Timing cover
Timing cover
Just wondering if this cover has some type of silicone or gasket on it? It seem that there is something on it.
See the different color
Notice the color difference on the inside. I have tried to clean it but nothing. I just dont want to put this back together and the gasket doesnt seal properly
Received 1,913 Likes
Probably a seal required - not a gasket - see this thread for similar
https://mbworld.org/forums/w212-amg/...over-leak.html
Have you tried acetone or steel wool?
it has the black gasket maker because i had to clean it off the engine but the timing cover had no gasget(black thing from mercedez) on it
Peter, i appreciate your help. Thank you
PeterUbers (05-02-2024)
Yes, I just resealed my upper covers not long ago . New sealant will not adhere well to this existing grey coating . I found the red scotchbrite pads removed it pretty easily. If it's left on the covers , they will weep again shortly.
Jtaveras13 (04-30-2024)
These covers are sealed to the head with Mercedes loctite black gasket maker. Follow the sealing pattern. I used a brass brush to clean the surface, followed by brake cleaner and finally alcohol or acetone. Improper prep and the Mercedes gasket maker will fail. On another note I’ve used reinzosil with much success as the cure time is much better. It’s not preferred by all but is a very suitable substitute. The Mercedes stuff can take a week to cure to be able to be driven, literally. Stay with a small bead and you’ll be good with whatever cures the best imvho. I can not tell you how many times I’ve had to redo jobs with Mercedes gasket maker that never cured as it needs warm humid conditions and basically does not work in the winter in a ungaraged scenario. Good luck.
The following 2 users liked this post by Baltistyle:
Jtaveras13 (04-30-2024),
OldManAndHisCar (05-01-2024)
Does anyone have the pattern on how to apply the gasket maker?
Have it soaking in goof gone for 45min and nothing. Wtf lol.
mbwillgrubs (05-01-2024)
Yeah you'll need an abrasive like wool or brass brush - it's time.
Jtaveras13 (05-13-2024)
New covers have the same grey type coating on them. I bought a new one. I used brakecleaner & a red scotchbrite pad. Took some elbow grease but it comes off.
Mb oem sealant - I let it cure for 24hrs. About 10k mi. Later & they're bone dry.
Jtaveras13 (05-02-2024)
I'm so happy that this comes from factory. Thank you so much. saved me some money
Sorry fellas. I'm back with another issue. I finally got all the parts and started putting everything back together.
I was able to remove both left turbo coolant lines.
Here is my problem. I was only able to do get the lower turbo installed. I cant seem to find a way to install the the top line. Any help would be appreciated. Thank you.
Does anyone have any pics of how the lines sit on turbo housing? Bottom one is flush but top one maybe has a 1/4 inch from being flushed on housing. Is that normal? I know the 2 brackets meet from screw placement, is this the reason?
If it came from factory, why take it off. Maybe a better question is why would the factory put that on to just take if off.
