SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
View Poll Results: Which tuner would you recommend?
EuroCharged
0
0%
Renntech
2
100.00%
Wiestec
0
0%
Kleemann
0
0%
Voters: 2. You may not vote on this poll
SL/R129: ECU tuning for 1999 R129 SL500
Old Nov 21, 2019 | 04:43 AM
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
Hello people,
From experience, who would you recommend for tuning my ME2.0 ECU?
I have swapped out my M113 5.0 engine for a 5.4 M113 AMG N/A one. And need my ECU programmed to compliment the new engine.
Old Nov 21, 2019 | 08:51 AM
FATHERTIME's Avatar
94 SL320 98 SL500 99 SL600 07 SL55
Originally Posted by Ahmed
Hello people,
What do you feel the issue is with the standard ECU . I'm trolling for an engine and car to do this swap .
Old Nov 21, 2019 | 12:34 PM
Ahmed's Avatar
Well. Common sense tells me that with larger bore cylinders and probably longer strokes and different injectors, I might be running lean.
Perhaps ignitions timing needs to be altered. Someone has to tell the ECU all that stuff.
Old Nov 21, 2019 | 07:49 PM
mahunt's Avatar
1997 MB SL600
The ECU is self tuning via the oxygen sensors. Your current injectors probably have the flow to handle the upgrade.
If your engine were lean it would be hotter (tougher to cool) and the plugs would be white. Pull one and hope for a nice tan pattern.
You can probably just drive the car with no worries. What did the other folks that made the same swap do to their car's ECU, probably nothing?
Old Nov 22, 2019 | 08:31 AM
Ahmed's Avatar
That's actually very comforting to know.
Old Nov 22, 2019 | 08:47 AM
mahunt's Avatar
1997 MB SL600
Pull a few plugs, post some pictures and we'll let you know how the engine is doing.
Old Nov 23, 2019 | 11:38 AM
FATHERTIME's Avatar
I'm very interested in making a R129 SL55 In my search for an engine I want to know if there are any cam differences between a M113N/A CL55, ML55 or S55?
Old Nov 25, 2019 | 10:40 PM
mahunt's Avatar
1997 MB SL600
What are the HP/TQ numbers between the 3 models listed?
Old Nov 26, 2019 | 01:37 AM
FATHERTIME's Avatar
Good call thanks. looks like the S55 is the top.
Old Nov 26, 2019 | 04:29 AM
Ahmed's Avatar
I'm guessing the engines are identical, the only thing determining power outputs are the ECU tunes on each. That's pretty much it.
