SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Wood Panels around seat switches
Old May 18, 2006 | 08:56 PM
l5foye's Avatar
I notice the wood panels which are round the seat switches are coming away leaving a gap or edge visible. What is the best cure?
Old May 23, 2006 | 01:34 PM
jjay911's Avatar
1991 300sl 5 speed manual
Best cure
THey were glued on from the factory. I have the same issue right now. Im looking for some type of adhesive for intior. or I may have to take it to an appulstry shop. IF anyone can recomend some type of adhesive that would be great. JJ
Old May 23, 2006 | 02:19 PM
Lincoln's Avatar
97 SL500
You need trim adhesive which is really a contact adhesive. You spray or brush (depending on which type you buy, I like the spray) some on both surfaces and let it cure for about 5-10 minutes then you stick 'em together. I don't remember the name of what we used at the car stereo shop but it worked great. I get it at local supplier (J&J Supply) that sells automotive carpet and vinyl.
Old May 24, 2006 | 02:27 AM
LeaUK's Avatar
'93 SL500
Mine do the same and look rather tacky as the door closes as they bounce in/out.
Regrading adhesive, you will need something that can be detached without damaging the lether behind as if/when you need to remove the door panel these wooded covers need to be removed.
I would suggest something from the enormous range at 3M
Lea
Old May 24, 2006 | 09:47 AM
rellik's Avatar
mercedes
they should have metal clips on them
you can go to your dealer and show them the metal clips and get new ones for a few cents as the old ones may have lost their spring
were they supposed to be glued in initially?? i didnt think that
on mine also some of the plastic slides that hold it to the door have snapped also, im looking to fix them soon, hopefully we can cure this problem
ill post new info if i find anything
Old May 24, 2006 | 12:23 PM
b4mmy's Avatar
500 SL R129, Blue - 1991. Mini Cooper S, Works Kit Silver - 2007. Mitsubishi FTO, Silver - 1996.
Reliks right, they are clips and mine have snapped as well, if anyone ever finds the part number could they post it up?
Old May 24, 2006 | 01:38 PM
jjay911's Avatar
Wow
I work for the dealer and they had know Idea there were clips. I will have to take mine off and lnspect it. JJ
Old May 24, 2006 | 08:32 PM
rellik's Avatar
mercedes
i wish they gave me part numbers, they jus looked it up in the database
ill check my copy of EPC to see if it has em
Old May 25, 2006 | 12:42 AM
MorrisWu's Avatar
300SL-24 1992 White
I have done the repair, simply to change the plastic clips and cost little money and time. I 've got the parts number for both sides, and also the procedure pictures. My friends, DO NOT GLUE IT! wait for my pictures coming soon.
Old May 25, 2006 | 02:35 AM
LeaUK's Avatar
'93 SL500
Blimey, I've taken those door panels off over 4 times now and completely forgot they were clipped in...
Old age has effected my memory more than I realised!!!
Cheers for the tips.
Lea
Old May 25, 2006 | 04:36 AM
b4mmy's Avatar
Ok, thank you.... can you post the part numbers plaese Morris.... I think my 1991 has metal clips though
Old May 25, 2006 | 08:25 PM
MorrisWu's Avatar
300SL-24 1992 White
Please come in my photo album to share.
(I would find more photos to add in later.)
http://tw.pg.photos.yahoo.com/ph/mhw...?.dir=/cac5scd
Old May 26, 2006 | 03:56 AM
b4mmy's Avatar
Thank you Morris. These are the clips we need the part number for, the are metal and springy....
Old May 26, 2006 | 04:28 AM
MorrisWu's Avatar
300SL-24 1992 White
I am sorry, there is no any number on it. But, if the clips drop, they must be inside the car or limited inside the door panel. Or, it would be not difficult to make a duplicate.
Old May 26, 2006 | 02:31 PM
kerrypacker's Avatar
1998 E320, 1994 320 SL,2000 Ford F 150.1997 Gixxer 1100
Same problem here. However, My Dad thought he would help and while I was on vacation, drilled self tapping screws into both sides. Needless to say, he has not been back in my car since then. I had to purchase new ones. Well, not really new, but from a parts car.
Old Jun 2, 2006 | 03:23 AM
MorrisWu's Avatar
300SL-24 1992 White
More photos are post to share:
