Sponsored by: CARiD
LAUNCH Creader Elite 2.0 Review link
Old Mar 23, 2024 | 10:15 AM
DFWdude's Avatar
2016 E350 Sport
Question LAUNCH Creader Elite 2.0 Review link
Here is a link to an interesting review of the LAUNCH Creader Elite reader. This is the previous version (vertical orientation) reader, but covers (I presume) all the same features of the newer, horizontal version reader...
The more I learn about the features of this product, I am both bewildered by the depth and wealth of the features, AND the more apprehensive I am to using this device to code changes, because there are so many ways to make mistakes. To minimize this, his advice to use a rubber-tipped stylus to navigate screens is a GOOD idea, IMO.
For example, there is a section where the reviewer mentions the (undocumented) need to turn the ignition OFF and back ON to process changes... This is not at all intuitive to the casual user, or the beginner, like myself.
On my wish list is coding to permit "Video in Motion", but I want to learn which module to look for, just to get me in the right neighborhood.
Old Mar 23, 2024 | 11:28 AM
JettaRed's Avatar
Veteran: Army
Generally, it is best to turn the car off for 10 seconds and then back on when clearing codes. Not all DTCs require this, but some do. My Creader (and other scanners) gives instructions to do so when needed.
The biggest difference between Elite and Elite 2.0 is that 2.0 has an internal battery that keeps it on when disconnected from the OBD port. I think Elite 2.0 uses a faster processor, as well. But both use the same software version. I did recently have to upgrade the OS on my Elite 2.0 whereas the original one did not have the upgrade. So, there's that too.
I will repeat that you should always make a backup before making any changes to the variant coding. On the module screen, you are given the choices of Write Coding, Backup, or Restore.
Old Mar 24, 2024 | 05:01 PM
JettaRed's Avatar
Veteran: Army
The Upgrade menu notifies you and allows you to upgrade the firmware and software applications. However, I found that the Android OS upgrade occurs elsewhere. The following shows how to update/upgrade the OS.
  • Start with the Settings menu.
  • Go to About.
  • Select Version and then select Detection system update.
  • On the System Update screen, select Check Version. You will be told if you have the latest version or that you need to update.
Old Mar 27, 2024 | 07:35 PM
kgredstar's Avatar
CLS55 AMG
Been looking at this myself. It seems like a great option at a great price point. With coupon (come and goes) you can get it $149 or so.
Old Mar 27, 2024 | 09:52 PM
JettaRed's Avatar
Veteran: Army
You can also get it on AliExpress shipped from the US for under $120.
Old Mar 28, 2024 | 09:19 AM
ygmn's Avatar
2015 E400 Sedan
I have looked but has anyone used this tool to get the Euro ILS headlight function to work?
I thought I read it on here but then the thread I thought it was in the member deleted all his posts.
ANyone?
Mine should be here today as Amazon has coupon for $30 off price and for $170 Delivered with tax is a good price for this tool.
Seems like it a whole bunch more then the normal code reader.
Thanks to all who have posted their comments and experiences so far as I read a good hours worth before pulling the CC out of the wallet.
Old Mar 28, 2024 | 10:17 AM
JettaRed's Avatar
Veteran: Army
ANyone?
Are you sure your car is equipped with the proper hardware for the Euro ILS? I tried activating it on my car (2015 SL400) and it did not work. I do have option 615 -- BI-XENON HEADLICHT W.ACTVIE CURVELIGHT RIGHT-DRIVE, but I don't think that is the same.
This scanner does seem to actually do more than XENTRY with some functions, such as activating the blinking brake lights, or at least I can't find it in XENTRY.
Old Mar 28, 2024 | 10:29 AM
rey_winslow's Avatar
2016 E350 wagon
I think you need to have 640 for ILS?
Old Mar 28, 2024 | 05:34 PM
ygmn's Avatar
2015 E400 Sedan
I have all the things that the hard coders (benz ninja etc) require and could pay them but this would be cool for Launch to do.
Car is loaded.
Old Mar 28, 2024 | 06:46 PM
JettaRed's Avatar
Veteran: Army
Car is loaded.
I would be careful, though. I know I hosed up my front radar using iCarsoft to do a throttle position sensor (TPS) calibration, and had to use XENTRY to recalibrate and get Distronic Plus and PRE-SAFE brake to work again. You can probably mess things up even with this great little scanner if you don't know exactly what you are doing. If you really want to make some of these changes, go with @BenzNinja and ensure it's done right.
P.S. Why did resetting the TPS also reset my front radar? I have no idea and that's the scary part.
Old Mar 28, 2024 | 07:10 PM
WRC-LVR's Avatar
2012 E350 Cabriolet now SOLD to my son
Can you post a link to thsi 2.0 version?
Old Jul 23, 2024 | 02:42 PM
jmcdermo10's Avatar
2019 GLC 300 4 matic
Question 2019 GLC300 4matic Oil life reset with the Launch Creader Elite v2.0 -BN
I already posted this on a different thread but this one seems more applicable. I bought the tool on 7/18/24 for $170 and it got delivered last night (Monday 7-22-24) I changed the oil and filter 2 days before but holding the "phone" button and "ok" button on the wheel for 5 seconds didn't work. This tool seem like it can do a ton of things but I have spent 2 hours + trying to figure it out and keep striking out. Can anyone walk me through how to do it?
Thanks,
Josh
Old Jul 23, 2024 | 06:52 PM
W205C43PFL's Avatar
Thanks,
Josh
Do the reset the traditional way on the steering wheel, if it isn't working you could keep trying, make sure you are on the Trip/odometer screen.
Old Jul 23, 2024 | 08:02 PM
DFWdude's Avatar
2016 E350 Sport
Resetting the meter is somewhat fiddly, so try it per the video and it will eventually work.
Old Jul 14, 2025 | 07:12 PM
rnettleship's Avatar
2012 CLS63, 2015 GL450, 2014 ML350
Does anyone know if you can export he diagnostic records to view on your PC? I have captured many data stream but do not see a way to get them off the reader. The Elite 2.0 is very powerful but viewing the records of the live data is difficult and tedious on such a small screen.
Old Jul 14, 2025 | 08:06 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
You know how you can hook up the scanner to a PC USB Port?
From the PC you can navigate the Android filesystem inside the handheld device.
You may find where the dot.csv log files are located.
Well worth poking around to import into Excel for analysis.
Old Jul 14, 2025 | 08:15 PM
I plugged it into my USB port but my PC does not recognize it as a drive. It seems to only support charging of the device.
Old Jul 14, 2025 | 08:24 PM
2016 E350 wagon
There is an option to share the report, just add your email address.
Old Jul 15, 2025 | 07:56 AM
I have no option to share the data streaming reports, just the diagnostic (DTC) reports. I start a data stream and then hit "Record". When I stop the recording it auto saves a copy that I can view on the device. When I hit "Report" it just says "Report saved". I feel like I am missing something obvious.
Old Jul 15, 2025 | 08:25 AM
streborx's Avatar
Top Answer: 1
G550
In the scanner's setup, specify a wifi connection and an email address. There's a "share" option that sends the report via email, and you can store and print from there. Scanner updates are via wifi -- no PC connection is necessary or provided.
Old Jul 15, 2025 | 11:35 AM
I must be missing something. I have WIFI setup and can easily email a diagnostic report. I have no option to share a diagnostic record which would be the live data stream results. Viewing the graphs on the device is nearly useless.
Old Jul 15, 2025 | 11:38 AM
streborx's Avatar
Top Answer: 1
G550
Sorry -- I think I misunderstood you. I thought you were having difficulty emailing the inspection reports. I haven't worked with the diagnostic records, but I'll take a look and see what I can find about recording/printing results.
Old Jul 15, 2025 | 12:19 PM
streborx's Avatar
Top Answer: 1
G550
Have you tried using the "Image" function? This lets you capture screens and email them.
Old Jul 16, 2025 | 04:18 AM
ygmn's Avatar
2015 E400 Sedan
ASK Launch by sending them email..
Old Aug 19, 2025 | 01:50 AM
steh-fan's Avatar
2016 GL550
Firmware Upgrade
Hi, has anybody had any issues with the Firmware Upgrade Program V12.12?
All applications update nicely in the background, but for unknown reasons, the Firmware Upgrade is waiting forever on the download.
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
