SL/R129: SL600 - what's wrong with these?
Ok, so somehow, I don't even know how, I ran across the crazed rantings of some MB nuts who were obviously brainwashed about blah blah blah V12 blah blah blah great value for the money blah blah blah etc. Here's some of the craziness I read:
http://www.kenrockwell.com/sl/sl600.htm
http://www.mcsmk8.com/99-SL600/SL600.HTM
Unfortunately, I think the brainwashing was contagious as now I find myself checking out car listings from time to time looking for SL600s. I'm unsure yet if it's a midlife crisis going on or if I'm just inexorably drawn to the chance to get a $130k car for so cheap.
I've been doing some reading here and there on the maintenance costs associated with these bad boys and of course the horrific costs of repairs. However, I'm not looking for a daily driver and I'd hope that something I put low miles on wouldn't be breaking all the time. Still looking into things but I was wondering, what are your thoughts on some of these?
http://www.carfax.com/VehicleHistory...|-63|36|82|113
http://www.mandfauto.com/vehicle/307...w-Mexico-87120
http://www.carfax.com/VehicleHistory...22|-12|48|-113
http://www.mercedesoflittleton.com/u...0360d60f4f.htm
http://www.carfax.com/VehicleHistory...F172291&source=
http://www.mazdagreeley.com/used/Mer...6fca6268c5.htm
It looks like they've all had some work and problems. I see one with a bunch of failed emissions... but with cars like this, when you see work after it and it starts passing emissions, everything's good to go?
I assume if I got serious about getting one, I'd want to take it to a MB mechanic to get it checked out. But I mean do any of those carfaxes or pics raise any flags to y'all?
I've also run into V12 S600s, that's basically the sedan version of this car? Or totally different? 'ell, some of those seem to go for pretty cheap too.
Why? Was the market just so finicky that these cars depleted in value THAT MUCH? It's crazy! Normally I'd expect to find them to be nothing but mechanical messes but while repairs seem expensive, it doesn't seem like this car is using crappy parts or designed poorly.
It'll probably be a while until I get one, if I do, as I have to convince the wife that this is a better car to get than a 60's Stingray 'vette. I know someone like me wanders in from time to time and asks the same questions so thanks for humoring me. For anyone with the time, I'd love to hear your thoughts on some of my questions and linked-to SL600s! Thanks!
It would be best to test drive one, if you have the chance, to see the difference for yourself. If you do not find much differences with V8s, then whatever I say is futile. w/ smiles Jimmy
Cheers,
Jeff
Cheers,
Jeff
Always live below your means. It makes life so much easier when you run out of month before you run out of money.
The only "unusual" problem with my SL600 was a clunking in the front end at low speeds whenever braking or accelerating. After being stumped as to the cause (looked at most everything), I knuckled under and took it to a dealer and prepared for the wallet vac to be turned up to 11. It got worse when after a couple hours of diagnosis, they still couldn't find the source and said they'd have to just start disassembling the front suspension until they found the problem (at $110/hour). Luckily, it was found quickly - the bolt-on front braces to stiffen the front end were loose - cleaned the connections and re-retorqued and all is well!
I think you just need to be careful w/ MB service - they tend to jack up prices on R129 V-12's - perhaps just because they can. A good dealer will charge you for actual time and ditch the book rates on these cars - that's a big plus if they have a good experienced V-12 technician.
One interesting story - at 50K miles, the dealer said the spark plus should be replaced on my SL600 (in spite of the window sticker claiming they were 100K mile plugs!). Quoted cost: $850! High cost because of the alleged additional labor on V-12 to R&R interfering parts. I did the work myself - $120 for the plugs and it was the easiest plug change I've ever done - maybe 5 minute per plugs - tops!
Best thing you can do is research similar cars in your geographical area and price it accordingly. You could visit a local CarMax and get an estimate, if they'll approach something that old. At least it would give you a bottom price. If you need to sell quick; price will be lower. Etc. Getting a bunch of R129 owners around the globe to price the car for you is not the prudent way to go. IMHO
Cheers,
Jeff
I appreciate your input.
Why not get them both like I did !
I built a 65 vette convertable and just bought a 2000 SL600.
And I didnt ask the wife for either of them.
IMHO the 600 may be collectible for my grandchildren. The 500, 320, 300 because of production numbers and "experimental" additions on the 600, less so.
The driving thrill captured me years ago, but that has diminished because of my age not the cars! I have exceeded the speed limit in many vehicles over lots of years!
If you are going to keep the 600 in "show" condition, it cost little more that any of the other SL group. That includes my experience with 190, 230, 280, 450, 500, 560's.
IMHO no benz is a "shoe string" collectible.
As for other cars, they are are "kool"
