Add 1qt oil (after solenoid fun)
Did a search, didn't find anything jump out at me.
I am about 4000mi since I removed my solenoid (that has nothing to do with this, other than confirming it did not happen sooner). Curious, how long should one go with the light on? In my instance I was about 25mi from home on a Sunday night in "no mans land" FL. Even had I stopped at the next gas station they were not going to have 1qt of Liquid Moly 5-40......
In the common thoughts...is this a "OH **** STOP THE CAR!!!!!", a just drive home and dont race it...or what? I suppose I could keep a qt of oil in my spare tire compartment......
Funny thing, I check my oil all the time. I did see it was a bit lower towards the bottom end...not enough of a change to make me want to was 3' to get more oil.
Received 1,477 Likes
I keep a 12-quart case in my trunk to always be prepared! (j/k)
I do keep a quart in the engine bay, usually in some nook or cranny that will hold it. I do this mostly to have oil warmed up a bit in the winter months so I'm not pouring freezing oil into a hot engine.
WRT adding something other than what you already have, I would do that before running the risk of a seized engine.
By the way, where is "no man's land" in Florida? Miami?
Growing up in Ft. Lauderdale, "no man's land" were the swamps west of State Road 7, where alligators, wild boar, and deer roamed freely. But that was over 50 years ago.
They're a massive stretches of nothingness. If you get between Ocala and any direction you can have about 45 minutes to an hour drive before you see anything but a hillbilly gas station. Between Tallahassee and Pensacola is the same. Then you have the mess that is going through the Everglades South to miami.
I forget how southern northern Florida is. South Florida was strongly influenced by northern "Yankees" and Cuban refugees. North Florida was strongly influenced by the South. But Central Florida never really developed like it was expected to. 🤔
kevm14 (06-22-2024)
From the manual:
Received 2,392 Likes
PFL205.064 with M276.823
It's not an immediate worry about the engine seizing, so more of the drive home to fill & don't race it. I keep a quart in the trunk just in case, although I never get this warning anymore since I switched from Mobil1 to LiquiMoly. This reminds me that it is time to change the oil.
From the manual:
From the manual:
Another question is, I always ask myself but never have a definitive answer. Is it recommended to have the oil level at the middle of the min and max mark or as close to the max mark as possible?
I understand that oil expands when hot and excess oil is just as bad if not worse than having low amount of oil. What is the consensus on this one? Thanks.
Received 1,546 Likes
2008 E350 (W211 @170K), 2012 ML350 (W166 @119K), 2014 E350 Sport (W212 @96K), 2015 ML350 (W166 @92K)
There is a sensor, but does it report the level in the cluster? or can it be coded? do not know
EDIT: Added the link for verification of your specific model fitment
https://www.fcpeuro.com/products/mer...891011#fitment
T
https://cimg0.ibsrv.net/gimg/www.mbw...1b4393d16a.png
juanmor40 (06-21-2024)
My take is (being an engineer) that my colleagues somehow already accounted for the expansion, if any, of motor oil. If not, they did not do their job right.
Therefore, I will stay up "to Max" within margin of error.
https://cimg0.ibsrv.net/gimg/www.mbworld.org-vbulletin/1563x486/image_e968fbf9063778a83d64ae44649a542a8132ef81.png
I think the real problem with overfilling the oil is if you add WAY MORE than the max level, say maybe a quart too much, and the crank shaft spins below the oil level and starts frothing the oil. The oil pump cannot provide sufficient oil or pressure when that occurs, and you could have an oil starvation situation, as contrary as that may sound. Kinda like drinking the foam off a beer but never getting to the beer itself. What fun is that?
The following 2 users liked this post by JettaRed:
CaliBenzDriver (06-21-2024),
I'm trying to remember, but I think my 2004 SL500 (no dipstick for measurement, but one to suction out oil) would give a message when overfilled. Can't remember if it was passive or active, meaning whether it would pop up automatically or only when you electronically checked the oil. I know it would tell how many liters were being measured. But hey, that was on a 20-year-old car.
