Old Jun 29, 2015, 03:28 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
DIY: Audio 10 Install Pics / W203 ('01-'04) Center Console Removal Instructions
Rating: Thread Rating: 9 votes, 5.00 average.
Old Jul 29, 2002 | 04:36 PM
session's Avatar
2007 VW GTI
I promised I would post all of my pics of the install, so here they are, accompanied by the instructions to go with each.
Firstly, the "before" pics of the unit itself.
Old Jul 29, 2002 | 04:37 PM
session's Avatar
2007 VW GTI
Back view
Old Jul 29, 2002 | 04:41 PM
session's Avatar
2007 VW GTI
Top view
session's Avatar
2007 VW GTI
The "before" console
Old Jul 29, 2002 | 04:45 PM
session's Avatar
2007 VW GTI
OK, for the install you'll need a thin flat-blade screwdriver, a long T20 torx screwdriver, a pen light and about 40 minutes.
You'll first need to undo the silver tabs on the bottom of the silver console trim. To do this, open up the ash tray cover about halfway and shine the pen light into the gap. You will see on the far left and right sides two silver clasps holding the trim in place. Take the thin screwdriver and pry these clasps down; they are hinged in the front so pry them from further back. (I don't have photos since the gap is too small)
Next is the removal of the air vents.
Take the thin screw driver and gently push the bottom plastic tabs on the left side of each vent to the right. While doing this, push the vent upward.
Old Jul 29, 2002 | 04:47 PM
session's Avatar
2007 VW GTI
You should be able to now turn the vents up even further than normal, creating a gap below them as seen below.
Shine the pen light into this gap and you should see two torx screws on the far left of the left vent and the far right of the right vent. Be sure to close the white dials on each vent (turn all the way down) so you won't lose the screws. Once this is done, remove the screws using the torx screwdriver.
Old Jul 29, 2002 | 04:50 PM
session's Avatar
2007 VW GTI
Now, you need to turn the vents down to create a gap on top. Gently push the top plastic tab to the right while pulling the vent down and you should create a gap as seen here.
Shine the light into this gap and you will see two "hooks" on each side of the vents... You will need to use the thin screwdriver to pull these down. They have teeth to hold them in place; pulling them down is a bit tricky so be sure not to damage the teeth.
Old Jul 29, 2002 | 04:53 PM
session's Avatar
2007 VW GTI
Here is a shot of the aforementioned "hooks" once the unit is removed. Notice the teeth.
Old Jul 29, 2002 | 04:54 PM
session's Avatar
2007 VW GTI
Once these hooks are pulled down enough, you can simultaneously pull out on the vent unit and pull it out of the console. Be sure not to damage the trim when doing so, but this may take a bit of force.
Here's what the back of the unit looks like.
Old Jul 29, 2002 | 04:56 PM
session's Avatar
2007 VW GTI
Here's what the console looks like when the vents are removed.
Notice the metal parts attached near the screw holes to hold the console aluminum trim in place. Pull out on the trim and it should come right off since nothing is holding it in place (you already removed the screws on top and the metal clasps on the bottom)
Old Jul 29, 2002 | 04:58 PM
session's Avatar
2007 VW GTI
Here's a shot of the aluminum trim being removed.
You may have to be careful in working the trim around the shifter. Mine took a little wrestling to remove properly while the car was in Park.
Old Jul 29, 2002 | 05:00 PM
session's Avatar
2007 VW GTI
Here's the cables connected to the back of the climate control unit. You may remove these to make removing the trim easier, although I didn't.
Old Jul 29, 2002 | 05:02 PM
session's Avatar
2007 VW GTI
Here's the cable connected to the emergency flasher button.
Old Jul 29, 2002 | 05:04 PM
session's Avatar
2007 VW GTI
Console explosion!
Once the trim is removed, unscrew the two torx screws on each side of the radio and remove it by pulling straight out.
Old Jul 29, 2002 | 05:08 PM
session's Avatar
2007 VW GTI
Once the radio is removed, unplug everything from it. These two plugs require some force and feel like they won't come off, but trust me they will. Just pull straight out. (Thanks Buellwinkle )
Old Jul 29, 2002 | 05:10 PM
session's Avatar
2007 VW GTI
Here's the other plugs minus the one that's obviously been removed. They are fairly easy to remove; just press the tab on the left side and pull out.
Old Jul 29, 2002 | 05:12 PM
session's Avatar
2007 VW GTI
It's smooth sailing from here on out. Plug the cables into the exact same positions on the Audio 10 and slide the unit into place. The plastic tray below the radio just hangs onto the bottom -- it's pretty obvious how to connect it. Be sure to balance it while pushing the radio back into the hole.
Be sure EVERYTHING is plugged in, and you'll be set to test it out before putting everything back together. This is the first boot of my audio 10!
Old Jul 29, 2002 | 05:13 PM
session's Avatar
2007 VW GTI
Now, screw the radio back into place.
Old Jul 29, 2002 | 05:14 PM
session's Avatar
2007 VW GTI
Now, do everything essentially in reverse. Put the console trim back in place and push the silver clasps on the bottom (in the gap on top of the ashtray) back into their positions in the trim. This may take some work; it's hard to see in there to line them up properly. They should just snap back into place.
Old Jul 29, 2002 | 05:17 PM
session's Avatar
2007 VW GTI
Now slide the air vents back into position, making sure the metal rod slides through the hole in the red plastic piece in the middle (the air distribution rod). The plastic hooks with teeth on top should clip back into place. Just repeat the procedure to turn the vents up (creating a gap on the bottom) and screw in the two torx screws you removed. BE SURE THE VENTS ARE CLOSED SO YOU WON'T LOSE THE SCREWS!
After this is completed, turn you car on and test everything out. Enjoy your Audio 10!
Old Jul 29, 2002 | 06:04 PM
hawk's Avatar
Nice! I just did this yesterday (minus the installing audio 10 part). Just be careful of the hooks below the center console/above the ash tray. They wouldn't lock back into place after the install and I kind of scratched the aluminum cover of the ash try part when I was trying to close it.
And yeah, it might be better to turn the key to "on" and move the shifter from park to like neutral.
Great pics, I wish I saw this BEFORE I took mine apart! =)
Old Jul 29, 2002 | 06:05 PM
TimmyC230boy's Avatar
From: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
C230 Sports Coupe
Thats great info, how long did the install take?
Old Jul 29, 2002 | 06:07 PM
session's Avatar
2007 VW GTI
the install took about an hour and a half, including the time to go to sears and get the T20 screwdriver and to ask Buellwinkle how to remove the two plugs on the left side of the stereo.
install time itself takes about 40 minutes the first time, but i could do it in about 15-20 now.
Old Jul 29, 2002 | 06:11 PM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
Great pics - just one note of caution - the black connector with the orange (two) cables is fibre optic, so you need to take care of it as fibre optic mustn't be bent much to far (or crushed). "session" is a bit close to damaging it in that photo ...
- its best to remove it first before you start twisting the radio [and fighting the other connector] - theres a bit half way down one of the long sides that you push on to release the clip - and of course install it last and be careful it doesnt get crushed when putting the radio back in
- if you dont have CD/Teleaid etc, you may not have that connector at all -
Cheers
R
Old Jul 29, 2002 | 06:16 PM
session's Avatar
2007 VW GTI
that cable is in the exact position it was when i pulled the radio out -- the cable sticks out to the right on its own. however, it is good advice to be careful not to bend it. i sure was (that's why it's missing in the next photo).
i don't have the cd changer nor teleaid, but i still had that cable.
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
