SL/R230: I lowerd my SL600 for $22,-..!
Old 08-08-2007, 03:47 PM
maxabo's Avatar
2007 Väth SL65 AMG. 2007 BMW Alpina B5s. 2007 BMW M6.
Here's a tip you might find useful:
From what I understand, there's 2 ways to lower this car.
1. An electronic devise for $2000,-, where the car lowers itself.
2. The mechanical alternative, for about $450,-, where you get 4 adjustable rods to replace the original with. And there you adjust each wheel separatly.
And it's to this last alternative we have found an even cheaper way.
I bought 4 adjustable rods, ment as stabilizers for extra mounted high beam lights. For less than $6,- each...
Then you saw the stock rods in half, and drill a couple of holes, so you can fit the adjustable rods on to the stock rods.
And there you go... Money saved.
To lower the car about an inch:
Make the front rods about 10 mm longer, and the rods in the back about 10 mm shorter.
Total time for this mod, is approximatly 1,5-2 hours.
Sadly, I didn't take any pics, but it's really easy!
Old 08-10-2007, 02:01 PM
PA55AMG's Avatar
2010 Range Rover S/C 2010 Land Rover LR4 HSE Lux Plus 2007 BMW R1200GS
Congratulations on your project, but I would like to point out that the Adjustable air ride system only costs $225-$250, not $450.
www.adjustableairride.com
Old 08-14-2007, 12:00 PM
maxabo's Avatar
I didn't know of that company. That was actually cheap.
But since I live in sweden, allmost everything is more expensive here. So I just converted our prices here into your US$...
But that should mean, that the adjustable rods I got instead, are even cheaper than $22,- in the US then...
Old 08-14-2007, 12:35 PM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
That is a great product!! I am going to look into carrying their line for our clients.
Old 04-05-2009, 09:26 PM
Auraraptor's Avatar
IngenereAMG, are you? Or did you change your mind? Do the links still lower the car further even at speed? (ie past what the car normally drops to at high speed?
Old 04-05-2009, 09:53 PM
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
Being there done that end up getting the links for $350 very accurate and cheap Here is a thread of mine on it .
https://mbworld.org/forums/sl-class-...ing-links.html
Old 04-23-2009, 02:59 PM
Badr1's Avatar
2003 SL-500 AMG
Smile
[quote=maxabo;2359598]Here's a tip you might find useful:
Sadly, I didn't take any pics, but it's really easy![/quote
Go to Midwest Control supply for everything from steel to stainless Heim joints. You can fabricate stainless steel 10-32 adjustable links with simple turnbukles and use HEIM joints with male threaded ends to attach to upper and lower sensor attachment points. All in All about $75 for a fully adjustable set of (4), but with a turnbukle that can be adjusted by hand at each corner.
www.midwestcontrol.com
Old 04-24-2009, 12:19 PM
We do carry them, but we have started using the STAR system to lower the cars. That's how we lowered mine and it's great.
Old 04-24-2009, 01:32 PM
Alex1's Avatar
when using the star system how did you do it, did you need that romess measuring tool?
Old 04-24-2009, 06:17 PM
daltex's Avatar
03 SL500
I am also interested in lowering with the Star system.
Please do a write up.
Thanks.
Quick Reply: SL/R230: I lowerd my SL600 for $22,-..!
