SL/R230: Automotive Recall and Technical Service Bulletin Titles
Safety Recalls
TSB Number & Issue Date TSB Title
2004050014 OCT 04 Recall - SBC Hydraulic Unit Reprogramming
General Recalls
2002070011 SEP 02 Campaign - Front Axle Carrier Damage Inspection
Service Bulletins
P-32_50-24 MAR 05 Suspension - ABC Suspension Humming/Buzzing Noise
P-42_46-58 MAR 05 Brakes - Sensotronic(R) Brake Control System Activation
P-42_10-51B MAR 05 Brakes - Front Brake Squealing and Grinding Noises
P-27_35-52 FEB 05 A/T - No Gear Engagement/No Vehicle Movement
P-68_60-37B JAN 05 Interior - Sun Visor Cover Broken
P-91_10-84 JAN 05 Interior - Seat Backrest Crackling Noise
P-77_30-35 JAN 05 Body - Vario-Roof(R) Front Catch Noise
P-30_30-61 DEC 04 Cruise Control Inoperative
P-82_10-419 DEC 04 Lighting - Condensation in Headlamps
P-54_65-130 DEC 04 Parking Assist System - Triggers For No Apparent Reason
P-32_25-19 DEC 04 Suspension - Shock/Strut Replacement Guidelins
P-42_46-54 DEC 04 Brakes - SBC Hydraulic Unit Part Identification
P-42_46-53 DEC 04 Brakes - 'Brake Malfunction SBC Visit Workshop' Message
P-42_46-46B DEC 04 Brakes - Sensotronic Brake Control (SBC) Bleeding Proc.
P-18_00-17C DEC 04 Engine - Approved Engine Oils (Addition)
P-82_70-346B NOV 04 Cell Phone - Inoperative/Locks-Up
P-33_15-16 NOV 04 Steering - Steering Wheel Twitch on Low Speed Braking
P-15_40-54 NOV 04 Charging System - Insufficient Charging
P-42_46-50 OCT 04 ABS - Sensotronic(R) Brake Control Diagnosis/Repair
P-27_00-47A OCT 04 A/T - 722.6 Oil Leaks From Electrical Connection
P-63_20-06 OCT 04 Body - 'B' Pillar Cracking Noise
S-07_61-38F OCT 04 Engine/Transmission Controls - SCN Coding
P-82_30-366 SEP 04 Wipers/Washers - Wipers Chatter/Noisy After Blade Change
P-33_15-15 AUG 04 Steering/Suspension - Torque Strut Replacement Parts
P-82_00-260A AUG 04 Audio System - CD's Won't Play or Eject
P-83_00-70 AUG 04 A/C - Inoperative/Codes Set/AC OFF Lamp Illuminated
P-77_30-20A AUG 04 Body - Sudden Wind Noise at Rear Window
P-91_29-56B JUL 04 SRS - Warning Lamp ON/DTC B1863/B1864 Set
P-42_10-48 JUL 04 Brakes - Premature Rear Brake Pad Wear
P-58_20-136 JUN 04 Wipers/Washer System - Service Procedure
P-91_60-74 MAY 04 SRS - Coding Unnecessary
P-42_46-41 MAY 04 Sensotronic(R) Brake Control Unit - Service Precautions
P-27_00-40A APR 04 A/T - Shift Concerns/No Codes Set
P-42_10-33B MAR 04 Brakes - Front Brakes Shudder
P-42_20-35 MAR 04 Parktronic System(R) - Intermittently Inoperative
P-77_37-21 MAR 04 Body - Trunk Lid Won't Close When Operating Vario Roof
S-07_61-039A MAR 04 Engine Controls - DTC Trouble Shooting
P-00_45-77 FEB 04 Interior - Squeaking/Creaking Noise Kit
P-82_95-305 FEB 04 Emergency Contact/Alarm System - System 'Runaway'
P-68_10-22 FEB 04 Interior - Instrument Panel Catch Hook Broken
P-07_00-28F FEB 04 Engine Controls - Lack of Power/Hesitation/MIL ON
P-33_15-10 FEB 04 Steering/Suspension - Alignment Requirements
P-82_00-228B FEB 04 Audio System - Mutes Randomly
S-01_30-15 FEB 04 Engine - Cylinder Wall Damage Assesment
S-49_10-08 FEB 04 Exhaust System - Rattling/Hissing/Humming Noises
P-91_60-61B JAN 04 Air Bag System - Warning Lamp ON/DTC's B1859/B1860
P-40_10-43 JAN 04 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
P-54_65-104A JAN 04 Parking Assist System - Triggers for No Reason
P-47_10-27 JAN 04 Fuel System - Fuel Filler Cap Hard to Remove/Install
P-49_10-07 DEC 03 Exhaust System - Rear Exhaust Bracket Broken
S-18_00-16A DEC 03 Gasoline Engine - Oil Sludging
S-54_21-101 OCT 03 Engine Controls - ECM Flash Process Change
P-82_85-288 SEP 03 COMAND(R) System - Unable to Enter New Destination
P-62_30-05 SEP 03 Steering/Suspension - Crackling Noise When Turning
P-18_00-22 AUG 03 Engine - Oil Fill Capacity Correction
P-07_07-34 JUL 03 Engine Controls - MIL ON/Multiple DTC's Set
P-82_85-264 JUL 03 Navigation System - Inoperative/Erroneous Guidance
P-07_00-21F JUL 03 Engine - Piston Slap Sound on Acceleration
P-91_60-61 JUL 03 Restraint System - SRS Lamp ON/DTC's Stored
P-14_30-15 JUL 03 Emissions - MIL ON/DTC P2003 Stored in Memory
P-27_60-37 MAY 03 Antitheft System - Cannot Shut Vehicle OFF
P-20_10-23 MAY 03 Cooling System - Water Pump Leakage
P-91_60-57A MAY 03 SRS System - Control Module Service Precautions
P-42_46-28 APR 03 ABS System - Buzzing/Droning Noises
P-54_65-86 APR 03 Parking Assist System - Apparent Erroneous Activation
P-82_70-222 MAR 03 Cell Phone - Phone Won't Fasten Into Cradle Holder
P-67_00-09 MAR 03 Body - Windshield/Rear Glass Body Seam Corrosion
S-07_61-27A MAR 03 Engine Controls - ECM Reprogramming Procedure
P-30_30-60 FEB 03 Audio System - FM Band Radio Interference, Ignition ON
P-80_57-20 FEB 03 Audio System - RF Interference Explanation
P-46_20-10 FEB 03 Steering Rack - Connector Leaks
P-54_30-81 FEB 03 Instruments - Fuel Gauge Sticks at '0'/Low Fuel Lamp ON
P-42_46-24A DEC 02 Brakes - Noises When Releasing Brake Pedal
P-83_55-65 DEC 02 A/C - Compressor Cycles Frequently
P-88_50-31A DEC 02 Body - Trunk Lid Contacts Tail Lamp
P-32_50-12 DEC 02 Automatic Suspension - Hydraulic Fluid Leaks
P-82_85-210 NOV 02 Navigation/GPS System - Various Malfunctions
P-91_29-54A NOV 02 Interior - Seat Memory Positions Not Recalled
P-54_21-74 NOV 02 Engine Controls - ECM Programming Procedure
P-82_62-169B OCT 02 Audio System - Various CD Player Malfunctions
S-82_70-135B OCT 02 Fiber Optics System - Configuration/Version Coding
P-54_80-69 AUG 02 Instruments - Dashed Lines Displayed Through Odometer
P-40_15-41A JUL 02 Tire Pressure Monitor - Implausible Fault Codes Set
P-82_85-198 JUL 02 COMAND(R) System - No Sound/Whistling
S-07_08-001 JUL 02 Engine Controls - Software Calibration Number Coding
P-77_30-16 MAY 02 Body - Vario Roof Fluid Level Checking
P-42_10-21 MAY 02 Brakes - Corrosion on Brake Disc Bowl
P-42_10-20 MAR 02 Brakes - Groaning/Squeaking Noises
S-82_70-179A FEB 02 Cellular Phone - V60 Programming Instructions
Safety Recalls
Service Bulletins
P-27_60-53 MAR 05 A/T - Harsh Downshifts on Acceleration
P-82_85-424 JAN 05 Navigation - Navigation Unavailable/No DVD Inserted Mssg
P-42_46-55 JAN 05 ESP/SBC - Event Display Feature
P-82_35-428 DEC 04 Wipers/Washers - Windshield Washer Nozzles Heating Inop.
P-82_85-374A OCT 04 Navigation System - Erratic Operation/Inoperative
P-82_30-399 OCT 04 Windshield - Blistering Near Rain/Light Sensor
P-27_60-44 SEP 04 A/T - Implausible Downshifts
P-54_10-116 JUL 04 Electrical/Battery - Solar Charging Panel Installation
P-18_20-22 SEP 03 Engine - New Oil Filter Requirements
Safety Recalls
Service Bulletins
P-27_60-43 JAN 05 A/T - Rough Converter Engagement/Droning/Buzzing Noise
P-01_45-15 FEB 04 Engine - Oil Leak
P-30_20-61 DEC 03 Engine Controls - MIL ON/Limp Home Mode/DTC's Set
Safety Recalls
Service Bulletins
P-18_10-28A JAN 05 Engine - Correct Oil Level Message Displayed
P-47_20-31 DEC 04 Fuel System - MIL ON/Misfire DTC's Set/Hard Hot Starting
P-18_00-24 JUN 04 Engine - Oil Level Check
Safety Recalls
General Recalls
2004090005 NOV 04 Campaign - COMAND/Audio Gateway Flash Update
Service Bulletins
P-82_85-443 MAR 05 COMAND(R) System - Disc Drive Malfunctions When Cold
P-82_85-412B MAR 05 COMAND(R) System - No Audio/Erratic Operation
P-82_85-433 FEB 05 COMAND(R) Unit - CD Stuck in Head Unit When Updating
P-82_62-410A NOV 04 Audio System - No Sound/No Station Memory
P-54_35-120 NOV 04 Electrical - Horn Sounds Inadvertantly
S-07_08-43A OCT 04 Engine Controls - CVN Recoding After Module Replacement
Safety Recalls
General Recalls
Service Bulletins
Safety Recalls
General Recalls
Service Bulletins
General Recalls
Service Bulletins
P-07_61-47 MAR 05 Engine Controls - Misfire Conditions
HomeRun, why the aggro? I didn't see Ricky trashing the car. As I say, having this information is very helpful for getting permanent fixes to problems and keeping us owners happy.
I know that my dad has had the Michelin Pilot Sport A/S's on his car from the dealer and then they've tried to figure out why his car is drifting to the right...!
Don't worrk about HomeRunPark, he's just a little bitter because I'm cooler than he it
i'm kidding, of course. the more info, the better, especially given the MB service propensity for stating: "i can't reproduce it, so i can't diagnose and treat it."
seems like quite a laundry list of defects. MB had better clean up their act.
ToonArmy, if it's more than another car, then it's drifting. Try driving with another car (better yet, another SL) to check if it's the crown. All roads will cause the car to drift a tad bit to the right, but it should be so little that you shouldn't be able to notice it unless you're running wide tires.
david_101: Information should be free
Oh I'm way too young..
I'd still present this list to the dealer and ask them to overview each one for your car if possible.
Still print it out and ask the dealer to check if those are fixed.
theboogers, I'll do the S55 as soon as I have time
