SL/R230: First Impressions of SL500 Test Drive
Surprised,
Prolix
Surprised,
Prolix
Surprised,
Prolix
if you are going to be spending around 100K for the car, it would be good to check out a used SL55 or SL600 (you should be able to get an 04 for around that price). It is a world of difference between that and the 500, and a completely different driving experience. I went through the same thing as you. If i was going to spend that much, i wanted a car with some zip to it. I initially was looking at the 05 SL500 (this was the upper limit of my price range) which i drove with the 7 Speed tranny, and it was quite good (i am comparing this to my wife's 03 E500, which i had been driving at the time). Of course, it wasn't thrilling, so i test drove the 55 which i loved, but it was a little stiff and a little louder than the 500, not to mention 30 K more. So then i was debating SL500 vs 55, when i thought about the SL600. I set my sites on a 600 which i absolutely loved. After much looking around, i found a used 05 Sl600 (1100 miles on it) for 108K (just a little more than the 500), so i went for it. No regrets at all...by far the most fun car i have driven. So look around thoroughly on different sites for used vehicles. I used www.cars.com and www.autotrader.com. They both give great ways to do advanced searches for vehicles.... Inbox me with any questions. Good luck...
Think about whay you are comparing... a car with a automatic HARD top convertible, and lots of sound deading material..
A G35 is MUCH lighter... yet VERY noisy when driving ( I know I had one), has cheap interior materials and is NOT a convertible.
Imagine how much of a slug the G35 would be if you made it a hard top convertible. A better comparison would be a G35 and a 350z convertible.
The G35 is not even in the same league as a SL500.
Surprised,
Prolix
Sometime in 2004 they changed from the 5-speed to the 7-speed.
The 7-speed transmission has SUBSTANTIALLY more get up and go power than the 5-speed. I'd try one of those first.
Prolix
If I hammer the gas from a standing start, it feels quite lively indeed. Rolling along at 20 mph or so and then flooring it doesn't seem to do much, however, even if I feel the kickdown switch engage.
On the freeway, I find that holding the shift lever to the left for a second (which downshfts to "optimum" gear, usually 2or 3), and then hitting the gas, has a much more satisfying effect than just flooring it and using the kickdown to shift.
That said, I have driven a BMW M5, which is clearly in a different league, and an SL55, which is a different planet altogether, as much for the snappy shifting and overall toghter feel of the transmission as for the 490-to-300 HP difference. The SL55 feels much more like a manual transmission, while the SL500 has a lot of slop in the torque converter (i.e. RPM only vaguely related to speed).
I have not driven an SL600 to compare, nor have I driven the 7-speed.
Your other comments agree with my experience,although I will caution that, on mine at least, wind noise is much reduced when I open and re-close the windows with the roof up, ascompared to closing the roof onto the windows.
I never meant to imply that the two cars have equal build quality - they absolutely do not. The G35 received a lot of criticism for the use of cheap interior materials, and for scrimping on sound deadening materials. I just expected the SL500 to deliver the same acceleration and low-end torque that the G35 does, and this car I test drove did not. Is the SL500 a far superior vehicle? Absolutely............in every way but acceleration. I certainly don't feel like I need the 496 HP of the SL55, I'm not looking for mega-performance and have NO experience with cars that powerful, but based on my test drive yesterday, the 5 speed SL500's are underpowered and would not give me a satisfying driving experience.
I need to drive a 7 speed SL500 and a SL55 and report back on my impressions.
Prolix
Prolix
I don't think you'll be disappointed with a new 7-speed SL500.
For me, I couldn't justify spending another $30K for a 55, especially when traffic conditions here in So Cal prevent the use of that extra power. I can think of better ways to allocate that $30k
Anyway, good luck either way.
I haven't played with the 'optimum shift' at all yet, but I'm guessing it would give it a little more punch. Sometimes off of a corner, if I completely floor it, it seems to take a while to wind up and go, but I'm sure it's just where I am in the gear. But I'm just cruising around on PCH mostly.
For me the speed/power was not a concern at all, (I used the extra $40k to buy another investment property), but if it had been I would have HAAAAD to step up and get one of the big boys (55/600). There's really no comparison and there's nothing worse than buying down, wishing you hadn't then buying the one you wanted later. Waste of time AND money.
Good luck though! You deserve to have what you want - Enjoy!
just be sure to test the 7 speed SL under various city conditions. In this "MB Lovin' forum" it is hard to find a critic,
but I can tell you this: although the new 7 speed tranny, has better acceleration and fuel economy,
it sounds more like a lawn mower, or a boat engine, thanks to its impreceptible shifting. It has a "new concept" shifting program too,
which was designed to deal with the legendary MB lack of throttle response from low speed (see TroonArmy above ),
but it produced some unpleasant "sideeffects" (see some of my posts). I don't find it as much fun as my 2003 SL.
Oterwise it is a fabulous car...in need of major engineering, both soft and hard: leaky trunk, unreliable electronics,
bad software, over intrusion in driver choices etc. Having said this, no other comapny has mass implemented as many innovations
and sfety features as MB, over my drivnig lifetime....
