Old Jun 17, 2017 | 11:40 PM
  #351
Kobzarhomes's Avatar
2011 Mercedes E550 Sport
Thank you
I saw it on BRABUS G800 and it looked nice on it.
Old Jun 18, 2017 | 04:30 PM
  #352
sterz85's Avatar
w205 C43, 958.1 CTT
have you had a chance to work on the interior? looking forward to see how the leather turns out
Old Jun 18, 2017 | 05:17 PM
  #353
Not yet. Hurt my finger a little so it's a little difficult to pull the leather onto the parts. But I have a lot more to do before the interior is assembled. I'll definitely post pictures of the process and the finished product.
Old Jun 20, 2017 | 10:05 PM
  #354
Soft tape not to scratch paint
Old Jun 21, 2017 | 08:32 AM
  #355
pdeacon's Avatar
E450 wagon, C43 AMG Cpe, GLE AMG 63S
Man...this looks terrific. Keep at it. She's coming back to life. Probably better than new. Good luck.
Old Jun 21, 2017 | 10:35 PM
  #356
Assembled door mirrors. I'm so glad I took the effort to take them apart for painting.
Old Jun 22, 2017 | 03:58 AM
  #357
Stuckmojo's Avatar
2008 G55 AMG
Great work. Following with interest
Old Jun 22, 2017 | 06:26 PM
  #358
RA050524's Avatar
g500
hi KB, i am currently changing that gas pedal to the newer one. i was wondering, what is the little circular piece under the gas pedal and wire for? I'm talking about the hole where you used a piece to plug. did you just cancel it out? I'm very confused.
what did you do with this wire? where does it go?
Old Jun 22, 2017 | 06:36 PM
  #359
Hello
This is a kick-down button.
I have not driven with the new pedal at high speeds, but a member on this forum just told me that he did a similar pedal swap and ended up having to integrate this kick-down button in to the new pedal so the kick-down works.
The new pedal has a kick down button built in to its movement, he told me the car got confused when he used the built in kick-down so he modified the padal and integrated original kick-down button in to it.
Old Jun 22, 2017 | 06:39 PM
  #360
RA050524's Avatar
g500
so i should pretty much ignore it? i don't know what to do at this point. what do i do with the wire?
Old Jun 22, 2017 | 06:41 PM
  #361
RA050524's Avatar
g500
i wouldn't want to loose my kick down feature lol
Old Jun 22, 2017 | 06:42 PM
  #362
From what I understand.....
If you want to use the kick-down button when driving, you need to keep it plugged in and you need to integrate this original button in to the new pedal.
Old Jun 22, 2017 | 06:51 PM
  #363
aerG500's Avatar
you can't ignore it.
I did the same upgrade and came across a problem & solution. the 230 pedal has a dummy kick down switch (hence no wire plugged into it) in it which causes problems because the later models' ECU is programmed to "kick down" at a certain point in the electronic pedal travel, not by switch. with the new style pedal installed in with the older ECU (which requires a physical switch) when you floor the gas, the ECU doesnt detect a kick down, thinks there is a malfunction and so it cuts off all power to the pedal. dead in the water. press the gas pedal and nothing happens. then you have to stop the car, shut it off and restart to get it going again being careful to not push the pedal down below the error mark till you get it home (happened to me) SOLUTION: I took the kick down switch from the old set-up (the one mounted to the floor), removed the dummy switch from the 230 pedal and used a dremel barrel sander to enlarge the hole where the dummy fit into plus had to cut out on the back so the plug would fit thru the pedal assembly and into the the retrofitted original kick down switch, epoxied and screwed in the original kick down switch into the new updated 230 SL55 pedal assembly. that fixed it. 100% operational as intended now.
Old Jun 22, 2017 | 06:55 PM
  #364
RA050524's Avatar
g500
damn, all this sounds very complicated. so now i am currently in the process and i just plugged in the pedal in the hood area to test, and it works fine. how do i "integrate" the kick down from older pedal to newer? thanks very much
Old Jun 22, 2017 | 06:58 PM
  #365
RA050524's Avatar
g500
ohh i see, sorry about the last post. i will try to do as stated with the dremel barrel sander. i will let you guys know about the procedure. Anyways, KB, what will you do with the kick down feature? very curious
Old Jun 22, 2017 | 06:59 PM
  #366
AERG500: thank you for stepping in and sharing this information. It makes more sense coming from a person who actually has done the modification )) 👍
Old Jun 22, 2017 | 07:01 PM
  #367
I will do the same thing, I will integrate the original kick-down button into the new pedal. I just literally found out about this few minutes before you posted that original question.
thank you AERG500 👍
Old Jun 22, 2017 | 07:26 PM
  #368
aerG500's Avatar
my G is in the shop till towards the end of next week. when i get it back, I'll take some pics of what i ended up having to do for you guys. Hopefully that will make it a bit easier as I know just simply writing it out is probably not that simple to duplicate.
Old Jun 23, 2017 | 08:21 PM
  #369
RA050524's Avatar
g500
hey guys, so i extended the wire for the gas pedal and integrated the old kick down button into the housing. a couple of problems, when i was working on the pedal, i removed the carpet and made the bracket. now when i put back the carpet, the whole gas pedal won't fit since the carpet is very thick. another problem, does the newer gas pedal allow enough space for this carpet panel to go back in? because i was trying to put it back and it didn't seem to have enough space to fit. maybe i should cut a piece of the carpet in order to make the whole system fit. very curious...
(this carpet panel under the dashboard)
Old Jun 23, 2017 | 08:26 PM
  #370
I personally did not install my main carpet or the under-dash panel yet.
jdbenz500: Can you take a photo of how you attached the pedal in the car.
aerG500: I would also love to see how everything looks in your car when its all put together.
Thank you
Old Jun 23, 2017 | 08:32 PM
  #371
RA050524's Avatar
g500
Hot glued the kickdown, just got lazy to go and buy epoxy lol, very strong though
Built and welded the bracket
Btw Heres my custom interior guys, all done by me, still not done with the back seats. This whole interior used to be grey until i got fed up lol
Old Jun 23, 2017 | 08:37 PM
  #372
I see what you mean.
The top of the pedal is chunky and is hitting the under-dash panel? Is that right?
I think the under-dash panel might need to be modified for the pedal clearance.
Old Jun 23, 2017 | 08:40 PM
  #373
RA050524's Avatar
g500
yes its sitting higher than usual. ill probably end up cutting a piece of the carpet in order for everything to fit. modifying the under dash panel seems too difficult lol
Old Jun 23, 2017 | 08:43 PM
  #374
I see.
I think I might have purchased 2016 G63 driver side carpet. I'll check what it looks like where the pedal is attached to the floor. Ill see if they modified the design since newer G-Wagon's are using this style pedal.
Old Jun 23, 2017 | 11:45 PM
  #375
Here Are pictures of my driver side carpet. I think it might be different then regular G500 carpet....
