SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: ABS lamp is constantly lit after i managed to short-circuited the plus pole
Old Mar 3, 2022 | 12:57 PM
TheSaint's Avatar
350 SL, R230 - 300 SL, R129 - 1964 Corvette Sting Ray Sport Coupe - Porsche 911 Twin Turbo (sold)
The battery on my 1992 Mercedes 300 SL R129 started to go bad so i had to use jumper cables from a extra battery i placed in the trunk
One evening i was going to use the car i almost managed to place the negative jumper cable on the plus pole on the battery but i saw it just in time and did not put the negative cable on the plus pole in the car
But embarrassing enough when I turned around I managed to slightly touch plus the pole of the battery in the car with the result that the ABS lamp now is lit constantly..
When i managed to touch the plus pole it was just a hundred of a second but that is enough it looks like.
I can not understand that max a second after i saw that i almost mixed up the plus and minus i managed to touch the plus pole
Note that the jumper cables i used have the "safety box" on both wires
Any of my fellow member here have any suggestion on how to reset the ABS warning lamp in the dash?
This since i do not have any pin that is marked ABS in the instructions for the error tool. See the last picture/drawing
The "OBD" connector is the 16 pin type and is placed in the engine compartment. See the picture attached with a red arrow pointing to the 16 pin connector
Here is the 16 pin "OBD" connector in the engine bay on my 1992 Mercedes 300 SL, R129
This is the error code reader i have
The red marked pins is functional and the black pins is empty
Note that the pictures of the 16 pin connector is of the one that sit in my car. Also the drawing that is marked with red pins that is in functional is made by me
Old Mar 3, 2022 | 01:22 PM
Pazo's Avatar
R129.067 (500SL '93), EQE, MGB
Well, I'm afraid your car is the last year without proper ABS diagnostics.
For starters, I'd read & reset all codes anyway and see what happens. Especially pole 14. Check the Overvoltage Protection Relay (OVP). It has 10A fuses and it is known the solders crack over decades. I assume you have carefully checked your fuses - not only visually?
Good luck!
Old Mar 3, 2022 | 04:41 PM
TheSaint's Avatar
Thanks Pazo
So pin 14 is for ABS
Where is the overvoltage relay located?
Old Mar 4, 2022 | 01:27 AM
Pazo's Avatar
Originally Posted by TheSaint
Thanks Pazo
I'm afraid your car is the latest model without proper ABS diagnostics. But some of pole 14 diagnostics are related to ABS. Those who know this better, pls chime in...
Component locations can be found here: STAR TekInfo
Old Mar 5, 2022 | 12:35 PM
TheSaint's Avatar
Pazo. Looking at what it say on pin 14 for my car it does not say anything about the ABS at all
Looking at the instructions for the year 1992 it says a bit about the W140 but thats it
It says nothing about the ABS on pin 14 in the drawing above
Old Mar 6, 2022 | 02:42 AM
Pazo's Avatar
TheSaint, that's what I tried to write: your car does not have OBD1 ABS diagnostics. Nevertheless, I'd read all codes - there could be some clues. How's your OVP?
Old Mar 11, 2022 | 02:18 AM
John Coin's Avatar
1994 mercedes sl500
I did the same thing on my 94 sl If you're standing in front of your car left side back buy the windshield take the
plastic cover off where the obd1 connector is.You will see 3 or 4 computer modules on one of them has a fuse on it check it.
Mine was blown changed it and the warning light went out.
Old Mar 13, 2022 | 05:58 AM
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
Have you tried the reset procedure?
Turn steering wheel full lock to the left and then full lock to the right.
Old Mar 16, 2022 | 01:13 PM
TheSaint's Avatar
PAZO. I know. The drawing in the post of the 16 pin connector is of my car (I made the drawing a long time ago)
Old Mar 16, 2022 | 01:15 PM
TheSaint's Avatar
I see.I know where you mean under the plastic cover where all of the relays and ECU`s are located. This is to the left when standing in front of the car looking at the engine as you say
I will try that
Old Mar 16, 2022 | 01:16 PM
TheSaint's Avatar
I have not tried to do that since i thought that procedure was just for bleeding the power steering for air
But i will try
Old Mar 16, 2022 | 01:20 PM
TheSaint's Avatar
One more thing that i saw the other day that also stopped working after the "short" and that is the fuel consumption gauge.
So it is the ABS lamp that is constant lit and the fuel consumption gauge that do not work as it is supposed to. It worked as it was supposed to before i managed to short the battery
Anybody here that knows if the turn signal relay have something to do with the ABS warning lamp and also the the fuel consumption gauge?
The fuel consumption gauge also does not work proper after the short
Old Mar 20, 2022 | 04:22 PM
TheSaint's Avatar
John Coin You was absolute correct about what you said
There are two 10 Amp fuses there and one of them where blown so i replaced the blown fuse and now everything is as it is supposed to be
The ABS warning lamp is not on anymore and the fuel consumption gauge works as it is supposed to
So to my fellow MBWorld members thanks a lot for you help
Old Mar 21, 2022 | 09:00 AM
Pazo's Avatar
Great to hear. So it was simply one of the two 10A OVP relay blade fuses?
Old Mar 25, 2022 | 04:32 PM
TheSaint's Avatar
Yes it was just one of the 10 a fuses that sits under the plastic cover
