SL/R129: Brake light strip bulb replacement
Rocco
1. The whole strip is wedged in behind metal....that does not move
2. You can try to slide it out by loosening the clips from the bottom and then sliding the strip out.....but the strip gets stuck....on the un-movable metal
3. You can push the little pegs that hold the red lens in...pop it out then unscrew the 3 little screws...if you can get them out...and even if you could get them out....the strip still gets stuck...on the un-movable metal.
Or you can just slather some clear sealent around the outside of the lens to fix the 3 cups of water that is always draining into your trunk when it rains.
Hopefully is worked......after 3 weeks fo straight rain in this country....it has not ranied since I (hopefully) fixed the problem.
Hopefully is worked......after 3 weeks fo straight rain in this country....it has not ranied since I (hopefully) fixed the problem.Can be done. Need patience.Simply pull the clips and slide. Guys with body job experience seems to be pretty good at doing this stuff.However, first check the wire on the hinge which attaches to the deck. Mine was broken right there. The constant up and down motion.
Phil
Phil
- The bulbs can be replaced by removing the bulb holder strip from the inside of the trunk. Open the trunk and remove a plastic cap and a plastic panel from the inside trunk lid liner. Two holes will be revealed so you can un-clip the bulb holder at both sides of the light assembly. After un-clipped, patiently remove and wiggle the bulb holder out of the larger hole. If I remember, you need to unplug the wire from the wire supply.
- You can purchase the lens separately, and it clips into the trunk lid. To remove the old one, you can access it from the inside of the trunk after removing the bulb holder. There are numerous clips holding the lens in. Just work your way around the lens and un-clip it to remove the lens toward the outside of the trunk.
