SL/R230: New Turbine Rims - Tire Storage Question
2003 SL500 Sports Package
Hi -
I just put the new turbine rims with the PZero Rossi tires on the SL500. It looks so sweeeet......
I now have two sets of wheels the original 5 spoke 18" factory wheels with the Michelin Pilot Sport All Season tire which is great in the snow.
And these smokin' turbine rims off of a new SL600 with the PZero Rossi tires for summer. I'm soo...stoked, these summer tires are like riding on air next to the noisy all-season's.
I have a question - do you know anything I should do to store the other wheels. Like should I let some air out of the tires.
Originally Posted by a site i googled for
Store tires properly when you are not using them. Place them in a cool, dry place, away from direct sunlight to avoid premature aging. Also, prevent exposing them to ozone sources such as sun, arc-welders and mercury vapor light bulbs, as well as ultra-violet rays and inclement weather. Store tires standing upright on the tread and avoid stacking, which can weaken the tires on the bottom of the stack.
SL55, ML500, GT3 RS, 997C2S
You could soak them in Armorall and when you put them back on your car you can go sliding down the road backwards with your wheels spinning forward. Next you will 360 against the granite curb and blow all 4 tires, ruin all 4 rims, and jack up most of the body panels. A friend gave his front end tires from his vette to me, treated this way.
2002 BMW 745Li Black/beige, 2006 SL600 Capri Blue/Black still on order
Don't let the air out...keep normally inflated. DO keep them out of the light with a nice cover if you have one (old tarp or sheet is better than nothing). Don't use armor all (I think you get that) That stuff is not good for anything really. People in the midwest do this alot for the summer and winter tires, so you might contact someone in the Northern tier for more info on tire storage too. Don't worry about them exploding on a hot day...they get MUCH hotter when you drive on them. Sunlight is enemy number one.
SLK 55 AMG
Local tire fitting places tell you to not stack the tires on top of each other, but rather to place them against a wall, but standing up. Then you need to rotate them once a month so that the rubber doesn't take on a new form.
But apart from this info, I'm no expert so take it only with a grain of salt.
Several MB's Superperformance MK III Cobra
May be a little overkill but it certainly worked well. I purchased them from Griots garage; they are called a wall mount hanger and cost about $25 each.
Lou's suggestion is the best one. Keep your tires inflated at the rec'd COLD level and then hang on the rack to avoid any flat spots, etc. I track my 996 enough that I am swithcing between my street wheels to track wheels often enough that I avoid any potential problems.
