Post your wheel/tire setup with pictures and information...
Old 12-29-2016, 05:28 PM
wolves.creed's Avatar
E63s
Why not make a thread of all of our setups. Post pictures of wheel size , offset , tire size and if any fender mods were needed to make that setup work. This would be a good reference thread for newcomers or just members looking to switch it up, this way you can get an idea of what size/setup you would like to run before making any big purchases.
This is for any w212 e63 model.
List the following. Summer & Winter wheels , OEM or Aftermarket.
Wheel make/name (ADV1)
Wheel size (20x9.0)
Offset (33-45ET)
Tire size (285/40/20)
Suspension (coilovers/h&r sports/stock...etc etc)
Modifications if needed (fender roll/trimmed fender liners/spacers...etc etc)
And most of all post 2-4 good images of each setup so that the fitment can be seen clearly.
Please try to keep the images semi small (800x600ish) so that there is better load time. thanks.
The following 2 users liked this post by wolves.creed:
2012 CCB E63 (12-29-2016), mj_39 (12-29-2016)
Old 12-29-2016, 11:50 PM
mj_39's Avatar
2014 E63S Sedan
You read my mind, I was actually going to ask if there was a thread like this already made! This is a great idea
Old 12-30-2016, 01:53 AM
CarHopper's Avatar
E63S | X5
I'll bite even though I am on OEMs.
Wheel --- OEM
Wheel sizes --- F: 19x9 R: 19x9.5
Offset --- F: +37 R: +52
Spacers --- F: 10mm R: 13mm
Suspension --- H&R springs and rear endlinks.
Fender mods --- None.
* Note. I do rub. Turning the wheel at low speeds and going over dips at high speed. I will work on correcting this hopefully with an aftermarket set.
Pics:
Post your wheel/tire setup with pictures and information...-vzm.img_20161118_132312_zps9gigajsn.jpg
Post your wheel/tire setup with pictures and information...-img_20161230_013814_zpsien1hxgo.jpg
Post your wheel/tire setup with pictures and information...-img_20161230_013848_zpsekwmuzid.jpg
The following 2 users liked this post by CarHopper:
E63_SauceGod (05-17-2019), Ed99 (01-20-2017)
Old 12-30-2016, 12:05 PM
BLKE63's Avatar
2014 E63S AMG
Car looks sick good job. Gotta love black and white
color combination.
CarHopper (12-30-2016)
Old 12-30-2016, 01:33 PM
SPONSOR
thewb's Avatar
www.wheelsboutique.com
HRE P43SC
Brushed Dark Clear
20"x9" // 20"x10.5"
255/30/20 // 285/25/20
Old 12-30-2016, 01:44 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Just got the call, custom wheels just arrived. I'll be back from Cali and have them installed on Tuesday and get some pics up!
Post your wheel/tire setup with pictures and information...-70c2f79d-b1fb-4f8c-8f60-a74650ce8d2a_zpsyg8xtc1i.jpg
Old 01-03-2017, 11:53 AM
microcolt's Avatar
2013 C63 AMG P31; 2016 E63 AMG S
Wheel --- OEM
What lip do you have on your front bumper if you dont mind me asking?
Old 01-03-2017, 03:08 PM
sjb
sjb's Avatar
S213 E63
Beef. Not just for dinner.
HRE Classic 305 3-piece
Front 19x9 ET30
Rear 19x10 ET49
Michelin Pilot Super Sport
Front 255/35ZR19
Rear 295/30ZR19
The following 3 users liked this post by sjb:
altesporsche (12-20-2022), BCP (10-29-2021), NH_E63 (01-26-2023)
Old 01-03-2017, 05:34 PM
chiromikey's Avatar
Avant Garde F411
19x9 30ET 19x10.5 50ET
265/30/19 305/30/19
No spacers
Stock height (trying to talk myself into sacrificing ride quality)
Here are some horrible quick pics. I'll replace these with decent ones when I get the tires cleaned up from the install.
Post your wheel/tire setup with pictures and information...-13e53096-5bd9-41ab-bde1-c1bdbe967d6a_zpsjwsb2k4n.png
Post your wheel/tire setup with pictures and information...-df00a090-7591-44fd-9e3a-ab90dba8daeb_zpsqdikwiat.png
Post your wheel/tire setup with pictures and information...-aa9cafc1-829c-4bf8-9e56-bec5af838490_zpsoijlm4qo.png
Old 01-09-2017, 11:39 AM
CarHopper's Avatar
E63S | X5
delete.
Old 01-19-2017, 10:12 PM
mj_39's Avatar
2014 E63S Sedan
lets bump this, help us newbies with fitment ideas.
The following 2 users liked this post by mj_39:
02jagman (06-23-2024), P30E63 (01-06-2022)
Old 01-20-2017, 04:46 AM
godrealm06's Avatar
2014 E63 AMG S 4MATIC
HREs FF01
19x9 front/ 255s
19x9.5 rear/ 285s
Continental Extreme Contact DW
Stock height
Old 01-20-2017, 11:10 AM
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
Originally Posted by chiromikey
Avant Garde F411
265/30/19 305/30/19
No spacers
Looks good, will it rub in the back if you lower? Looks flush, would 295s with 10.5" wide at Et45 be ok?
Old 01-20-2017, 04:37 PM
chiromikey's Avatar
I think I could still lower this car and not rub. After the camber is reset I might have to adjust the offset slightly to but I think it can be done. 295s would be no problem and if you're not lowered I think (but don't hold me to it) ET45 would work.
Old 01-20-2017, 08:04 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
I had hoped this would take off...
Before I made a decision on some wheels...
Old 01-21-2017, 11:55 PM
iownedu's Avatar
2014 Mercedes E63S AMG
Here is my setup.
Rohana RF2 wheels on Nitto Neo Gen All-Season Tires, factory height, no rubbing on any suspension settings ever. Tires are within .1" overall diameter of factory 19" tires. If I put a straightedge (yard stick) on the fender lip to the ground down the center of the wheel, the face of the outer lip of the rim is 7mm in from the fender on the front and rear both so these are the correct offsets to be even. I would like to lower the front 1/2" if I can find springs that do that, I dont forsee any reason it would rub then either.
Front:
20x9, 25mm offset Wheel
245/30ZR20 Tire
Rear:
20x10, 45mm offset Wheel
305/25ZR20 Tire
Post your wheel/tire setup with pictures and information...-p_20170114_093031_vhdr_auto_zpskbhewleg.jpg
Post your wheel/tire setup with pictures and information...-p_20170114_092955_vhdr_auto_zps9eqmnjiw.jpg
Post your wheel/tire setup with pictures and information...-p_20170114_092928_vhdr_auto_zpswf9j20fm.jpg
Post your wheel/tire setup with pictures and information...-p_20170114_092920_vhdr_auto_zpspnijw1sn.jpg
Post your wheel/tire setup with pictures and information...-p_20170114_092904_vhdr_auto_zpsxjakbqci.jpg
Post your wheel/tire setup with pictures and information...-p_20170114_092811_vhdr_auto_zps9igk1gdy.jpg
Post your wheel/tire setup with pictures and information...-p_20170114_092737_vhdr_auto_zps9ckzx4ch.jpg
Post your wheel/tire setup with pictures and information...-p_20170114_092742_vhdr_auto_zpsietrg51s.jpg
Post your wheel/tire setup with pictures and information...-p_20170114_092727_vhdr_auto_zpsdej5dlqs.jpg
Old 01-22-2017, 02:56 AM
cstanley92's Avatar
2011 E63, 2011 Audi A4, 2017 Audi Q7
iownedu, that thing looks nasty. I am usually not a fan of colored wheels, but wow. The red really sets off and compliments the whole car. If only it had that color red interior!!! I've considered red Vossen's, but I feel like that is the BBS of the tuner world. Great looking wheels, but everyone has them. These are unique!
Old 01-22-2017, 10:16 AM
iownedu's Avatar
Yeah I went out on a limb by ordering them in red, I was going to get the titanium finish originally. I was going to sell them and replace them with titanium if I didn't like the red. But it actually turned out really well, it's a very nice shade of red and actually goes with the diamond white/black of the car.
My car actually has designo Mystic red/black interior as well.
Old 01-22-2017, 04:39 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Let's see some more set ups.
Old 01-31-2017, 07:17 PM
hotrodwagon's Avatar
2016 Mercedes Benz E 63 S AMG Wagon
No proper pics yet. Waiting for summer to do that now. But here's what I am running in the summer...
Wheel make/name: Vossen VLE1
Wheel size: FR-20x9.0 R-20x10.5
Offset: FR-32 R-42
Tire size: FR:255-30-20 R-285-25-20
Suspension: Stock for now but have springs and links to be put on soon.
Ed99 (01-06-2019)
Old 02-01-2017, 07:28 AM
CliffJumper's Avatar
no MBs at the moment :(
Wow, that's a unique look for the wagon! Very nice.
Offset: FR-32 R-42
Old 02-01-2017, 09:49 AM
10speed's Avatar
E63s
Originally Posted by iownedu
Here is my setup.
Front:
245/30ZR20 Tire
Rear:
305/25ZR20 Tire
Looks nice! The front tire looks a little stretched can you use a slightly larger tire to get a little more meat ? Or would a 81/2 " rim be better? I'm only asking I'm not to experienced with figuring out wheel offsets, Is your front tire really 25mm or 35 mm , I seen most rim places recommend 35mm for front ?
Old 02-02-2017, 07:23 PM
SPONSOR
SupremePower's Avatar
GT3RS, 356, Raptor, M2, Sprinter 4x4
Vorsteiner VFF-103
20x9 +35 (265/30/20) | 20x10 +42 (295/25/20)
Post your wheel/tire setup with pictures and information...-vorsteiner_e63vff103-203-20copy_zps0k2kfzei.jpg
Post your wheel/tire setup with pictures and information...-vorsteiner_e63vff103-202-20copy_zps3iij3780.jpg
The following 2 users liked this post by SupremePower:
BCP (04-26-2020), mj_39 (02-02-2017)
Old 02-02-2017, 07:35 PM
mj_39's Avatar
2014 E63S Sedan
^ looks great! Rear fitment looks perfect. Are you rubbing at all? What are you lowered on? Which brand tires are you running? Lastly, how's the fitment front vs rear?
Old 02-03-2017, 11:18 AM
SPONSOR
No rubbing with this setup.
Lowered on KW H.A.S.
Tires are Michelin PSS.
Fitment is pretty on point. Car looks dialed.
raudiace4 (02-03-2017)
Quick Reply: Post your wheel/tire setup with pictures and information...
