SL/R232: Handle swipe to open
I just discovered that (In addition to other methods) a finger/thumb swipe to the left or right on the lower (painted) portion of the door handle will make the handle present itself--a really slick method.
Am I the only R232 SL owner that did not know this?
Received 2,836 Likes
Unless... I am understanding you wrong.
I wouldn't say you are the only R232 owner that did not know this but this was mentioned almost all times in car reviews of W223, R232, EQS and EQE both sedan and SUV, C236. Your delivery specialist should had went through this, if you are not the type that watch youtube reviews. So they didn't do their jobs properly.
The point of my self-deprecating post was to alert others who might have also missed it.
And my salesman did not tell me. He also told me that the only way to open and close the convertible top was the annoying touch screen hold method..I showed him the double physical button press method I gleaned from a Doug Demuro review.
I did watch many R232 reviews but must have missed it.
Received 3,989 Likes
2019 C63CS
Thing is you don't actually have to swipe it, but most people don't realize that the MB door handles have two sensor areas. You can touch the outside of the handle, or the indented square. I never use the square. I always touch the larger handle sensor area to lock for example. BTW, this is all documented in the owner's manual.
California John (08-26-2024)
I kind of knew about the feature of extending the retractable door handles with a finger touch. But I never use it. I don’t find it useful. Even if you extend the handle, the door is still locked, so I just use the remote to extend and unlock.
I locked myself out of the car a few times. I left the car parked with the engine running for 2 minutes, when I came back the handles didn’t pop out at all. I had the key in my hand and nothing. I tried unlocking from the key, only the trunk worked. After a few minutes I tried the passenger s door and that one worked. Very tricky sometimes…
What do you do if it doesn’t open?
2019 C63CS
I see, basically aiming the key at the box/square to use that feature right?
2019 C63CS
No, place your finger on the square and keep holding it there until the windows/sunroof/panoroof opened/closed. I mostly use it to close everything after parking if I had the panoroof open. Place the finger on the square until everything is closed. To open it I usually do it from the key fob as I'm walking up to the car. Point the key fob towards the car, press and hold the unlock button. Sometimes takes a couple of attempts to succeed. You have to be somewhat close to the car. It doesn't allow it from far away.
The following 2 users liked this post by superswiss:
California John (08-27-2024),
Raulr (08-28-2024)
it even showed that you can slightly pull the handle to do the summer convenience feature without the key pointing at it.
Don't leave the car running. My understanding based on a similar experience another forum member had and a subsequent conversation they had with Mercedes customer service, they've added a safety feature that if the car thinks somebody is inside, either by the engine running or detecting a key fob inside of the car, it retracts the handles and doesn't release them to protect the occupants and/or the car from being jacked. Not sure what exact procedure you have to follow to get back in, other than somebody from the inside releasing the door handles via the unlock button.
Anyway, the car was no locked, just the handles disappear.
The trunk still opens, so if someone is trying to steal stuff they could still do it.
But considering the key was not in the vehicle but in my pocket, I still wonder how do one gets back in his car if lets say he just gets out for a second to grab something. And then back in. I forgot my phone in the house, left the car running a bit and when I came back tot the car I only got to enjoy the exterior beauty of this beast.
I have to mention that the app will not open any doors while the engine is running. The door will eventually pop out the handle, it’s very interesting how and when haha
by the way, on the SL63 E is very easy to forget the engine running, cause it’s just sitting ready on the electric motor, you don’t usually hear the engine while stoped or at low speeds..
I see.
