SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Brake upgrade for 2002 SL 500 Silver Arrow
Old Aug 12, 2020 | 04:41 PM
onjerry's Avatar
'18 AMG SL63, '02 SL 500 Silver Arrow, '17 Range Rover
Any advice or direction to upgrading brakes on 2002 Silver Arrow? Have seen lots of threads on later model SL's, but none on this particular model. Thanks to all in advance.
Old Aug 12, 2020 | 11:17 PM
mahunt's Avatar
1997 MB SL600
You already have the factory OEM upgraded brakes. All R129s built from MY 99 on up have the upgraded brakes.
Pull one of the front calipers off and look on the inboard part of the casting for the Brembo lettering.
You could change out to more aggressive brake pads like Akebono (if the car doesn't already have them).
I consider the upgraded brakes necessary for all the V12 cars built earlier than the 1999 cut-over.
Old Aug 13, 2020 | 05:54 AM
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
Yes that is correct, all 99+ models have upgraded brake calipers.
Your silver arrow has the slotted or drilled rotors too.
It's perfect.
Old Aug 15, 2020 | 08:59 PM
ChrisB's Avatar
1999 SL 500 & 2011 E 550 4Matic
i has read somewhere that the R129 SL was outfitted from factory wth Brembo brakes ... but lost the reference & could not Google it.
i also did not know 1999 was the first year for that.
Lucky me & I know for sure why my 1999 stops very well when jamming on those brakes.
Have had to do that quite a few times in the past 18 years of ownership.
Has never disappointed ...
Thanks for confirming the fact.
Old Aug 15, 2020 | 09:10 PM
ChrisB's Avatar
Sorry - posted twice ... maybe the Moderator can delete.
Old Aug 18, 2020 | 01:56 PM
onjerry's Avatar
Thanks all. I have to replace my disks and pads, was just wondering if there was a bolt on kit that was a bit more aggressive. Maybe as Mahunt suggests, use Akebono pads.
Old Aug 18, 2020 | 03:50 PM
mahunt's Avatar
1997 MB SL600
Go to the dealership (if they are still available) and get the SA rotors. Call your local auto parts store and see if the offer Akebono.
Great bite with little dusting.
Old Aug 19, 2020 | 08:49 AM
Ahmed's Avatar
U upgraded to Zimmerman cross-drilled rotors and textar pads.
Old Aug 27, 2020 | 05:19 PM
R129Workshop's Avatar
1992 500sl Japan version
They are out of production, i managed to find some drilled Zimmermann in Germany, they will be delivered early next week i hope, i´m from Denmark.
I´m doing the brake upgrade right now, you can see my video here.
Old Aug 27, 2020 | 05:58 PM
onjerry's Avatar
Thanks all. I have received my new Zimmerman front rotors which are drilled, and found a set of new OE Mercedes rear rotors. Should have the Akebono pads by this week-end. Will let you know how i works out.
Old Aug 27, 2020 | 06:10 PM
Did you buy oem front pads or Zimmermann front pads ?
How much did you pay for the rear Oem. rotors.
Old Aug 27, 2020 | 06:31 PM
onjerry's Avatar
I purchased Akebono pads, EUR 603 front, EUR 847 rear. OE Mercedes rear rotors were $109.59 each.
