2020 G63 exterior rearview mirror vibration
Just curious how many others have noticed either of their exterior rearview mirrors vibrate at higher speeds. At speeds higher than 55MPH my 2020 G63 exterior rearview mirror on the drivers side vibrates (just the mirror glass itself). The passenger side is fine.
Kasch (Today)
‘13 911-4S, ‘21 CTR, '22 GT4, ‘19 G63
I had the driver's side mirror glass motor replaced which was "suppose to fix the vibration issue", but of course they replaced it under warranty at the dealership and nowt I think the vibration issue is only marginally better (or possibly no difference). Kind of disappointing... Seems like there is no real solution for this problem.
No problem (yet) on my 2019. Do both left and right mirrors feel the same when you press on the glass? Any loose feel to the left one? Did you actually see the motor unit the dealer claims to have replaced?
same issue
This issue happens to my last 2019 g63amg but I didn't keep that car very long. And I bought a 2021 model about 3 weeks ago, the same issue happens again!
I brought it back to the dealer and they replaced the motor, but I didn't noticed any improvement. So I brought the car back to them again, they kept the car for 2 days and said they can't get it fixed completely. Looks like this is a design flaw.
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
I had rattle noise from wind on both mirrors and figured it out today. There is a circular cap under each mirror that I assume covers access to the folding motor. Both of mine were just slightly loose, as in I could slightly push it in and slide it around a little from side to side with my finger. I took a small bit of black gorilla tape and secured the caps to the base of the mirror...barely noticeable (only from looking under the mirror unit). Problem solved. Probably a bad gasket seal or just a fault in manufacturing, but no more noise. Hope this can help some.
Any luck with the mirror glass vibration issue getting successfully fixed? My dealership has “fixed” it twice and still no difference (replaced motor).
There apparently doesn’t seem to be a successful solution to this problem. Unless someone has had a successful repair done??? Do most of you notice this mirror glass vibration on drivers side of your G wagon (2019-newer)? It’s kind of pathetic that a $200k vehicle does this… a $20k car doesn’t even have this problem….
I hear you on this matter with the vibration. i have to live with it as well, dealer attempted to fix but NO luck.
Similar to the windows (on my E class) situation where that plastic piece design keeps on breaking and preventing window roll up/down operation.
I am afraid to roll down the windows..kinda sad.
Mbracer26 (02-13-2024)
2021 G63 rearview mirror driver side vibrations
Went two dealerships four times the last one changed the whole mirror housing and everything but still no luck
it actually is worse now I requested them to put the original one back but they said it broke while taking off. Now I am stuck and it’s surprisingly just the driver side and dealer told me it’s common complaint with no credible fix yet from Mercedes. Very disappointed that 200k car has this issue 😢😢
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
