Front SAM module replacement
Does the car start, run, warnings popping up on the dash, fault codes showing when scanned with OBD scanner?
I think if you got a sam with the same part # and then looked up each cars vin #'s to make sure they have the same options you have a better chance of it being plug and play.
Other issue is no "power windows" !!!
Looking for Help too
thanks for that.
I got someone to code it and I don't think he could do it.
The boot open button opens the driver side window, looks like coding issue to me
Yeah the plug and play option is ideal. However, by luck I obtained the newer (used) one for free.
I wonder if anybody has any luck with that EEPROM switch over.....🤔 or how can I obtain Xentry, Vediamo or DTS Monaco software?
Any laptop, Vediamo from internet, Openport interface will be the cheapest solution, if the fuses and relays are on the same positions like in the old SAM....
I am in a kind of sticky situation here. I bought the part from overseas and its for LEFT HAND DRIVE vehicle where as mine is Right Hand Drive.
Tried SCN coding both online and offline and it still is not 100%.
I cannot get the windows to work.
Anyone had similar experience ?
Thanks,
Rahul
