB mechanics say they have to use their kit over and over again.
Nick
Old Apr 30, 2017 | 11:40 PM
tusabes's Avatar
Mercedes
maybe I am one of the forum idiots , but I thought if you simply install an intercooler overflow you will never need to bleed the intercooler ?
Old Apr 30, 2017 | 11:43 PM
tusabes's Avatar
Mercedes
Like the overflow shown here
https://mbworld.org/forums/m275-v12-bi-turbo-platform/562924-intercooler-circuit-overflow-reservoir-2.html
Old May 1, 2017 | 02:19 AM
pmercury's Avatar
member
CL
Welwynnick might confirm me but why would that reservoir remove your bubbles from the circuit ?
It will PREVENT air to get in, but you MUST bleed if you have air or changed the radiator
when a circuit is NOT SELF-BLEEDING like the engine cooling system, it won't become self-bleeding by adding a recervoir
lets wait what nick says
Old May 1, 2017 | 04:21 AM
Welwynnick's Avatar
2006 S600
Wasn't this the thread you were looking for, where Mooks actually replaced the stock W220 IC filler with a proper W222 header tank:
https://mbworld.org/forums/m275-v12-...atibility.html
What I said in that thread was:
The other possible upgrade from the W220 (or other recent turbocharged Mercedes) could be the full-height heat exchanger. I saw a picture of one of these and counted 66 rows.
Part No A0995003603
E / SL / CLS-class: A1975000103
It looked to me that bleeding would still be difficult, as the header still didn't have any bleed lines from the intercoolers.
However, it still enables level checking and topping up, which are very important.
I still think the only way to bleed these systems properly is with a vacuum re-filler and a rotary vane vacuum pump.
They get the vacuum down low enough to get literally ALL of the air out, and they cope with the water vapour. Not expensive either.
I think a header tank is necessary for any cooling system, but it doesn't facilitate bleeding in itself. Look at the engine cooling system. There are two bleed lines to the coolant reservoir - one from the highest point on the top, right hand corner or the engine radiator, and one from the highest point of the engine (the thermostat housing). That's how you do bleeding.
The IC system has none of that. There's a big air-lock in the HE. There's an air-lock in each IC. There's an air-lock in the return pipe to the HE inlet. None of these air-locks will be bled by the header tank, very useful though it is. In 2013 I spend day after day modifying, bleeding and testing and bleeding and testing my IC system. The flow rate is very sensitive to air in the system. Once you have a TINY bit of air in there, the pump churns it up into a froth (especially if you have anti-freeze) and that really chokes the flow. It took a huge amount of work just to get the flow up to a pathetic figure like 4gpm.
Nick
Attached Thumbnails FULL size intercooler upgrade DY-imag0728.jpg   FULL size intercooler upgrade DY-imag0732.jpg   FULL size intercooler upgrade DY-imag0737.jpg
Old May 4, 2017 | 06:11 PM
pmercury's Avatar
member
CL
another addition
I have removed the radiator to built optimum in and out hoses
I was also concerned by the space between the intercooler radiator and the air condition radiator.
So closed every gap between all of them with heat resistant triple aluminum tape
engine temp dropped 5¨C
also, the stupid ABC radiator was taking cold air away
so I finally made the step for a test, removed it
and YES, if you do not have ABC anymore you CAN remove the ABC radiator
tested, abc ail goes to 35° celcius, no problem
also, I testdrive the car tonight, medium high boosts
outside 15° C
I parked and the intercoolers where 17°, really crazy
and don't forget to go under the car to tape all the stock gaps too !
result without the stupid ABC radiator:
Old May 5, 2017 | 06:23 AM
pmercury's Avatar
member
CL
just upgraded to the AMG expansion tank
easy, and really plug and play !
how to here: https://mbworld.org/forums/m275-v12-...atibility.html
Old May 5, 2017 | 12:26 PM
v8mercedes's Avatar
great job
again one of the best mods ever
Old May 5, 2017 | 01:15 PM
pmercury's Avatar
member
CL
after a good triple vacuum bleeding I did some hardcore driving
really great
don't stress to see the coolant level just below the middle line
when the beast is hot, that seems normal
