Sloshy Sloshy?! Water in the frame of the vehicle? Where are the drains?
Old 01-01-2022, 09:32 PM
C230 Sport Coup's Avatar
So, living in Oregon these days by the coast.
LOTS of rain in the winter.
We have a few issues with the 06 ML lately,
and one is that we hearing water sloshing around in the frame below the doors.
I'm guessing the drains are plugged. Where should I be looking?
Old 01-02-2022, 01:00 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
The sloshing water you hear is located in the tailgate flooring, There are four drain plugs on the flooring but they do not have holes in them.
You must remove the rear-end door floor and then remove the spare tire and all the other equipment until you see the metal floor and the drain plugs..
File Type: pdf
Old 01-02-2022, 03:54 PM
That's my plan for today. Read a ton of threads on this.
The funny thing is I'd swear it sounds like it's in the unibody sections below the passenger door.
You can hear it moving up and back in long waves. Nobody mentions that.
But I'll know later today. Thank you.
Old 01-02-2022, 08:38 PM
Ok, got into it.
Pulled all the crap out of the back, pulled the spare etc.
Tiny bit of water under there. Just an oz or 2.
checked the sides where the tail lights are.
Lightly damp, no puddles.
Checked under the passenger seat, battery compartment,
mostly dry, slightly damp in a couple spots.
No smoking gun puddles of water.
Cleaned windshield drains, and poured water...came out from the bottom of vehicle.
Poured water in sunroof drains, came out the bottom in the front AND the back.
So...what the heck? Thing is sometimes it doesn't want to go into reverse and
I thought it might be water related. But hmmm.....
Old 01-03-2022, 04:15 AM
Even if you have a small amount of water in the tailgate flooring, you must replace the rear tailgate seals.
Also clear the drainage holes in the eng. compartment.
File Type: pdf
Old 05-14-2024, 03:51 PM
louisRRR's Avatar
ML350 2007 164.186
Hey
did you find a solution for the sloshing water noise ? I have the same issue.
Thank you
Old 05-22-2024, 08:28 AM
sunspace's Avatar
2014 Ml350
Sloshing water in rear passenger door frame
Originally Posted by louisRRR
Hey
Thank you
I had the same thing and it was water in the door frame. So just pull on the outside edge of bottom rubber gasket and the drain hole will unplug and water will pour out.
Old 05-22-2024, 10:06 PM
Currently sitting with all 4 wheels locked, won't go into park.
So, never got the sloshy thing sorted out.
Pulled all the plugs under the car, some water came out.
Also heard there are plug under the plastic wheel house covers
and I have not gotten around to checking those.
And I'll check doors, if I ever get around to fixing this thing.
Quick Reply: Sloshy Sloshy?! Water in the frame of the vehicle? Where are the drains?
