Let's See Your Aftermarket Wheels
Old Feb 15, 2018 | 02:17 PM
Cobra1832's Avatar
E63s
Im in the process of looking for a set of wheels for my E63s. Because the car is fairly new with slightly weird offsets there doesn't seem to be a ton out there. On top of that there seems to be almost no pictures with the wheels on a 213 E63. If you've got aftermarket wheels post them up!
Thanks!
Im thinking black or a darker silver color on this.
Popular Reply
Oct 24, 2019, 02:46 AM
apsuard's Avatar
apsuard
Empty
Old Feb 15, 2018 | 09:01 PM
simarddominic's Avatar
Mercedes-AMG E 63 S 4MATIC+ 2018
Same thing for me ! Looking for summer wheels !
Old Feb 26, 2018 | 05:39 PM
soulsea's Avatar
☐ Rekt ☑ Not Rekt
Quick q ... what are the oem offsets?
Thanks.
Nvm, I think I found it ... 25 front 55 rear.
Old Feb 26, 2018 | 06:47 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
Nice! Much better than Hulk green.
Old Feb 26, 2018 | 08:45 PM
BACONMOTORSPORT's Avatar
2018 E63s Wagon
Do we know how wide of a wheel/tire combination these newer cars will fit? I have some 20" tires with nearly the same diameter as oem, but they are 305 and 315. The 305 front seems an unlikely fit. Thoughts??
Old Feb 26, 2018 | 09:38 PM
soulsea's Avatar
☐ Rekt ☑ Not Rekt
Old Feb 26, 2018 | 10:15 PM
Cobra1832's Avatar
E63s
Originally Posted by soulsea
The 305's will certainly be too big for the stock front rims. I think you need a 10.5inch rim at the least for that size tire. I am curious, what are they off of?
Old Feb 27, 2018 | 05:56 AM
2018 E63s Wagon
Soulsea I know what size we have. I'm curious how big we can go. Not the wheels so much but what fits the car without rubbing. Tires were on a 2016 gt350
Old Feb 27, 2018 | 09:31 AM
soulsea's Avatar
☐ Rekt ☑ Not Rekt
That I don't don't know,.
The first consideration would be how wide a tire 9.5" and 10" wide wheels can accommodate ... the second, whether changing the overall geometry of the wheels would affect the awd system.
Not so much if you're changing both measurements keeping approximately the same diameter, like going from a 265/35 to a 275/30, but if you're going bigger in both directions.
Personally I wouldn't put 305/315 on those width wheels even if they didn't rub and the awd system could take the change, they'll be balloting like moon lander tires.
Old Feb 27, 2018 | 06:26 PM
2018 E63s Wagon
I would go with an aftermarket wheel that could support the tire. This goes back to my original question. I wonder how wide a wheel and tire this car will fit without issue. Regardless of oem sizes or what I happen to have laying around.
What will fit...
Old Feb 27, 2018 | 08:18 PM
Cobra1832's Avatar
E63s
What will fit...
Hi, if my memory serves me correct, we ran together at Devens. Yours is white and ran Hoosiers? I had the black R. Still have it? Hopefully I’ll see you out there in the E.
Regarding the front tires on the E, the minimum wheel width for that tire is 10 inches, the stock is only a half inch smaller. I would be willing to bet a 10 inch wheel will fit. I cant speak to the tire size though. its a pretty big jump. might get some rubbing if it fits at all. Unfortunatley wheels are hard to find for these cars and when you do they are $$$$.
Old Feb 27, 2018 | 08:23 PM
Cobra1832's Avatar
E63s
What will fit...
Old Feb 27, 2018 | 09:19 PM
2018 E63s Wagon
That's me!! Sold everything I owned to buy the E63s. My concern is not so much with fitting the tires I have. I was just trying to have the conversation about what size wheels and tires will fit the platform.
I image we will do one or two events this year in the wagon. Assuming it's not in the shop...
Old Feb 27, 2018 | 09:45 PM
ptclk63's Avatar
2007clk63
hello just saw where you are from im in ma as well. are there any meet ups you guys attend in the better months?
Old Mar 8, 2018 | 09:22 PM
bluesea's Avatar
'18 E63 Wagon, '14 E63 Wagon, '00 M5
S213 with HRE P107 in Satin Charcoal
Just put these on today. I may replace the bright window trim with the factory's black chrome version.
Old Mar 9, 2018 | 02:25 PM
thewb's Avatar
SPONSOR
www.wheelsboutique.com
Excellent wheel choice Blue Sea. I'm a bit biased though since I have the P107's on my car as well ;p
Here are a couple of HRE setups we've done. We've got the fitment dialed in perfectly:
View this post on Instagram
Old Mar 9, 2018 | 02:34 PM
bluesea's Avatar
https://www.instagram.com/p/BfdjgOxH...wheelsboutique
https://www.instagram.com/p/Bb0exyyg...wheelsboutique
These setups look great! Yeah, P107's work on a number of cars, I think. Do you know what the center cap diameter is? I'm trying to find some Mercedes Three-Pointed-Star caps to clean up the look and give it a more OEM finish. Do you carry such caps? Thanks!
Old Mar 9, 2018 | 02:43 PM
thewb's Avatar
SPONSOR
I've found some aftermarket ones on ebay in the past. The outside diameter must be 55 mm and the clips on the revers side should be about 52 mm. Here's the link to the ones that I found for my customer in the past - https://www.ebay.com/itm/4x-CHROME-W...oAAOSw7GRZCyPP
Old Mar 9, 2018 | 03:37 PM
bluesea's Avatar
Thanks so much! That's very helpful.
Old Mar 9, 2018 | 09:27 PM
eas43's Avatar
'17 E43
Looks great! What would be the ideal HRE setup (widths/offsets) if we stick with 20" rims?
Old Mar 10, 2018 | 10:35 AM
thewb's Avatar
SPONSOR
20"x9.5" // 20"x10.5" is the correct fitment for the W213 E63 AMG. The above two cars used that but with 21" setup.
HRE doesn't divulge offset information until a customer has placed a deposit on an order. If you want the perfect fitment I've got you covered.
Old Mar 13, 2018 | 09:39 PM
sighting's Avatar
e63s edition 1
Pretty sure the w213 e63 has the following wheel dimensions and offsets
Front: 20x9.5 ET25
Rear: 20x10 ET55
Old May 2, 2018 | 12:14 PM
Cobra1832's Avatar
E63s
Finally made my decision and went with Forgeline VX1’s in matte black. Stock sizes.
Old May 3, 2018 | 11:14 AM
tonymiabmw's Avatar
f80 M3
E63s need a piece wheel imo. Not a fan of mono block on the e63
Old May 3, 2018 | 12:38 PM
CALBenzo's Avatar
'18 E63S AMG
I assume you meant a 2 or 3 piece wheel. While they look awesome, especially with a nice 4" lip, I will never buy a 3-piece again. With a 35, 30 or 25 side profile, they just were bent too easily when hitting an inevitable pothole every now and then.
