Trouble code P2404 The stop lamp switch signal sent from the traction system via the
Old 09-27-2017, 11:50 AM
Lab
Lab's Avatar
C230 kompressor
I have a 2005 c230 kompressor coupe and I'm getting the trouble code P2404 The stop lamp switch signal sent from the traction system via the CAN bus is implausible.
Does anyone know what the problem might be ? Has anyone had this problem before ?
Old 09-27-2017, 03:08 PM
Russell Ormerod's Avatar
not a merc
Read ESP faults! Then renew stop lamp switch
Old 09-28-2017, 06:25 AM
Lab
Lab's Avatar
C230 kompressor
It has ESP code C1330 and there's is no stop lamp switch on this model (2005 c230 coupe)or I would have already changed it. Instead this car has a pedal travel sensor located in the brake boaster and a brake pressure sensor in the master cylinder.
Old 09-29-2017, 04:31 PM
not a merc
So what is the description for the code in esp
Old 09-30-2017, 12:56 PM
Lab
Lab's Avatar
C230 kompressor
C1330 no description.
Old 10-01-2017, 12:17 PM
not a merc
I will check what that codes means
Old 10-02-2017, 06:53 PM
Super Moderator
Glyn M Ruck's Avatar
Early cars had on pedal switch. Later cars took feed from ESP/BAS.
Old 10-03-2017, 05:43 PM
not a merc
So basically the BAS position sensor on the brake boosrer is being used as the stop lamp switch. I have never seen these give stop lamp problems!
Stop lamp switch on the other hand I have replaced plenty. Stop lamps usually still work but ESP lamp comes on.
Old 10-04-2017, 06:54 AM
Lab
Lab's Avatar
C230 kompressor
It's looking like I have to replace the brake booster. When I scan the car with my launch creader vii I get the codes P2404, c1330, c1201 and the car won't come out of park. The brake solenoid and brake lamp switch are in the brake booster so gonna have to change whole unit.
Old 03-07-2024, 10:19 AM
outdoorjunke's Avatar
2005 C230 K
Did this fix your problem?
Quick Reply: Trouble code P2404 The stop lamp switch signal sent from the traction system via the
