Trying to get LAUNCH to code Euro ILS
2015 E400 Sedan
I have been playing and found the screen to set but way too many choice nd unsure of what they do.
Under SG-SW-L Left Headlamp
Varient coding
General
My lights by default are shown as 212M ILS SAE
Choice I think will work:
212M ILS ECE LV
212M ILS ECE RV (China) ???
Also lists them for other body W207, W222 vans etc.
Th one that says China I think not but curious what it does.
So anyone change to on of these and what did it do?
Of course you have to do Right Side as well
Varient coding
General
212M ILS ECE LV
This may help. You must have the correct hardware. Do you have Option Codes 608 and 640?
Varient coding
General
212M ILS ECE LV
Varient coding
General
212M ILS ECE LV
If your car doesn't have option codes 608 and 640, you're SOL.
The notes in this video got it done for me!
2015 E400 Sedan
Yes I have 608 & 640 and about everything else they offered in a 2015 W212. Them E400 came loaded.
CRASH;
Did you change all those other ones in the video?
Did you get ILS to work using the Launch scanner?
I amnot wanting to be the first Test subject on this - just trying to see if anyone else got ILS to work using LAunch and if I am on correct path
CRASH;
CRASH;
CRASH;
I changed all the same coding as outlined in that video. It helped me to copy/paste the notes from the description to google translate or similar, since the launch creader has most item names in English and I only know enough German to get more beer/sausage/schnitzel.
The variant coding menu structure and general layout is a bit different with the launch scanner. Go carefully though and you’ll find it all. I’ll grab some screenshots of my coding later if I have a chance.
Wish I’d thought of this sooner but in theory you could code one headlight, backup that coding, then apply the backup to the other. Might work. If this was set up like VAGCOM or OBDEleven on VWs that’s what I’d do; just copy the hex string.
GuestFromTampa (04-17-2024)
I went back to grab screenshots of how the coding is arranged in Launch creader. Turns out every setting stuck except for the general setting for headlamp style! Went for a nighttime drive and confirmed the lights are function as regular automatic high beams as before. Every other neceesary setting took the coding change. The plot thickens. I sent a feedback request to launch. Will see what they say.
Left headlight general setting didn't stick
Right headlight general setting stays on SAE
2015 E400 Sedan
Did you make changes in the order of the YouTube vedamo method?
I also took his written notes and put into word processor and translated as best as google and MS can, but I have no idea if those two translators did it correctly since I know from experience tchnical terms can get translated wrong.
I will try to play with it this weekend - after the Honey doo list is done and I get my time.
Lets keep this alive until someone gets it to work and then documents what has to be done for all the others
Remember, in the video, he changes a whole bunch of things, such as settings for each headlight, the front camera, and the instrument cluster, and maybe something else. It made my head want to explode.
2015 E400 Sedan
Yeah and he posts what he did:
I translated to English:
CGW231
2. VCD 02 global variant coding
Intelligente Fernlichtsteuerung "turn off" = Intelligent high beam control
Intelligente Fernlichtsteuerung Plus "Turn on" = Intelligent high beam control
Hard Reset
IGW212
1 5.VCD EVC CfgBit 65 96
628 INTELLIGENT HEADLIGHT CONTROL PLUS (IHC+) "turn ON"
608 INTELLIGENT HEADLIGHT CONTROL "Turn OFF"
2 6.VCD EVC CfgList 01 0C
Headlamp Style 640 HEADLIGHT UNIT LED W DYNAMIC LIGHT SYSTEM SAE RHT - Change to "642 HEADLIGHT UNIT LED W DYNAMIC LIGHT SYSTEM ECE RHT"
Hard Reset
IC204
5. VCD 05 Variantenkodierung Intelligent Light System (ILS Available) "Turn ON" = Variant Coding
6.VCD 06 Menueaktivierung Intelligent Light System (Menu ILS) "Turn ON" = Menu Activation
Hard Reset
HLI-FL212 and HLI FR212
3.VCD Fahrzeugdatensatz Allgemein - Daten 3 212M ILS SAE Change to "212M ILS ECE RV" Vehicle Data Set General
4.VCD Fahrzeugdatensatz Autobahnlicht - Daten 4 nicht aktiv change to "aktiv Fzg mit ALA Hella" Vehicle Data Set Highway Light
5.VCD Fahrzeugdatensatz Erweitertes Nebellicht - Daten 5 nicht aktiv change to "aktiv Fzg mit ALA" Vehicle Dataset Extended Fog Light
8.VCD Fahrzeugdatensatz IHC - Daten 8 IHC aktiv Hella change to "IHC plus aktiv Hella" Vehicle Data Set
9.VCD Fahrzeugdatensatz LDC - Daten 9 212M ILS SAE change to "212M ILS ECE" Vehicle Data Set
10.VCD Fahrzeugdatensatz LUC - Daten 11 ??? change to "212M ILS ECE" Vehicle Data Set
14.VCD Schrittmotorparameter ALA - Daten 16 Hella VarioLED SAE change to "Hella VarioLED ECE" Stepper Motor Parameters
16.VCD Schrittmotorparameter VLA - Daten 18 ??? change to "Aktorvariante Hella Haltestrom 1" Stepper Motor Parameters & Actuator variant Hella holding current”
Hard Reset
Hard Reset
IGW212
Hard Reset
IC204
Hard Reset
Hard Reset
It does work a bit differently with launch’s interface since you’re doing each item in a module one at a time, vs the way it seems to go in Vediamo which is writing all the code to the module at once. Not sure if that is a factor.
NB I didn’t change anything in the stereo camera. It was set to IHC/IHC+ already.
Of note in the stereo camera, I found it had traffic sign assist available for the US(but not canada, and I couldn’t change the coding. augh!). So you should be able to activate option 513 sign assist. I did but it just shows a dashed line on the little speed limit indicator. Which makes sense since there is no data.
2015 E400 Sedan
DONE and it works just so many variables to change and then you do it again for RH light.
I got the menu to pull up and turned on then sat in garage and well no issues.
Will confirm with test tonight.
FYI: I did have battery charger on battery the whole time took like 30-45 mins as after every variable change you have to save and then wait.
Pretty much take the info that guy in the YOU TUBE wrote, and I copied above and go down the list and find the right module.
I can say the Second module list is FWGW or something but was CHASSIS Gateway.
He has HLI-FL212 and I have SG-SW-L for LH headlamp module.
Few different English words as I guess the Launch coder use a different translator.
Yours may be different as sometimes he uses English word for NO or YEs and then on Launch you get German so take your time make sure you have them all before changing them.
WI am attaching my revised word doc I made after going thru it to find everything.
I know I messed up, but it was close enough for me to figure out. Think I forgot a few words here and there.
Here is copy and paste of my text:
CGW (Central Gateway)
Global Variant coding
Variant coding
Variant coding
Intelligent high beam control – Set to OFF
Intelligent high beam Plus control – Set to ON
FWGW (Chassis Gateway)VCD EVC CfgBit 65 96
608 INTELLIGENT HEADLIGHT CONTROL – Set to OFF
628 INTELLIGENT HEADLIGHT CONTROL PLUS (IHC+) - Set to ON
VCD EVC CfgList 01 0CHeadlamp Style - Set to HEADLIGHT UNIT LED W DYNAMIC LIGHT SYSTEM ECE RHT
IC (Instrument Cluster)Variant coding
05 Intelligent Light System (ILS Available) - Set to ON
06 Menu Activation Intelligent Light System (Menu ILS) - Set to ON
SG-SW-L & SG-SW-R (Left & Right HeadLamp) (complete Left first then Right)Variant coding
Vehicle Data General
Datem 3 = 212M ILS SAE - Change to 212M ILS ECE RV
Vehicle Data Motorway Light
Datem 4 = No Active – Change to ACTIVE W/ ALA HELLA
Vehicle Data Extended Foglight
Datem 5 = Not Active – Change to ACTIVE W/ ALA
Vehicle Data - IHC
Datem 8 = IHC Active Hella – Change to IHC Plus Active HELLA
Vehicle Data -LDC
Datem 9 = 212M ILS SAE – Change to 212M ILS ECE
Vehicle Data - LUC
Datem 11 = 212M ILS SAE – Change to 212M ILS ECE
Stepper Motor ALA
Datem 16 = Hella VarioLED SAE – Change to HELLA VarioLED ECE
Stepper Motor VLA
Datem 18 = ACTUATOR VARIANT HELLA HOLDING CURRENT 1 (Double Check this; mine was already set to this))
GuestFromTampa (04-21-2024)
What does your variant coding look like after changing? Did it stick, or does it look like mine where one headlamp shows a dash, and the other shows SAE still, despite changing(see my previous post with screenshots upthread)?
2015 E400 Sedan
I did go back when I was doing it after a change to see if it stuck and those I checked randomly seemed to stay.
My test drive was interesting.
As I first drove with it off and putting on Auto High (stick forward) really did nothing. not sure what it is supposed to do when youhave ILS off and in auto highbeam mode.
Lights still turned with steering wheel so that is good.
Pull stick and flash to pass still works.
Then turned-on ILS via instrument cluster using steering wheel controls - NEver went into high beam like flash to pass bright.
2 different cars were heading towards me on highway and nothing happened.
I can see dip in light beam though all the time for this car coming at me - Never changes.
Confirmed this pattern on the garage door.
So will connect today to ensure all stuck and I got them right.
Wish there was a way to test in daylight as my garage is not dark enough due to windows right next to my car and well...
ANyone have a way to test in daylight to confirm they work?
Ps I Did finally check my codes and found I have I think - Memory fading - a rear radar sensor short to ground issue and this is why my Parktronic does not work.
Heck I have never used Parktronic once or tried to as the little blue P sysmbol has never showed its ugly face - maybe now I have reason - Will search this and find what peeps did as well as confirm whatever codes I hve today before checking lights.
Anyone else trying this?
I will check today if time permits.
RE: rear radar sensor issues, my car had intermittent blind spot warning errors and radar sensor errors when I bought it (2016 E63S), only started popping up on the long drive home. Nothing in PPI. Dealer found corrosion in the rear blind spot sensor connectors and parking sensor connectors. Blind spot sensors and harness for the blind spot warning and parktronic sensors replaced under warranty.
It's a known issue on a few models. I guess it's bad enough for MB to cover it regardless of age.
2015 E400 Sedan
SG-SW-L shows -
SG-SW-R shows original 212M ILS SAE
Only these modules I checked all the others.
I wonder if another module/Variable etc needs something coded before doing the headlights?
When I cruise thru I see things that I do no understand like it says I do not have say lane keeping but trust me I do just keep it turned off.
I will send email note to the peeps I purchased from on amazon.
2015 E400 Sedan
Maybe someone with a launch could connect to someone who has a working ILS Euro headlamps coded in their W212 and then check to see if anything is different from my list and/or has more things coded.
2015 E400 Sedan
Got my reply and some homework but ask others with this funky issue of not saving to read and follow up.
Figure the more who report the more likely they are to fix.
FYI: I purchased on Amazon:
Link to unit which shows supplier:
Supplier email - and they have replied during China Business hours every time and is in my inbox the next morning after I send them something:
Lifetime free user support: ediagtools@hotmail.com
My supplier email about this issue:
And the attachment is below as PDF.
The more that submit the more attention.
Amazon.com: LAUNCH X431 Elite 2.0 Pro Bidirectional OBD2 Scanner Fit for Mercedes-Benz MB Sprinter Maybach,2024 Full System Diagnostic Scan Tool, All Reset Service, ECU Coding, Auto Vin, Lifetime F-Ree Update : Automotive
The problem you mentioned about the device not saving data after vehicle coding is performed, we have understood. To better solve your problem, please provide vehicle diagnostic feedback. This function enables you to feedback the diagnostic issues to LAUNCH for analysis and troubleshoting.
Please refer to the attached document for detailed steps on vehicle diagnostic feedback. In addition, when submitting diagnostic feedback, please attach the file of diagnostic record. After submitting the diagnostic feedback, we will send the SN code of the product to the technician. The technicians will search the problem you submitted based on the SN code. And please send us the SN code. The product's SN code is on the back of the tablet.
JettaRed (04-26-2024)
JettaRed (04-27-2024)
2015 E400 Sedan
Got word back and does not look good unless more peeps complain and ask for a fix.
I sent them link and text from the You tube guy who used Vediamo to program.
I say the more who ask the more likely they will actually fix this one issue in those 2 modules.
Thank you for your reply.
I have sent the attachment to the engineer. The engineer provided feedback that the software of this device is the same as the original factory. However, LAUNCH Company currently does not have the information on unlocking the hidden function, so it is not clear if it needs to be combined with another projects to activate the intelligent lighting system. They suggest referring to the original factory's unlocking hidden information. In addition, there are currently no other solutions available.
Any questions, please feel free to contact us. And if you need to make a refund, please provide the order number.
2015 E400 Sedan
I will be relentless in asking them to fix this and hope others are as well.
Latest
ANyone have info I can send them to help them fix their software so it will save these 2 variants.
I even told them to go find a W212 with LED lights and try it themselves.
Explained how China has their own version of this ILS..
SO CLOSE to this working yet so far away.
Latest
I have submitted all the information you sent to the engineers and consulted them again. They feedback that your operation is no problem. However, since LAUNCH company does not have the information to unlock the hidden function of the vehicle at this time, it is not clear which part of the process has caused the problem that prevents the regular content in the left and right modules from being saved. They suggest referring to the original factory's unlocking hidden information.
I really want to help you solve this problem, but since we do not have detailed information about this feature, there is no other solution at this time. I am very sorry that I cannot provide you with other useful assistance.
