SL/R230: get rid of scratches on the SL
Old May 26, 2005 | 11:03 PM
Tico's Avatar
How do u get rid of the scratches on ur sl on the bottom of ur bumper, no one can see them but i know i scartched it and when u put ur head down the bumper u can see the scartches. I tried using these scratch removers but they didnt work. The best way to get Rid of them is to re-paint the bumper? I scartched the bottom going off a driveway which i didnt know it was that steep.
Thanks for the help.
Old May 26, 2005 | 11:22 PM
StephenK's Avatar
2006 SL600, 2001 S500, 1996 SL320
Scratches
If they are under the bumper, I would leave them alone, repainting the bumper is just looking for a problem. No matter what anyone says, nothing is like factory paint. I have looked at work from several body/paint shops over the years, and can normally find flaws without much searching.
Old May 26, 2005 | 11:23 PM
vraa's Avatar
I wouldn't worry about it, my dads SL500's front bumper is cracked. You can't even tell though.
I'm going to buy him a new front bumper soon anyways.
Old May 27, 2005 | 01:15 AM
Tico's Avatar
anymore suggestions i know i should leave it alone. But it bugs me. There is no way anyone can see it i am the only one who knows about it. Just knowing the fact its there.
Old May 27, 2005 | 01:54 AM
tiggerfink's Avatar
SL500 and A-CLASS
Do you have parktronics?
Old May 27, 2005 | 03:14 AM
Dvinn's Avatar
03 E500
Touch it up. If it is not visible you can buy a touchup paint from the dealer and paint it yourself. The paints from dealer will match perfectly.
Old May 27, 2005 | 03:39 AM
LovinMercedes's Avatar
2026 Mercedes CLE53A4 AMG Cabriolet and 2025 MAYBACH EQS680V4
Thumbs up There is an answer...
I have done this on other cars so I know it works. You need a good body shop.
You DO NOT want to paint the entire bumper as it will never match perfectly and the factory paint can not be duplicated.
What a good body shop can do is take off the bumper, prepare the underside of the bumper and paint ONLY the underside. He then clear coats it slightly higher but still leaving the front of the bumper in tack. He only paints the underside of the bumper and clearcoat slightly higher.
This will work but it takes a great body shop. I have never done this on my Mercedes but I have done it at least twice on other cars I own and you could NEVER tell it was painted and the underside scratches were removed. You can only do this once or twice to the bumper because more than that will cause too much paint buildup.
Good luck.
Old May 27, 2005 | 03:05 PM
clkcadet's Avatar
S550
why worry about the bottom of your front bumper? you will just hit it again on the way out of the paint shop
Old May 27, 2005 | 07:49 PM
That I agree with.
Old May 29, 2005 | 01:18 PM
NeilC123's Avatar
SLK 230
bumper question...
Hi,
similar to this topic - a month ago i hit a tyre that was lying on the motorway and it cracked the underside of my front bumper. I was thinking of just getting to to a MB dealership and getting a new one and have them replacing it. Would everyone agree with this? As opposed to having the old one fixed? Or do you think i should just leave it?
Old May 29, 2005 | 02:07 PM
Originally Posted by NeilC123
Hi,
If the bumper is cracked it will have to be replaced. You can not properly repair a rubber type bumper once it is cracked.
