SL/R129: No Power to Headlight
My right side headlight on my 1991 500sl does not work. This is an OEM Mercedes HID system. I originally thought that the ballast was bad, so i swapped the right side ballast to the left side to see if the fault would follow. The ballast worked fine. Next i removed the entire right side headlight assembly and hooked it up the the left side connections, the headlight housing worked fine too, the projector lamp turned on. So, next i measured the voltage coming from the right side headlight power connection and there is NO Voltage.
I need to trace the headlamp power back to it's origin, does any one know if there are independent fuses or relays for the HID headlight system?? Or some kind of control module that powers the lights separately? I'm not quite sure where to take things from here.
Oh one more thing, the high beams work on both sides, it's just the HID projector that does not work on the right side.
You also have an additional fusebox in the trunk, but his box has nothing with the lights to do. Central locker, IR-function is among otherts thing placed there.
Problem with SL is Galvanic corriosion on fuses in the fusebox. So start clean up every single one.
Good luck
jori
