C63 Black Series - RennTech tune - will it go over 200 mph?
Hello! So, I have a RennTech ECU tune on the way, and I was curious if anyone knows if the slight bump in power, and the elimination of the speed governor, will allow it to go over 200 mph in a safe and closed environment. Prior to the tune, the car seemed to be able to get over 180 mph without much issue at all, so I'm wondering if the gearing and other factors will let it exceed the 200 mph barrier.
Has anyone done it or have experience with it on a U.S. spec C63 Black Series?
Thank you,
Thank you,
duuder (06-17-2024)
If you have the Aero package that won't help with a top speed trial. Regardless, I think it's probably top out in the 190s somewhere compared to other AMGs with their aerodynamics and power levels. 🤷♂️
'12 C63BS "SlickTop", '08 CLK63BS, '16 E63S wagon, '12 CLS63, amongst other non-Merc toys
what hardware mods are you pairing the software to Mitch?
with everything else stock, you'll have zero gain in peak power, OEM software already maxed out the peak-power potential of the OEM hardware on our BS..
you might see some gains over the power-band & along the curve on dyno, but no peak power gain.
There is a video from Carwow where a BS went 203 mph I believe, but it was supercharged and didn't say what tune, I believe other then the supercharger it was stock. Without a supercharger it should still be able to go over 200, but would take a long runway I believe.
I'm hoping to hit 170mph in a half mile run with ~740chp/625whp, but need to dial in some cooling mods and a better tune first.
