SL/R230: Recommended Tire Pressure?
2003 SL500
What is the recommended tire pressure for the Michelin Pilot Sport OEM on the SL500? I have the 255/40/18 fronts and 285/35/18 rears.
After fixing the tire pressure monitor, the car was returned to me from the dealer with cold readings of 28 front and 30 rear. These warm to 30 and 32 respectively.
Enterprise rent-a-car!!!
correct pressure for an R230 with those tires is 30psi frt 33 psi rear.
Not sure what dealer the other guys are working at but they should check the tecnical data book(or look inside the gas flap)
SL/M6
I think the dealer put them lower since it makes the ride smoother, etc.
On my 20's I run 2 psi more in the front since that is what Luke said is best...
