SL/R230: 428 - Gear Change Buttons On Steering Wheel
After checking out 2 SL500's(both 2005), I found one of the cars has this gear change buttons on the steering wheel, but the other doesn't.
I know on SL55 AMG, they all have the gear change buttons on steering wheel.
But for SL500, 2005 model year, is this an option or due to the production date, they put on as standard?
Thanks.
Thanks.
Actually, I checked both cars thoroughly, even the original window stickers show both have AMG sport package.
Same AMG front/rear bumpers, same wheels (5 wholes turbine).
That's why it makes me so confused one comes with the gear shift buttons but the other doesn't.....
Here are some photos I found on eBay
2005 SL500 with Sport Package.
if you look closely, you will see the black gear change buttons behind the wheel
http://cgi.ebay.com/ebaymotors/AMG-S...QQcmdZViewItem
Does this car have a wood steering wheel now?
Probably like what you said, one upgraded to the "Wood Trim" package only, and the other went for the more expensive one.
Actually, I went test-drived the SL500 with shifting buttons. They act slightly different from the SL55(right button for gear up and left for gear down).
Those buttons are both bi-directional(one way for gear up and the other way for gear down). Similar to Porsche's tiptronic buttons.
I don't know if this is good but at least it may reduce the confusion when changing gear while you turn the wheel 180 degree.
